2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) I think I found the best wheel brush
      03-01-2019, 12:20 PM   #1
vancitymike
Drives: 2015 M235i xDrive
well I didn't do any testing or anything - but I purchased it on the recommendation from Obsessed Garage (I purchased it in Canada through Auto Obsessed) its the EZ Detail or Speedmaster wheel brush - it takes practice to stay clean while using it, but it does the best job for any single tool. Especially for the top and behind the caliper, and it will clean that inner lip where everything accumulates. No more wheel woolies or cleaning the lip by hand with a cloth
      03-01-2019, 01:05 PM   #2
overcoil
Drives: M235i 6spd
is this the brush ?
      03-01-2019, 04:58 PM   #3
vancitymike
Originally Posted by ScottSinger View Post
is this the brush ?
yup - I got the mini, I may get the larger one too someday
      03-01-2019, 08:13 PM   #4
xantdieselx
Kingslayer
xantdieselx's Avatar
No_Country
411
Drives: 23' M3 Base
Agreed. I haven't picked up a wheel wooly since I bought the Speedmaster brush. Really does a great job just make sure you're far enough away when using it (or wear some clothes you don't care about).
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      03-04-2019, 02:29 PM   #5
35mmSummicron
Drives: F30
100% First time I used this brush I found myself covered in spray from wheel brake dust/cleaner
Originally Posted by xantdieselx View Post
...just make sure you're far enough away when using it (or wear some clothes you don't care about).
      05-10-2019, 08:55 PM   #6
John in VA
Drives: 2015 228i M Sport
That's why I wear a black T-shirt when going this job!
      05-11-2019, 08:22 AM   #7
Alpine2
Drives: '15 M235i (AW), '12 E70 (AW)
Didn't take this into consideration, glad someone mentioned it.
I always end up ruining clothing working on cars
      05-16-2019, 11:25 AM   #8
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
Pull out slow. LOL. It is one of the best wheel brushes on the planet. Make sure you wear some shades because the last thing you need is dirty wheel cleaner chemicals in your eye.
78' Honda CB400A project
      07-29-2019, 10:21 PM   #9
cyclingismylife
cyclingismylife's Avatar
Drives: BMW M240i
Just bought one myself and love it!
      02-28-2020, 12:46 AM   #10
DannyM235
DannyM235's Avatar
Drives: BMW F22 M235i
Been using the EZ- detail brush for years it works great but the splash back is bad sometimes. Try wheel woolies you won't get dirty at all and they also work just as well or better. I have the set of 3 a large, medium and small.
https://www.autogeek.net/wheel-woolies.html
      04-03-2020, 07:52 PM   #11
ggggbmw
Drives: 2017 M2 Manual
I'm using a set of Griot woolies similar to the ones DannyM235 listed. I also have a brush like the one vancitymike posted.
I greatly prefer the woolies. The brush splatters everything all over the place. The small woolies are also way better at getting in between the caliper and the wheel rim, and for poking at the recesses of the caliper itself. The larger woolie with a long handle is good for cleaning the barrel. And unlike the brush, as you work it back and forth on the barrel it's not splattering you as the brush pops between the wheel spokes.
      04-10-2020, 07:27 PM   #12
The_otherM235i
Driver - Autocross
The_otherM235i's Avatar
Drives: BMW M235i
I use a paintbrush to clean my wheels, Then i use a harder Simonz wheel brush with some autoglym magma to get rid of the iron. works well!
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
      04-12-2020, 07:26 PM   #13
Maynard
Drives: 228iX & M2C
For me brushes don't work as well as woolies, or a rag on the finger, at least for brake dust and regular dirt. Sometimes brushes are better for really tough crud, like the pre-storage cleanup of those backside nooks.
      06-13-2020, 09:06 PM   #14
dradernh
dradernh's Avatar
4393
Drives: 2017 M240i
To loosen as much of the outer layer of my DTC-70 race pads' dust as possible, I use the Carrand 92010 Grip Tech Deluxe Wheel Brush:
Following that, I use the Griot's Garage 15220 Wheel Scrubber Brush to remove the remaining, firmly-attached race pad dust. Due to the design of the 436M wheels, this one requires a fair amount of elbow grease using thumb and first two fingers. These wheels were not designed to be easy to clean.
After cleaning and drying I use Sonax Wheel Rim Shield to ensure the wheels will be reasonably easy to clean the next time. This product is the best I've found so far, but it's far from allowing the easy removal of race pad dust.
Maynard3848.00
      06-19-2020, 09:30 PM   #15
Rollo`
Drives: 2018 230i
+1 for the speedbrush, been using it for years and find it to be excellent
