Please Post M Performance Carbon Fiber Interior Photos!!! |
10-27-2018, 09:37 PM | #45 |
Rep 1,241
@ kuhleen
It looks like the very top plug can pull out, leaving the rest of the connectors and wires attached to the climate vents. Look at how that very top plug is clipped in and use a tiny flathead screwdriver to release whatever clips are keeping it secured. Then you can take the whole assembly with the vents and wires inside and take your time unclipping the vents from the surrounding trim. You can do it!
CP911
10-29-2018, 06:58 AM | #46 |
FakeM2
246
Rep 280
I used a small flat head to very carefully work once side out, top or bottom and once it was free they just slid out
2017 M240I / M Performance Exhaust / Dinan Midpipe / Dinan CAI/ Akrapovic Downpipe / Dinan Stage 1 / Dinmann Front Splitter / Dinmann Rear Diffuser / M-Performance Steering Wheel / M-Performance Carbon & Alcantara Interior
04-18-2019, 11:27 PM | #47 |
Rep 11
Where did you find a lci trim radio kit for your car? I'm only seeing 3 and 4 series models only
06-11-2019, 10:03 PM | #48 |
Rep 26
Anyone else notice a significant gap when installing the door handles? On the top corner that faces you (passenger or driver). It was a slight pet peeve, but not that big of a deal initially. However, when the temperatures rise, that corner actually pops out. I've tried adjusting to see if it's not full clipped in, but that hasn't made any positive difference.
06-12-2019, 11:57 AM | #49 | |
Rep 5,369
I had the same issue with my driver's side handle cover. The gap was slightly open and when it was warm out, cover would pop loose when I'd grab the handle to close the door. After numerous attempted reinstalls, it turns out that I wasn't quite getting all the small leading edge tabs of the cover to seat fully, thus the larger tabs could not fully grab and clip in. It's hard to explain in a post, but all I can say is you need to make sure everything is seating, especially on the cover edge where your palm/thumb would contact the cover. That's where I was having the issue. Once I figured out how to seat the cover fully, the gap is gone and it's never pop out since.
06-12-2019, 01:06 PM | #50 | |
Rep 1,227
06-13-2019, 01:23 AM | #51 | |
Rep 26
06-13-2019, 11:33 AM | #52 |
Rep 5,369
Nope. You guys haven't seated the leading edge clips on the cover. I'm talking about the tiny clips and ridges along the perimeter of the cover. You may also need to make sure the attachment points on the door handles haven't bent, thus not grabbing the cover tabs.
06-13-2019, 12:10 PM | #53 | |
Rep 1,227
06-13-2019, 05:12 PM | #54 | |
Rep 26
Thanks in advance! |
06-17-2019, 12:26 PM | #56 |
Rep 1,227
The interior trim layout changed with the cosmetic LCI for MY18.
06-18-2019, 05:02 PM | #57 | |
Rep 5,369
06-20-2019, 09:34 PM | #58 |
Rep 26
07-22-2020, 09:53 PM | #60 |
Rep 32
11-22-2020, 05:05 PM | #61 | |
Rep 32
They were not in stock, but ordered via facebook. |
01-01-2021, 08:04 PM | #62 |
Rep 91
Drives: 2020 X5; 2016 M235i Conv. 6MT
Is this still available to get for the F23? I can only find for F22.
01-01-2021, 09:24 PM | #63 | ||
Rep 506
You can order the individual pieces including the center console piece for the convertible or get the non convertible pre LCI set and then also purchase the center console piece. 51-16-8-088-622 Cover Center Console Carbon
E46 -> E90 -> F30 -> F23
01-04-2021, 08:06 PM | #65 |
Rep 120
01-04-2021, 09:54 PM | #66 |
Rep 140
