02-13-2019, 08:22 PM | #23 | |
Rep 190,777
Jb4 does not hide the CEL code, meaning you will have to clear it every 50-100 miles. Car will not pass emission even if code has been temporarily cleared. If you car is emission controlled in California, skip the downpipe
MostlyHarmless179.00 |
02-14-2019, 08:35 AM | #24 | |
Rep 292
Best mods for this car in California would be a JB4 tune with a CAI?
Current: 2018 X3 M40i (PB)
Previous: 2019 M240i (EB); 2002 E46 330i in OB |
02-16-2019, 08:24 AM | #26 |
Rep 351
jb4 no longer hides engine codes/cel. I e had the cel pop up from catless dp and cleared it whenever it comes in... typically getting on the throttle on a not warmed up engine. it's fine. the cel will come back in when it needs to.
02-17-2019, 04:55 PM | #27 |
2018 M240i / BMS CAI / JB4 / Catless VRSF
134
Rep 112
Anyone from NY have issues passing inspection running JB4 with Catless VRSF DP, or is it possible to have all monitors ready before the CEL appears?
02-25-2019, 10:10 PM | #28 |
Rep 70
heusing240i134.00 |
03-02-2019, 04:46 PM | #29 |
134
Rep 112
I know there are a few options for the O2 bung extension, that keeps the sensor out of direct flow but has anyone attempted this 90 degree bung: LEDAUT 90 Degree CEL Check Engine Light Bungs O2 Sensor Socket Real Mini Catalytic Converter Inside 201 Stainless Steel https://www.amazon.com/dp/B01MTA6OXG..._rAWECb9JXBCWA.
or has anyone replaced the actual sensor with a "simulator" functioning O2 sensor?
Can't stop the //Addiction...2020 Misano M2CS 6MT - New Toy
2018 m240i b58 - Formerly owned / BMS CAI / VRSF DP / JB4 map 2 - 340WHP; 363TQ 2016 328i xdrive n26 - daily 2015 GMC Sierra 1500 - daily driver HEUSING240i |
03-28-2019, 05:17 PM | #30 |
Rep 119
I have the VRSF 200 cell downpipe and when I first got it I had a CEL within a few miles. I got the stainless 90 degree spacer and it went off for about 200 miles, but came back on saying it was too lean. I got a small straight one for a few bucks and it's been off since (about 16 months and 10,000 miles).
2017 BMW M240i xDrive - Mission Performance Stage 2 and transmission flash, CSF Intercooler, VRSF 4.5" downpipe, Dinan midpipe, BMW M Performance muffler, Agency Power Cold Air Intake. 11.58 @ 116MPH
04-11-2019, 10:01 AM | #31 | |
Rep 19
04-11-2019, 10:05 AM | #32 |
Rep 119
https://www.vr-speed.com/vrsf-4-5-ca...0i-xdrive.html
Choose the catted version in the option drop down.
Mathew Miles13.50 |
04-13-2019, 10:38 AM | #33 | |
Rep 448
CG Precision DS-1
04-20-2019, 01:58 AM | #34 | |
Rep 19
04-20-2019, 05:56 AM | #35 |
Rep 119
https://www.amazon.com/dp/B07JGRM1HR..._BOVUCb56Q65Z9
You can pick these up at pretty much any auto store like Auto Zone, Pep Boys, etc. but here is a link to Amazon.
04-22-2019, 11:30 PM | #36 | |
Rep 70
04-23-2019, 09:00 AM | #37 |
Rep 8
I got a VRSF hatless down-pipe, I installed it with a 90 degree spacer and to worked perfectly for 2000 miles. I got a CEL and thought it was a normal cat deficiency code but ran a scanner and got all this. Something with the heater circuit.
p0030 p0036 p0031 p0037 any help and fixes is greatly appreciated. thinking of removing the downpipe and taking it to the dealer and see what they find. |
04-23-2019, 05:25 PM | #38 |
Rep 119
There's a heating element in your O2 sensor. While changing the down pipe it may have gotten banged and messed up the element. When the shop did mine they hit it putting it in the new downpipe. Had to buy a new one because of it.
giangi_m240i1.50 |
04-30-2019, 11:33 AM | #39 |
Rep 8
Anyone knows the part number on both O2 sensors? And were ti get the best deal to buy them.
05-11-2019, 11:38 AM | #40 |
Rep 70
Hey greg21040
Just realized u said u got the high flow 200 cell race cat instead of the catless. Do you know if the spacers you are using would work for catless too? https://www.amazon.com/dp/B07JGRM1HR..._BOVUCb56Q65Z9 |
05-11-2019, 11:54 AM | #41 |
Rep 119
I'm not sure, probably. Don't be discouraged if you get. CEL. It might take small adjustments. I just happened to see the plug defoulers in Auto Zone the other day. I imagine there are several different size holes in them. If you get a CEL that's too lean you can drill out the hole in the spacer a bit. If it shows too rich then see if you can get one with a smaller hole. It's all about how much catalyst reaches your O2 sensor. I got a $21 scan tool that deletes codes. Then I'd just google the code and it'll tell you.
Hope this helps.
05-13-2019, 10:37 PM | #42 | |
Rep 70
can you tell us more about your scan tool that deletes codes? I just need the cel deleted before bringing in my car to service. from what i know, only the jb4 can delete/suppress the cel light |
05-14-2019, 05:04 AM | #43 |
Rep 119
Scan tool
You can find them almost anywhere for cheap. Here is one on Amazon. It reads codes and clears them.
https://www.amazon.com/dp/B0725Q6X7B..._9cP2CbPQCQ3F7
05-14-2019, 11:43 AM | #44 | |
Rep 70
