06-16-2019, 02:47 PM | #1 |
Rep 225
Tail light condensation - another one
OK, so I have the tail light condensation too. Seems to be a common problem. Brought to the dealer, and was told it was likely my aftermarket sub on the left side that damaged the seals on the left light. Whatever. Anyone else get told this? Have so say I was a bit shocked as it seems to be a common problem. Perhaps not where I go. Anyway both are leaking, but only one showed the condensation so they are only changing one. Bottom line is if you have this and your car is under warranty and you have this make sure the dealer sees it as they need evidence for BMW to change under warranty.
18 340i F30 mostly stock |
06-17-2019, 07:37 AM | #2 |
E4 Mafia
323
Rep 412
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
sounds like they are just trying to pass the buck. especially since the tail light is completely on the outside of the car and not accessible from the inside. they think the sub rattled out the seal?!?! that'd be a crap seal then! I'd keep fighting with them.
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
06-17-2019, 11:12 PM | #3 |
Rep 225
Well they said they would replace one but not the other since it didn't show any condensation. My fault for not bringing it in when it was present. Guess my laziness paid off . Still thought the excuse was silly as there seem to be a number of these on the forum.
06-21-2019, 05:01 PM | #4 |
Rep 558
i had the passenger side replaced a few months ago under warranty and just had the drivers side replaced yesterday, also under warranty.
Both for water in the reverse light lens. Both were dry when I brought it to the dealer, but I took pictures when they were wet and sent the pictures to my SA. Apparently that was enough for warranty.
06-21-2019, 10:47 PM | #5 |
Rep 197
I had a new one installed 2 months ago. Also have condensation now. Service advisor said there is a service bulletin from BMW regarding the wiring installation process, causing condensation issues.
BMW is going to repair it free of cost. I am not under warranty but I assume the job is. |
06-15-2020, 07:35 PM | #6 |
Rep 40
Reviving this thread to add some info.
Back in January I brought my 2016 F22 in to the dealership for condensation in the taillights. No warranty left on the vehicle and they charged me a little over $700. Yeah, should have just bought the LCI tail lights but what's done is done. Anyway, went to www.bmw-rp.com and punched in my vin to find there was an extended warranty for tail lights so I submitted my bill for reimbursement. The worst they could say was no. After 6 months of absolutely nothing from BMW, I got a reimbursement check in the mail today for the full amount. If you're having a condensation problem (or perhaps any problem for that matter) with your tail lights, check out www.bmw-rp.com. You might be able to get reimbursement for the work, albeit 6 months later. Hope this helps someone. |
06-16-2020, 12:44 AM | #7 | |
Rep 225
06-16-2020, 12:19 PM | #8 | |
Rep 243
I only say this because my lights would not get "foggy" right when you blasted it with water. Rather, it was not until about 30-60 minutes after I washed the car that all the moisture would start building up inside. Anyway, I got both lights replaced under warranty but they first came back saying no moisture was present after hosing it down. They inspected again later in the day and sure enough, moisture was present in both sides. |
