01-08-2015, 10:37 AM | #45 |
Rep 1,091
Thanks, and no bad feelings
previous: 2003 E46 330i SMG
01-08-2015, 11:40 AM | #46 |
Rep 36
01-08-2015, 11:50 AM | #47 |
Rep 1,091
If only I get some positive info I'll share it here, no worries. But frankly, with so little experience with things like LSD here, BMW may be unable to help without escalating the thing higher (to the AG)....
01-09-2015, 04:30 AM | #48 |
Rep 1,091
Actually I learn the answer I got on another forum (that eDiff is *only* active with DSC OFF) turns to be true! This means it should be seen not as another electronic "nanny", but a replacement to a "real" LSD in e.g. track drifting where the driver can safely switch off DSC.
But assuming LSD actually *needs* some wheelspin (or difference in left/right wheel spins) to kick in, my question is still valid: - will LSD be used efficiently in DSC ON driving scenario? - won't DSC stability control action (engine power taming/one or more of all 4 wheels braking) prevent LSD from being efficiently used? I hope that the amount of wheelspin as allowed by DTC (before full DSC kicks in) will be sufficient for LSD to work, but this is now my main question...
01-09-2015, 05:43 AM | #49 | |
Rep 1,091
1. eDiff (eLSD) only works with DSC off, so it's a fake LSD for those drifting on a track, where turning DSC off is appropriate 2. When on public road, we usually don't want to switch DSC off, so we're left without any LSD - until we add the M-P LSD. Why did I stress M-Performance (i.e. the one we're discussing here)? Well, because unlike e.g. viscous units, the clutch pack units (BMW Performance LSD) and TorSen (Quaife) are activated by torque differences (this is why I bolded this fragment out in your quote), and not wheelspin difference; also they will usually react sooner than the car electronics So, DSC ON should not - within reasonable limits - prevent the M-P LSD from efficiently putting more torque to the pavement! This conclusion - although still unconfirmed in 100% by BMW, which was to be expected - effectively ends my little "research" - I'd like to thank all of you for your input (including those in similar threads of mine on the other fora). I for one am definitely adding M-P LSD to my M235i !
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD Last edited by moldcad; 01-09-2015 at 08:55 AM.. |
01-09-2015, 09:35 AM | #50 |
Rep 1,066
FYI for the OP. The roads are CRAPPY here today and I don't have the LSD yet (I get it on the 20th). No problems at all. the e-diff/DSC works great in the snow, slush, ice, and random slippery crap on the roads today. LSD is not needed for slippery weather, it is only needed for top performance.
01-09-2015, 12:43 PM | #52 | |
Rep 5,262
what i don't quite get is that if both wheels are not slipping then the torque sent to each of them should be the same no? hence the answer from one of the admins that went to the pref even in LV "A mechanical LSD is always 'on'. It is a mechanical locking device. However, with DSC engaged, your inside wheel slip will be curbed much sooner by the DSC braking the individual inside wheel, well before it has had enough slip to engage the LSD. The LSD is always on, but can't be felt until you turn off DSC. Otherwise, DSC will interrupt your power well before the LSD even has a chance to take hold." |
01-09-2015, 01:00 PM | #53 |
Rep 5,262
2 interesting threads
http://www.bimmerfest.com/forums/sho...88&postcount=5 http://forum.miata.net/vb/showthread.php?t=233722 "Yes, in theory you can have the LSD working with the DSC/TSC on. As said before the LSD is a mechanical device that maximizes the available grip you can put power to. i.e. if your turning into a corner and apply power, your inside wheel will not have much grip since it's unloaded to put power. If you have an open differential, that inside tire will break loose spin and all the power diverted to the inside wheel that doesn't have grip, while the outside tire which has available grip doesn't get the power. LSD enables the torque to be applied more to the outside wheel rather than the inside wheel, hence giving you more accelleration out of the corner. In the same scenario if you apply so much power with the LSD such that your outside tire starts to slip and your powersliding, your DSC and TSC will kick in decreasing your throttle and applying brakes to certain corners such that you don't spin out of control and maintain the direction your intended on going." |
01-09-2015, 01:15 PM | #54 | |
Rep 1,091
01-09-2015, 01:23 PM | #55 |
Rep 36
IIRC the DSC is triggered by accelerometers in the car, steering wheel position, and wheel speed sensors which are interpreted by the computer which decides that "you are in an understeer or oversteer" situation and brakes individual wheels/cuts engine power to get you back in control.
The mystery to me is does the LSD have a lower threshold of activation than the e diff? If you are theoretically going straight (no over or under steer going on) and one of the rear wheels hit a slippery patch of pavement (ice, snow, sand, gravel, lard etc.) while accelerating (as in overtaking) which kicks-in first, the LSD or the e-diff? Anybody have any experience in trying this scenario? BTW, I think e-diff is always on regardless of what setting you have on. |
01-09-2015, 01:32 PM | #56 | |
Rep 1,091
- eDiff only works when DSC is OFF - clutch-pack mechanical LSD like M-Performance one is torque-sensitive not wheel-slip speed sensitive You will find your answer...
01-09-2015, 01:33 PM | #57 | |
Rep 1,066
So we are now splitting hairs, but I can say that I have done both today. ON and OFF. In the ON setting the car has no problems getting started and keeping things straight. This is in near worst case conditions on the road. With it OFF (in a parking lot) it is a lot of fun. The e-diff only working lets you have fun and you can feel it working. It is quite good. Back to the OP's original question. No you don't need a LSD to address bad roads in the winter. The car will address that without the LSD. |
01-09-2015, 02:45 PM | #58 | |
Rep 36
an e-diff system operates using the ABS sensors and the ABS system to control wheelspin AND so does the DSC (although it uses other inputs too and then the computer decides which wheels to brake and when to cut engine power) in an unstable situation. If you think of it, what scenario would you like the e-diff to be OFF, if you do not have a LSD? There is NO situation as a auto enthusiast would you want this (except doing inefficient one-wheel-burnouts) because now you have a open differential and if the DSC software/hardware is not sophisticated enough to maintain DSC functionality, then NO DSC. Which is why I think that my BMW dealership in my location WOULD NOT turn off the e-diff when I was looking at a 135 coupe some years ago that I wanted to put an aftermarket LSD (liability concerns?). You can however turn-off DSC and still have the benefit of the e-diff (acting as a LSD). There are lots of types of LSDs and if the M-Perf LSD option on the M235i is a clutch pack then it does not operate by being torque sensitive (Torsen differential but friction is still involved). |
01-09-2015, 04:53 PM | #59 |
Rep 199
BMW just explained how it works in M Perf diff press release : http://www.2addicts.com/forums/showthread.php?t=982939
01-09-2015, 07:47 PM | #60 |
Rep 891
I come from a background of U.S. V8 manual RWD cars - Mustangs, Corvette, Camaro - all of which come with a mechanical LSD standard, aka "posi" rear end. So I have no experience with an e-Diff, and to be honest, am somewhat concerned about it since I track my car once per year or so.
For the record, I don't do burnouts, though I will shift hard into 2nd gear occasionally with my Mustang just to break the rear loose. Even with the Traction Control on, this will always leave two fat tire patches on the road, 10 feet long or so. (With TC off, the patches are much longer than 10 feet.) My question is about the e-Diff in the M235i. If you do a burnout, will it leave two tire patches or one? Does it matter if you are in Comfort, Sport, or Sport+ mode?
Previous: 2018 Camaro 2SS 1LE 6MT; 2015 BMW M235i 6MT; 2015 Mini Cooper F56 6MT; 2005 Mustang GT 5MT; 2003 Mini Cooper R50 5MT |
01-09-2015, 08:13 PM | #61 |
Rep 1,066
Two. And that is in sport+ or DSC off. In the others, the nanny systems will stop it too quickly.
01-09-2015, 08:23 PM | #62 |
Rep 891
It won't do a burnout at all in Sport mode?
01-09-2015, 09:50 PM | #64 | |
Rep 36
01-10-2015, 05:31 AM | #65 | |
Rep 1,091
"The unit reacts instantaneously to torque variances in the half-shafts. As such, the responsiveness of the unit operates before DSC has an opportunity to respond, thus no operational interference with the aforementioned "driving aids". So - depending how close is the above design intent to real-life behavior, there is no reason why a non-tracking M235i owner should not be able to take full advantage of M-P LSD, even if he mostly drives with DSC ON.
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD Last edited by moldcad; 01-10-2015 at 08:24 AM.. |
01-10-2015, 06:47 AM | #66 |
Rep 199
Yes I think that you have the point .
I've ask my local dealer a price quote for the M Performance LSD. First they announced me 2834€ (excl VAT) retail price... I found it at 2413€ (excl VAT) in Germany. In the meantime I found ETK 12/2014 prices for M Performance Differential 33107555610: 33107555610000002567.23000000000.0016%* 1 000002156.470EUR So 2156.47€ (excl VAT) corresponds to ~2560 USD, price generally observed in the US... |
