2Addicts | BMW 2-Series forum Technical Topics Tracking / Autocrossing Bridgestone RE71r 235/45 17 for Auto X
      09-09-2019, 02:39 PM   #67
rhop101
Drives: BMW M235i, Honda S2000 AP2
Yea think I’m just gonna go 225/255 just to play it safe. Mainly using the car on road with maybe 2-3 autocrosses a year at most, so we’ll see what I think about the 255 on the back maybe next time I’ll get the 235 if I think it’s too pushy.
I see what you mean about the flipping. If I was autocrossing more that would definitely be a reason to go with the RE71
      09-16-2019, 10:15 PM   #68
TajoMan
TajoMan's Avatar
174
Drives: M240 xdrive, X3M40i
Track day at Autobahn CC north
Track day at Autobahn CC north.
Tire temp went up to 190F in front (according to TPMS).
It still held up pretty nicely without being too greasy.
More and more I drive on track, it feels like I may need 18 inch rim.
Tire seems too soft during turn. Maybe too high sidewall from 17 inch 45 series?
      09-17-2019, 07:43 AM   #69
bbnks2
Drives: 135i N55
Re-71r have a very soft sidewall. Might be better off with a 40 series if you want a bit more responsiveness out of the tire. What tire pressures were you at? Upping the pressure can help a bit.
      09-17-2019, 10:09 AM   #70
TajoMan
TajoMan's Avatar
174
Tire pressure was 42/40 hot. (36/33 cold)
It's was higher than I run in Auto X. (37/32 hot)
I thought the RE71r was one of the stiffest tire among 200tw tires.
What other tire has stiffer sidewall? (200tw)
      09-17-2019, 10:21 AM   #71
dradernh
dradernh's Avatar
4399
Drives: 2017 M240i
Still on the 235s? If so, I'd say you've definitely gotten your money's worth out of them!
Regarding your tire temperatures, I haven't seen any published data on recommended tire temps for the RE-71R, but I'd guess that 190 degrees is pretty high. FWIW, I've understood the RE-71R to be more of an autocross tire than a track tire. I've never used them, though.
To run a car with this much weight and power on the track, you'll get a dramatic boost in grip by increasing both your wheel and your tire widths. And by adding some negative camber. And an LSD. And...
Seriously, 8½-9" wheels and 245/40s would create a significantly different experience. If cost is an issue, though, I'd start with camber. Just my 2¢.
As I say, I haven't run the tire, but if I had them and didn't know where to start, I'd aim for 35-39 hot.
Perhaps other drivers with track experience on the RE-71R can weigh-in here.
Dylan861330.00
      09-17-2019, 10:35 AM   #72
bbnks2
Drives: 135i N55
I know them to have very soft sidewalls in comparison to just about any other 200tw tire. That's one of the reason I think they provide good grip even in the cold. Soft tire compound and soft sidewalls allow a lot of flex. I've seen plenty of picture of RE-71r flexing like crazy under load.
40psi is decently high. I wouldn't go any higher than that. Move to a 40 series tire if you want a sharper response from the tire.
      09-17-2019, 03:12 PM   #73
TajoMan
TajoMan's Avatar
174
The tire lasted pretty good so far.
140 Auto x runs, 3-20 min track sessions. I had to flip it though.
I will be doing 2 more auto x this year and it will be DUN.
Primary focus for me is staying in FS for Auto x. So no wider rim or camber.
That's actually kinda surprising. I thought the RE71r has stiff sidewall.
Maybe going for 235/45/17 was a mistake. 225/45/17 could be better with only 0.1" less thread width.
Next year, I'm thinking about going 245/40/17 on current 7.5" rim.
Apparently, lots of GTI guys run 245 on their 7.5" rim for auto x.
At least I will have shorter sidewall with this setup. (25.4" vs 24.7" in diameter, so 0.35" shorter sidewall. )
Will see how it works.
      10-15-2019, 09:53 PM   #74
TajoMan
TajoMan's Avatar
174
Cone Halloween
Tires nearing end of it's life.
1 more Auto X left this year.
I really need to work on driving smoothly.
It looks like the tires are squished quite a bit.
Could be better with 18 inch I guess.
      11-18-2019, 09:34 PM   #75
TajoMan
TajoMan's Avatar
174
last auto x of the year
It was last Auto X of the year.
Due to the weather around here, I had to put on winter tire on 17" rims.
So this Auto X was with stock PSS. (RE71r was pretty much done anyway)
The stock PSS was just so slippery (compared to RE71r)
First couple of runs, car was all over the place.
Weather was fairly cold as well. (40~45F)
Still, I never felt this much sliding with re71r. lol
Weirdly, I kinda think the car felt more balanced (or natural) without too much body roll with PSS.
When I used RE71r, car seems to have excessive body roll on the corner.
Maybe the RE71r is too much tire for the chassis?
Now I have 5 month to think about what tire/size that I want for next year.
      06-21-2020, 11:14 AM   #76
TajoMan
TajoMan's Avatar
174
First Track Sprint this year.
I ended up with 225/45/17 Hankook RS4.
It has stiffer sidewall than RE71r for sure. Surprisingly quieter as well.
Ultimate grip level seems little less than RE71 but I feel like this tire is batter suited for the stock suspension. (Maybe RE71 was little too much?)
Haven't tried it for auto x yet. Will see how the shoulder wears.
      06-24-2020, 08:08 PM   #77
ggggbmw
Drives: 2017 M2 Manual
This is the tire I use for track and auto-cross. Seriously, it's quieter than the RE71? Oy. I guess my PSS really have me spoiled for a quiet tire, because I hate how loud the RS4 is. Can't wait to get them off the car after a track weekend.
Yes, the RS4 has very stiff sidewalls. Totally unlike the PSS. Virutally no roll-over scrubbing. Even running at 32-34 PSI hot (starting about 25 PSI cold), I've just barely gotten to the the little triangle edge markers. And when I did, I reversed them to start wearing on the other side.
You'll probably find that the RE71 was better at auto-x. It sticks better when cold. But if you're just doing it for fun, the RS4 is plenty capable.
Do watch your pressures though. If you get over 36-38 PSI hot, the RS4 will start sliding like crazy.
      06-24-2020, 08:33 PM   #78
TajoMan
TajoMan's Avatar
174
I was surprised as well. RS4 is definitely quieter (at least when new) than RE71r.
Compared to those 2 tires, PSS is like marshmallow. So soft and quiet.
Thanks for the tip. I will watch the pressure.
      06-24-2020, 10:02 PM   #79
dradernh
dradernh's Avatar
4399
Drives: 2017 M240i
This may not be relevant here, but the purpose of the triangles on a sidewall is to indicate where in the tread the tires' wear bars are located. Alternatives to the triangle are the manufacturer's logo (used by Michelin) and the text string 'TWI'.
I mention it because many drivers think the triangle indicates how far they should be or could be exercising a tire's tread.
Maynard3848.00
      06-25-2020, 03:16 PM   #80
Maynard
Drives: 228iX & M2C
They do provide a very graphic display of how badly the street tires keel over on track though. I think mine were gone after the first weekend.
      06-25-2020, 05:37 PM   #81
TajoMan
TajoMan's Avatar
174
haha. yes
Mine on RE71r were gone after 1 auto x school with 26 runs on concrete.
Also auto x ed with MPSS couple of times and letters on the side wall were worn.
While that triangle is not a proper "using all the tread" indicator, it certainly shows how badly the tires roll. lol
Maynard3848.00
      06-26-2020, 09:37 AM   #82
nubbster927
Drives: AW M235xi
I'm shocked you were able to get so much life out of your tires! I only got about 75 runs out of my first set of 245/40/17 RE71R, and that was with flipping the tires and no track/open lapping sessions. And they were pretty much down to the cords at that point. Maybe it comes down to a difference in track surfaces to some degree.
      06-26-2020, 04:34 PM   #83
TajoMan
TajoMan's Avatar
174
Mine was done after around 160 runs or so.
At least half of those were on very grippy (rough) concrete surface.
You do need to spray water. Overheating will kill re71r badly.
      06-27-2020, 07:51 PM   #84
ggggbmw
aerobod once again, you are a font of incredible knowledge. I little googling confirms you are right on this. But, as a side benefit, they do seem to work pretty well as tire rollover indicators also. I've found that on a performance tire, if you are scrubbing them off, you are probably abusing the tire or the pressures are wrong.
I do love the little smiling Michelin Bibendum triangles. Always enjoy when a manufacturer has a little fun with something like that.
dradernh4398.50
      07-14-2020, 12:18 PM   #85
Two4me
Two4me's Avatar
26
Drives: M240i, X5 xDrive50i, MX-5
I'm not sure about your RE71s, but I nearly entirely wore out a set on a track weekend at a rough track here in NC called NCCAR. It's known for having harsh pavement and lots of technical curves.
Apparently that's common for RE71s to heat up and wear down quicker on track. From what I was told, they are perfect for autocross when you don't have time to heat them up, but for track days everyone suggested the RS4s instead as they last longer with close-enough traction.
So now I have two sets, one for track and one for autocross.
Full disclosure, this is on my NC1 Miata though. The BMW has just seen two autocross sessions with the stock tires.
      07-14-2020, 02:16 PM   #86
TajoMan
TajoMan's Avatar
174
RE71r wears out even quicker when overheated.
You really need to watch out the heat.
I had to spray water during the auto x even in 50~60F ambient.
I can imagine that it will just melt out during track day sessions, especially in warm-hot days.
      07-27-2020, 03:40 PM   #87
TajoMan
TajoMan's Avatar
174
Another Track Sprint last weekend.
I was pretty much faster through every turn (except the last turn) compared to the last time but the overall time was 0.6 sec slower.
Weather was so hot and it showed on straight line speed.
I was 4 mph faster through the "kink" but the top speed was the same as the last time at 104 mph.
Checked the intake manifold temp later and it was around 130 F. lol. no wonder why it was slower.
I guess running the AC until right before the start was not the good idea. haha
Dylan861330.00
      07-27-2020, 06:03 PM   #88
Are you still starting with the same cold pressures? I was running mine at 27psi cold to net 32psi hot and they were perfect coming off the track after 15 minutes in the blistering summer heat.
