2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions BimmerCode
      05-12-2017, 09:44 PM   #89
wdlfbio
Drives: 2013 4S, 2015 3500 HD Dually,
Got my new Vgate. Started car, plugged it in, Vlink popped up on my IPad wifi networks. Selected it, opened App, and Viola!!!! Coded away. Now I have to read up more on the expert mode so I can code enhanced BT and get Office (I have the Tech package and Nav, but no Office, so no texts). Also want to eliminate the seat belt nag. My mail box is 250 yards from the garage, so I don't need to listen to it nag me when I get the mail.
Stephan was absolutely stellar about helping. He even showed me how to get a full refund if I wanted and was very prompt with my requests for help.
'16 235i
'15 3500 HD Dually
'13 C4S
      05-13-2017, 12:28 AM   #90
wdlfbio
Ok, trying to add office.
Head unit is NBT EVO
Followed this series
I get office to show up in the main display and two others, but I don't get it when configuring my phone. I did check the box on my iPhone 6 to allow notifications under Bluetooth. I don't see emails or texts.
Sorry, pics are out of order.
'16 235i
'15 3500 HD Dually
'13 C4S
      05-13-2017, 06:13 PM   #91
MyMiniM3
Drives: 16" BMW M235i
Does connector interfere with tunes? Active Autowerke Active-8 specifically? I where does it plug in?
16' M235i Active Autowerkes Stage 2 Tune/DP/FMIC/CP - Dinan CAI/Lowering Springs - 19x8.5/19x9.5 Forgestar CF5V Bronze Burst
      05-13-2017, 07:10 PM   #92
BMWZ4
BMWZ4's Avatar
1907
OBD port
indizo5.50
      05-13-2017, 07:15 PM   #93
BMWZ4
BMWZ4's Avatar
1907
Curious if anyone has hit a snag coding ASD and M animated idrive power up.
Even though I've coded F80 for ASD it sounds as though ASD is actually off. Same thing if I restore the backup. Sounds like the ASD is off now. I also can't get the M idrive boot logo to come up. Start the car and the idrive immediately goes to the last thing I was using in idrive.
Has anyone experienced this and were you able to fix it?
      05-13-2017, 10:59 PM   #94
THEOS
THEOS's Avatar
19
Drives: M240i
I think changing ASD (to M3) on model years 2016+ no longer works.
As for the M iDrive boot animation, if the car hasn't sat for a little bit you most likely will not see it. Try locking the car and letting it sit for 10 minutes or so and try again.
BMWZ41906.50
      05-14-2017, 12:11 AM   #95
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Correct. You basically can disable by changing model, but not customize sound.
If you could electronics off with door open, then you see animation each time.
BMWZ41906.50
      05-14-2017, 09:02 AM   #96
BMWZ4
BMWZ4's Avatar
1907
Thanks guys. I'll try the animation later this morning as the car has been sitting all night.
      05-14-2017, 09:43 AM   #97
BMWZ4
BMWZ4's Avatar
1907
Ok, the logo comes up but disappears in milliseconds whereas the original BMW logo was displayed for maybe 2 or 3 seconds. I reverted back to the original logo and same thing...appears for milliseconds now....weird.
      05-14-2017, 02:35 PM   #98
kohlzor
Drives: 2017 M240xi
Instrument cluster
I coded the digital speedometer but noticed that I can't get anything to display above it. You see the --:-- that never changes. How do I get the time to display again?
      05-14-2017, 04:41 PM   #99
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
you need to set the time on your car
kohlzor46.50
      05-14-2017, 04:41 PM   #100
kohlzor
Drives: 2017 M240xi
Never mind went for a drive and it showed up weird glitch.
      05-14-2017, 05:32 PM   #101
shundel
shundel's Avatar
Drives: 2017 M240i
Would the dealership have any issues with this on a leased car?
      05-15-2017, 02:25 AM   #102
Almaretto
Almaretto's Avatar
2374
90% no. A small percentage yes. One problem is that certain functions people are enabling that come standard on other series or depending on vintage. Biggest issue is that they would have to prove you changed things that compromised some aspect of the vehicle.
      05-17-2017, 08:49 AM   #103
THEOS
THEOS's Avatar
19
Drives: M240i
Is the "M Performance" logo supposed to always show on the cluster similar to the "M240i" logo as seen above? Mine only shows when I get in before starting the ignition.
      05-17-2017, 09:43 AM   #104
BMWZ4
BMWZ4's Avatar
1907
Only comes up when the vehicle is started or shut off.
      05-17-2017, 04:54 PM   #105
Fasteddy1
Drives: 2017 M240i
Let me know what you did when you get that working. I have been wanting to do this as well.
Pat
      05-17-2017, 08:14 PM   #106
Preformman
Preformman's Avatar
Drives: M235I Convertible Astoril Blue
Any Warranty Issues Using BimmerCode?
Are there any warranty issues by using BimmerCode? In other words, will any warranties be voided by changing code? I understand that you may need to recode if you take it in for service and they have to perform a reset.
      05-19-2017, 06:39 PM   #107
MyMiniM3
Can you remove an engine code from a piggyback using the Bimmercode app?
      05-20-2017, 02:05 AM   #108
Vyruz Reaper
Reverse Homer
Vyruz Reaper's Avatar
Drives: ///M240i
Nope
      05-22-2017, 05:18 PM   #109
MyMiniM3
Any reason why I can't access advanced cash safety mode? Want to remove seatbelt ding.
      05-22-2017, 09:29 PM   #110
Vyruz Reaper
Reverse Homer
Drives: ///M240i
Few of us have the same problems. Probably a glitch in the app. The dev is on here forums, hopefully he sees this and fixes in the next release candidate build.
Search this Thread:
