2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics How to install a dash cam(Best way)
      03-28-2020, 07:18 AM   #1
K1ogk
Drives: BMW M235i
Hi, has anyone fitted a dashcam to a 235i at all? Wheres the best way to run the cable etc.. and is the fuse box under the bonnet?
      04-05-2020, 03:42 PM   #2
keylime503
Drives: M2C 6MT, Audi A4 Avant
I have a blacksys CH100B hardwired to the front fuse box under the hood for parking mode. Getting the wire through the firewall was a pain but once I got everything setup it's been working perfectly for 2 years now.
      04-06-2020, 08:13 AM   #3
KennyFSU
KennyFSU's Avatar
1104
Drives: Lexus RC F
I have the Garmin 55 and was able to route the cord from the cam (mounted near the rearview mirror), tucked under the headliner, down the A-pillar, under the kick panels, under the rear seat, and then plugged into the trunk plug. All wiring is hidden and easily removable.
Estoril Blue E36M3
Mineral Grey M235ix/12.02 @ 115
Ultra White Lexus RC F
      04-06-2020, 02:21 PM   #4
sandrik93
Drives: '23 M240i RWD
https://www.2addicts.com/forums/show....php?t=1378410
Here's a thread with discussion and a very nice video. I need to wire my Thinkware as well, but since all the stay-at-home situation, I've been putting it off.
      04-11-2020, 07:22 PM   #5
BimBimM2
Drives: M240xi 'Vert
The best way to do this is to not touch your car's wiring. Period.
Run a Cellink battery from the 12v socket in the boot. Wire the dash cam to that battery. Perfect parking mode!
Super simple. None of that piggybacking or splicing cables shit.
      04-12-2020, 05:23 AM   #6
overcoil
Drives: M235i 6spd
My Owl dash cam plugs into the obd-II socket.
Been using it for two or three years with no issues.
      04-14-2020, 08:04 PM   #7
DrEgon
Drives: 2015 BMW M235i
I vote for this also.
      04-29-2020, 10:44 PM   #8
personinma
Sleepy
Drives: 14 Mazda3 sGT, 18 Audi S5 SB
This might be a dumb as hell question, but what do you mean by 12v socket in the boot? I'm trying to figure out the easiest way to wire my blackvue 2 channel also.
      04-29-2020, 11:52 PM   #9
BimBimM2
Oh no! Not a dumb question at all. Took me a while to find one of those as well.
So it is going to be on the left hand side. Here is a picture of mine.
shadowfax1289.00
      04-30-2020, 09:36 AM   #10
personinma
Sleepy
YO, that's so tight!!!! Wow, cannot believe I never actually looked under that little cover before. Thanks a bunch! Definitely gonna make use of that socket
      04-30-2020, 01:25 PM   #11
4Hockey4
Drives: Pinto
Just started looking into and have 247 questions lol
Was looking at Nextbase 522 and Garmin.
1) Can you order set wires to run like KennyDSU did ?
2) How long can you tape on a 128GB card ?
I'd like to set up and let it run, and only save/pull as necc. Is that auto or are you constantly having to save,delete/remove to leave enough room on card ? (or does it record and if you DON"T save after drive, cam will delete, is that based on turning car off ? )
Sorry odd/basic questions, but don't want to have to mess with everytime I drive my car...but would like to record some light track time and of course if ever an incident.
Cheers
      05-04-2020, 09:09 PM   #12
4Hockey4
Drives: Pinto
Ordered NextBase522, BestBuy just dropped to $209, down $50. Can you just wire to fuse box ? Do 2's require a low profile mini connection ?
Anyone ever use this set up ?
https://www.bestbuy.com/site/hardwir...?skuId=6346999
Thx
      05-04-2020, 11:33 PM   #13
BimBimM2
Thx
Hey there, does this camera have parking mode?
Also, I am especially shy about touching electronics/electricals in BMWs... why not get a battery and run it off that?
      05-05-2020, 06:46 AM   #14
4Hockey4
Drives: Pinto
Yes, I read through all the Best Buy questions, from SD card to hook up etc.
Do you put the battery in glove box ? What size and connection ?
That's not all, however, the 522GW also packs an 'Intelligent Parking Mode' that records any bump or physical movement on the vehicle when left unattended.
I wouldn't mind running to drunk hook up, guess you have to splice your own wire(s) and connections ?
Would note this is a UK product....but reviews all pretty good in US
Here's review:
      05-07-2020, 03:42 PM   #15
sandrik93
Cellink battery is 300 bucks.
And plugging into the car one is free (minus wire and time cost).
Wired mine just like the video link I posted earlier (a little different cabin wiring path). Works like a charm..
      05-07-2020, 03:46 PM   #16
sandrik93
Thx
Depends on which fuse you use. 5amp fuse #147 (for radio, that I tapped into) is a 5 amp mini fuse. Not low profile.
this one:
https://www.amazon.com/Bussmann-Amp-.../dp/B0024JT7TU
      05-07-2020, 04:35 PM   #17
BimBimM2
I agree. Cellink is expensive but I hate playing with these touchy BMW batteries. If you go to dashcamtalk forums it is ALWAYS some dude in a BMW complaining about his camera not detecting voltages right and running down the battery
      05-08-2020, 08:46 AM   #18
sandrik93
Yeah, I've seen a bunch of those. That's why the battery connection is direct and not fuse-tapped as well. blackboxmycar recommended a battery for BMW as well. But then again, I took the risk and so far it works. I did have to solder though, just like in the video.
