2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Here you go, Curt 11367 hitch on M235
      02-05-2016, 11:26 AM   #23
cth6
cth6's Avatar
Drives: '16 M235i
Unfortunately the 11367 does not fit on a '16 M235i without a significant cut on the bumper. The bottom of the receiver is flush with the bottom of the bumper cover. So I would need to have some pretty significant cuts. Outside of that it fits well.
I did call curt and there is no way to cross reference a hitch that has similar mount points, but a dropped receiver. I am going to ask a local welder to see how much it will run to get the receiver dropped 1.9" and ideally pulled back toward the rear axel by .25" to hide it even further.
      02-06-2016, 09:38 PM   #24
horsepower_and_hounds
Drives: BMW
cth6, you should not have to cut anymore than I did out og your bumper insert. if you have the stock diffuser insert it might look a bit more drastic than mine since I have the performance diffuser insert but there is no difference between the 2014 & 2016. Someone correct me if i am wrong
      02-08-2016, 07:03 AM   #25
cth6
cth6's Avatar
Drives: '16 M235i
All of the '16s that I have seen at my dealer have the same bumper covers. They were all assembled post Nov '15. Mine was Dec 4th.
The picture is not the best, but the bottom line of the bumper cover is slightly above the bottom of the exhaust covers.
      02-08-2016, 07:50 PM   #26
Drives: BMW
All your installer will have to do is cut a slot out of the middle diffuser. Use my pic's as a reference....no custom hitch needed
      02-08-2016, 08:25 PM   #27
cth6
cth6's Avatar
Drives: '16 M235i
I think the issue is the difference in our rear diffusers. True, I could cut it out but the hitch would be recessed behind the hole in my bumper. I will run by the dealer tomorrow so I can get some measurements off of a 15 with a sport diffuser.
Not my car, but here is a good picture of how boxy and far out the diffuser is on my car. Too dark to take photos right now.
      02-09-2016, 04:56 PM   #28
Cyberdemon
Cyberdemon's Avatar
1538
Drives: 2020 X5 40i, 2018 M3 Comp
All of the bumpers are the same - so you should be able to cut it out of the bumper the same - not sure why it would be any different.
If you want to drop it further, you could most likely take it to a local machine shop, have them cut the two pieces of flat plate that hold the receive to the cross beam, and then have them weld extensions in place. It's obviously going to cost you more than a few snips of the bumper, but if you don't want the cutout it's a pretty easy job for anybody with some scraps of 1/4" plate and a welder.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette
      02-09-2016, 05:47 PM   #29
Tito44
Tito44's Avatar
Drives: 2015 BMW M235XI
I was planning on just buying the sport diffusor for this reason.
      02-09-2016, 07:07 PM   #30
Drives: BMW
If you look close at my pictures mine is recessed also..... "not a problem" just do it
      08-02-2016, 02:40 PM   #31
nszzya
Drive Different
nszzya's Avatar
Drives: '16 F15 '17 F87
If anyone is reading this thread and has installed this or any hitch on an M2, please post back your experience. Similarly, if anyone has knowledge regarding whether this hitch could be fitted to an M2, please post back here. Thanks!
'17 F87 M2 DCT / '16 F15 X5 X35i / '09 E82 135i 6MT*
'10 E70 X5 35d* / '05 E60 M5 SMG* / '01 E53 X5 4.4i* / '76 2002* | '70 2002*
*Gone
      08-17-2016, 10:01 PM   #32
snodgrass23
snodgrass23's Avatar
Drives: 2015 EB m235i
Thanks for posting, this is very helpful. I've been thinking of easy ways to get my motorcycle to the track. I think if I had a really small lightweight trailer, this would work well for occasional trips.
aFe Momentum Intake, Dinan springs
      09-04-2016, 09:24 PM   #33
voukephalas
Drives: m235xi Cabriolet
Another Curt install!
First, I would like to thank ehagerty for taking the plunge on this one. I finally ordered the hitch and had a local shop do the install while my vehicle was getting other work done (among more serious work, installed weather stripping mentioned here http://www.2addicts.com/forums/showthread.php?t=1200964 ). For this I especially thank ehagerty since I provided links to this thread to the shop to convince them to undertake the project.
The result looks very professional and, to me, completely stock. I plan to pick up a rack this week and have a new bike on order as well.
Notes: the shop elected not to cut the heat shield in case I wanted to remove the hitch later but I plan to ask them to go ahead and cut it to fit the next time I bring the car in.
The install was in conjunction with that of the performance diffuser, which "needs" the extended exhaust tips for the right look, OEM in either chrome or carbon fiber. I ordered the carbon fiber since I'm not keen on the chrome ones.
Edit: This is a 2016 convertible with all the sensors -no wiring was in the way and everything works. Might have to turn off parking sensors once a rack is attached to avoid the beeping.
Without further ado, photos:
      09-04-2016, 09:46 PM   #34
NEUE02
NEUE02's Avatar
267
Wow! Super clean install!
The Stable
      09-05-2016, 07:23 PM   #35
nszzya
Drive Different
nszzya's Avatar
Other than being more expensive and more difficult to obtain in the U.S., is there any reason why the BMW towbar (P/N 71606874227) would not fit on the M235i? I like the idea of the potentially stealthy install.
*Gone
      09-08-2016, 03:44 PM   #36
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
Wondering if this could work on the M2
?16 M2 Long Beach Blue/Black, 6MT
'22 X5 4.0 M Sport Black Sapphire/Tartufo
?22 Tesla Model Y Performance Midnight Silver/White
nszzya52.00
      09-12-2016, 03:53 PM   #37
mdputnam
mdputnam's Avatar
289
There is a small difference in ball sizes. Standard European ball size is 50 mm (1 31⁄32 in) here in the US 2 inches (50.8 mm) or 1 7⁄8 in (47.6 mm) is typical. I would guess 0.8mm does not make any difference for a 2 inch coupler. But, if your small trailer only had a coupler that fit a 1 7⁄8 in ball you would have to change it to the US standard 2 inches or European 50mm.
      09-16-2016, 11:11 AM   #38
nszzya
Drive Different
nszzya's Avatar
That's exactly what I was getting at.
*Gone
      10-10-2016, 08:47 AM   #39
Polo08816
Drives: 2014 335i M Sport
Ok folks, here it is. The Curt 11367 3/4 series hitch installed on the M235. I have accomplished this even retaining the underside heat shield. These pics are with the MPE and M diffuser.
One casualty suffered, the front r/h cover tab broke when I pulled on the cover. The l/h popped right out, the r/h just broke off.
Enjoy the show.....
1-Up rack pic's uploaded & with bike mounted
Originally Posted by Cyberdemon View Post
Thanks for being the first person to bite the bullet.
It does look like it sits much higher on the F2x vs the F3x - was hoping it would be a no trimming affair like the F30.
Either way, great to know it fits and for ~$150 it's a much nicer solution than the roof rack!
Originally Posted by gmorrell View Post
Hi, just wondering if you have had any problems since installing your hitch. I saw in a different forum that someone with a 1 series car had problems with the muffler rattling against their hitch when the exhaust system heated up, wondering if you have experienced this.
Here's the procedure from ISTAD Rheingold that may help in installing this hitch.
      10-10-2016, 12:26 PM   #40
nszzya
Drive Different
nszzya's Avatar
Here's the instructions for the BMW OEM hitch in case anyone decides to go that route.
*Gone
      11-27-2016, 11:16 PM   #41
MartyMcFly88MPH
Drives: M235ix
Figured I'd update this thread with my results.
I had the Curt hitch installed by a local company. They managed to do it without any trimming, but I'm not sure that's a good thing.
I seem to have a different style bumper than OP. You can see in the pics that the hitch pushes right up on the bumper. I mentioned it to the installer and they made it sound like no big deal. I'm thinking about bringing it back for trimming.
What say you fine folks?
      12-14-2016, 01:41 PM   #42
tubmw
Drives: Ordered M140i Mineral Gray
Question
All pics from tear down to bike carried have been uploaded for future interest
I had that problem with my 1 series..that was probably me. Zero issues so far with this installation
ehagerty,
Yes, Yes Yes, Fantastic !!!
*canīt believe I finally found a thread with exactly what I was looking for*
Just let me say I also love the look and convenience of my hitch racks and had almost given up hope on finding a way to fit one in my upcoming M140i. Loved your install and 1Up rack, however Im partial to this one myself ...
http://kuatracks.com/products/hitch/sherpatm-2-0/
... the black and chrome would look badass in a 2 series.
Now the hard part: As I mentioned, Im getting a new M140i early next year, and of course want to fit the Curt Tow Hitch so I can continue to use my hitch rack, or even perhaps get a new one in black.
Questions:
1. In your experience, do you think this same Hitch will fit the M140i? - the backend seems to share quite a bit with the 235/240 ... I heard you had an issue fitting a hitch to a M135i ... perhaps you know a way around it?
2. Any advice before I order the Tow Hitch and take your step by step to an installer?
For adapting the Curt Hitch referenced above would you say it is required to fit the MPerformance exhaust and/or Diffuser? I canīt really tell from the pictures, but it seems a bit smaller than the standard exhaust and I had the notion that it might help make room for the tow hitch.
I was looking around with the folks at etrailer with the same idea, but I was looking at the wrong hitch and the schematics didn't match so iīd given up. The folks there did point me the wrong way, I suppose itīs a good policy to recommend OEM approved installations first: http://www.etrailer.com/question-194852.html?fb=yes
If you can give me a few pointers with what to look out for in the install for the M140i Iīll go to my installer when I get my new car, and post the step by step in the M135/M140 forums.
Oh ... one final question ... does anyone have experience with upholding the warranty with BMW with this type of MOD ? In particular because there is no electric install and no real towing being done ... thoughts?
Thanks so much!
Last edited by tubmw; 12-14-2016 at 01:43 PM.. Reason: incorrectly wrote rack went I meant hitch
      12-16-2016, 07:27 PM   #43
Drives: BMW
See in red below
Originally Posted by tubmw View Post
ehagerty,
Questions:
I feel it should based on the fact that the same hitch is marketed for the 2 series, 3 series and 4 series. I think all of the smaller platforms are using the same mount spacing in the rear but I have no facts....I just bought it and gave it a shot on both the M235i and then my M4
Just buy it and go....very limited investment in my opinion if it does not work. You have more to gain than loose
Nope live everything just where it is....I took the time to cut and fit the heat shielding just in case it gets really hot back there but the hitch blocks a lot of the heat
They are not so smart and gave me a lot of bum information....that is why I ventured out on my own
Just be careful pulling off the bumper so you don't break the tabs like i did in the corners
Warranty is not effected.....they never questioned mine in 1.5 yrs I had it.
Thanks so much!
      01-14-2017, 11:35 AM   #44
hoppy6698
hoppy6698's Avatar
Drives: M235i, Estoril Blue on Black
Thanks to OP and followers for this thread! Will totally address my bicycle issue and I am hoping to tow a small trailer. Lighting kits aside, has anyone used this for a class 1 trailer? I just need something big enough for track wheel sets or kayak fishing trips.
Tags
bmw 2 series tow hitch
