2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes m4 tension struts to go with lcas
      06-21-2016, 01:45 AM   #89
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Q
Bore is to suit m12
BP
      06-21-2016, 03:03 AM   #90
quenotte
France
60
Drives: F87N M2 Competition
I've edited to make it clearer.
      06-23-2016, 03:45 PM   #91
racerstf
Can anyone recommend a good shop to do my alignment after installing the LCA's and TS?
I am located in Orange county.
      06-24-2016, 05:34 PM   #92
mdputnam
mdputnam's Avatar
289
Try European Auto Source (714)369-8524
      06-25-2016, 01:40 AM   #93
racerstf
Thanks, I did more research and found west end. I will most likely go with them or EAS.
      06-30-2016, 01:37 PM   #94
Le frog
MRF Engineering in Lake Forest
http://www.mrfengineering.com/
Malek specializes in BMW, and he is great to work with
      07-04-2016, 08:57 AM   #95
Pparana
Drives: 2015 m235i
I finally got to one of the local tracks (firm in starve fl) ts feel great, turn in is better, more sharp. Steering is less vague. I even dialed out some camber. Tire wear was great.
Grassroots motorsports runs a 235i magazine car there. They are down to 1.27 times with motion control suspension, a tune and some other items. It is a brutal track on the cars brakes, and tires, lots of turns. If your car feels good here, your set up well. I was turning low 1.24s, think there may be a mid 1.22 with subframe and diff bushings upgrades next.
Bottom line is the car is getting pretty close to prepped race car times, with still being a streetable car.
Appreciate 4
      08-05-2016, 12:17 PM   #96
allthatisntnow
allthatisntnow's Avatar
United Kingdom
377
Drives: BMW M2C, 991 C2
Some great info here guys. Just pulled the trigger on the LCAs and Tension Struts myself. Also getting some of the Vorshlag camber plates to accompany. Will report back with how things go. Does anyone know the torque specs for the tension struts per chance?
I found the LCA specs in another thread:
Lower control arms to knuckle 122 ftlb (165 Nm)
Lower control arms to subframe 74 ftlb (100 Nm)
Is it just the same?
      08-05-2016, 12:22 PM   #97
Pparana
Drives: 2015 m235i
I have a manual at work, will check the specs. Subframe may be higher on ts.
      08-05-2016, 09:59 PM   #98
ICTZHP
ICTZHP's Avatar
25
Drives: E92 M3 and G06 X6
The LCA's and tension struts have the same torque specs. The bolts to the subframe are one use stretch bolts. The spec is 74 ft-lbs +90 degrees. The nuts for the ball joints are also supposed to be one use as well. I was more concerned with replacing the stretch bolts than the nuts. Oh, the knuckle torque sounds about right, I know it was 120 something ft-lbs, the exact value escapes me.
Hope this helps!
      08-07-2016, 07:39 AM   #99
allthatisntnow
United Kingdom
377
Hope this helps!
Thanks!
So its:
31106797237 hex screw with collar for LCA to subframe
31106795930 hex screw with flange for tension strut to subframe
33306787062 combi nut x2 (optional, but advisable)
from what i can gather on real oem
cxp213313.00
      08-07-2016, 08:59 PM   #100
ICTZHP
ICTZHP's Avatar
25
Thanks!
So its:
Yes, those are the nuts and bolts that I was referring to. Good luck!
      09-02-2016, 07:25 PM   #101
DVC
Diligentia Vis Celeritas
DVC's Avatar
Drives: 335i
Originally Posted by rwalker View Post
I'm about to install these... Pparana, any last words?
spacers from Summit Racing:
http://www.summitracing.com/parts/KYS-100-377-3
http://www.summitracing.com/parts/KYS-100-377-1
tension struts from ECS Tuning:
https://www.ecstuning.com/ES2767705/
https://www.ecstuning.com/ES2767682/
How are the F8x TSs + LCAs working out? Any issues, or do you still think that this setup (with the spacers) is solid and robust for road and track use?
And for spacers, you still recommend:
Thickness: 0.25" outer / 0.50" inner
I.D.: 0.50"
O.D.: 1.50" (thought I read elsewhere in the thread that 1.00" O.D. was used)
      09-02-2016, 07:29 PM   #102
rwalker
Drives: the wheels off
working well
no issues, is great for road and track
Thickness: 0.25" inner / 0.50" outer
I.D.: 0.50"
I used the parts listed in my post above, they fit perfectly, 1.5" OD
DVC558.00
      09-02-2016, 07:33 PM   #103
DVC
DVC's Avatar
Drives: 335i
working wellno issues, is great for road and trackI used the parts listed in my post above, they fit perfectly, 1.5" OD
Awesome...I think I'm gonna give this a go.
So you recommend the 1.5" OD over the 1.0" OD, right?
      09-03-2016, 08:08 AM   #104
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Spacer od of 1.25" or 30mm will match TS Bush OD.
      09-03-2016, 09:13 AM   #105
m3cmm
m3cmm's Avatar
55
Drives: 2016 M235i
I have the Dinan monoball kit. Any chance this will fit with the F8x TS?
I'm going to assume not given they have a different part for the F8x, but maybe just different spacers?
The F22 kit has 5 bolts.
F22 - http://www.dinancars.com/product/d28...ries&mid=1183/
F8x - http://www.dinancars.com/product/d28...ries&mid=1178/
DVC558.00
      09-03-2016, 11:09 AM   #106
DVC
DVC's Avatar
Drives: 335i
Interesting...so you went with 1.25"/30mm OD?
It seems people have had success with a range of ODs from 1.00" - 1.50" ... From those with experience from having installed them, is there an ideal OD, or is anything in the range equally effective?
      09-03-2016, 11:43 AM   #107
rwalker
some installation photos
DVC558.00
cxp213313.00
      09-04-2016, 07:03 AM   #108
allthatisntnow
United Kingdom
377
Mine are actually marginally smaller OD than the TS bush OD by about 1mm. All i could source at the time. There're stainless steel so material is more than robust enough for the purpose they're serving and stresses placed upon them are minimal in comparison to what the bolt is under. Mine are getting installed on the 6th Sept so will post if any issues are encountered (which i highly doubt they will).
      09-04-2016, 02:25 PM   #109
DVC
DVC's Avatar
Drives: 335i
The TS bushings are aluminum, right? Any reason you went with stainless rather than aluminum for the spacers?
I was thinking if there was any wear point between the TS, spacers and mounting point, worn spacers would be the easiest/cheapest fix... As long as they don't wear to the point of failure!
What's the consensus on stainless steel versus aluminum?
      09-04-2016, 04:27 PM   #110
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
The mating face on the subframe is steel so I went with SS spacers so as the interface to oem bush is the same.
Current '22 X3M LCI..
DVC558.00
