04-22-2014, 06:32 PM | #1 |
Rep 178
Squeaky brakes at very low speeds
Hey guys, something that's been bugging me since I got the new car.. (235)... and I usually only notice this at a drive through where you're moving very slowly and then stopping again (such as in a line of cars) - the brakes squeak. I've had the car about a month and there's 1200 miles on it. I never hear this at higher speeds or with harder braking.. Just soft braking during slow start/stops. Is this normal?
JB
2020 M2 Comp. / Hockenheim Silver / DCT / Executive / Moonroof
04-22-2014, 06:37 PM | #2 |
Rep 863
Drives: '19 M2 '21 X5
I had it. It passed.
Just a factor of high performance brakes. Any car that I have had with good brakes did it. M6. Cls550. If you want it to go away fast do a 60-0 run : P |
04-22-2014, 07:41 PM | #3 | |
Rep 178
04-23-2014, 04:40 AM | #6 |
Rep 1,002
Same thing on my 435i.... Quite embarrassing! Dealer said to bring it in, but I'm always wary of taking it in for niggles like this as they usually end up breaking more than fixing.
04-23-2014, 07:37 AM | #7 |
Rep 1,053
It's a bmw. Brake squeaks will haunt you in your sleep. I took my e90 in so many times during the warranty and they kept replacing all parts until it stopped. Then get another set of brakes later on and squeaking returns. At a certain point you will just give up! The stock brakes suck.
04-23-2014, 08:52 AM | #8 |
Rep 349
I reported this at ~1700 miles to my local bmw service and they said it's just a product of the humid air in the south. Huh? Crazy, but I've gone through a couple hard breaking sessions and it's less apparent now, although it does still happen.
04-23-2014, 09:55 AM | #9 | |
Rep 1,254
This happens with race pads on my other car. But I don't think the M235i or 135i comes with race pads. Maybe pull the pads put some quiet gel on them to help silent the low speed squeaks.
04-23-2014, 11:42 AM | #10 |
Rep 178
This is my 3rd bmw (2002 330ci, 2012 135i), and I never had this issue before. I'll try the bedding process...
JB
04-26-2014, 05:23 PM | #11 |
Rep 176
I have some noise with the brakes too. It's not a squeaking but rather one short clonk when I press gently the pedal brake. It happens mostly when I'm maneuvering to park. I think the noise is coming when the brake pads clamp the front rotors. Do you have this noise too?
04-28-2014, 06:27 PM | #14 |
***** noob
1402
Rep 10,477
The 235 front and back are both fix caliper right?? That means no sliding pins (they always squeak if not greased)....hmmm has to be improper bed-in/break-in of the pads. You dont have enough pad material on the rotor so it squeaks at low speeds
2006 325xi (Sold)
05-02-2014, 01:40 PM | #15 |
Rep 809
Drives: 2014 228i Msport
Same here with my 228
A peasant and proud of it
Save The Manuals!!! |
05-03-2014, 02:42 PM | #17 |
samuray
Rep 139
05-22-2014, 12:33 PM | #19 |
Rep 178
Mine seems to have subsided... I didn't do anything special to bed the brakes.
JB
11-18-2014, 04:22 PM | #21 |
Rep 809
And my Msport 228 just started doing this at 5600 miles. Seems to be cold weather related. Driving me crazy
11-19-2014, 07:50 AM | #22 |
Rep 809
Going to carry it to dealer next week. $40,000 car should'nt be waking up my neighbors when I go to work at 5:30am
