2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Base (Not HiFi or H&K speakers) amp optios
      03-28-2020, 10:12 PM   #1
NickB235i
Drives: BMW M235i
I have ordered the Eton and JL audio front and rear speakers + the tweeter covers to fit to my BASE UK (not HiFi or H&K) speakers.
I'm concerned I won't be able to power them as I'm fairly sure I don't have an amp in the base system.
Can someone confirm if I can power them without issue.
If I can't, can someone recommend a cost effective amp and I am already essentially at my budget, and also how I can fit this amp?
      03-28-2020, 10:15 PM   #2
NickB235i
Drives: BMW M235i
I have just thought, would it be an option to add a H&K amp if I can find one cheap? Would that be possible?
      03-29-2020, 11:34 AM   #3
MarcoZandrini
Drives: 2018 M240i
Nick, the amp is likely located in the head unit. If the speakers currently work then the new speakers will work.
      03-29-2020, 11:38 AM   #4
NickB235i
Drives: BMW M235i
Concerned the standard head unit won't have enough power to power the new ones and it might result in them being very quiet, is that not the case?
      03-31-2020, 03:46 PM   #5
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
You may have a better option (and easier install) of aftermarket amps if there is an ASD module in your F22.
      03-31-2020, 03:47 PM   #6
NickB235i
Drives: BMW M235i
Can you install an amp directly from the ASD module with a Technic harness?
      03-31-2020, 05:38 PM   #7
Encanto
Encanto's Avatar
It can be done, the wiring that you need to install an aftermarket amp is in there. No need to remove the OEM HU to get the input and output signals. The remote out wire is even in the ASD connector.
