2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Belt Kit Torque Specs?
      07-25-2021, 07:07 PM   #1
waxfigure
Member
waxfigure's Avatar
Can someone tell me the torque specs for the tensioner and the idler pulley?
just purchased: BMW Accessory Drive Belt Kit - 11288604266KT
Also, if you can link any guides it would be highly appreciated!
Thank you!
      07-25-2021, 09:51 PM   #2
delvec03
Drives: 228i Sport/ DSB
n20 is around 25 ft lbs.
careful...I learned that aluminum is soft, the hard way. wrench tight should be plenty.
      07-26-2021, 10:15 PM   #3
waxfigure
Member
waxfigure's Avatar
Oops I forgot to mention its for N55 (2016 m235i)
      08-01-2021, 04:39 PM   #4
123Britt
Drives: 15 M235i AT; 2008 Z4 3.0Si MT
Some Torque Value for N55 (235I) -
Hope these are accurate - use at own risk:
56Nm = idler Pulley
38Nm = Tensioner Bolt
Oil Filter Housing = 22 Nm
Spark Plugs = 23 Nm
W/P = 10Nm Aluminium non-alum 20.5 Nm
Coolant Hose to Block (Mickey Mouse) 8.5 Nm
Intake manifold Cover Nuts = 15Nm
Intake manifold Cover Bolts = 15Nm
Oil Cooler Bolts = 16 Nm
Oil Cooler Bolt holding (2) Feedlines = 8Nm
Oil Drain Plug = 25NM
Hose Clamps = 3Nm
      08-14-2021, 09:56 AM   #5
waxfigure
Member
waxfigure's Avatar
56Nm = idler Pulley
Spark Plugs = 23 Nm
Hose Clamps = 3Nm
I went with 38 / 60 based on other N55 videos on youtube..
I accidentally used ft lbs instead of NM on my digital torque wrench but I ended up re-torquing it to NM 10~15 minutes after I realized. Luckily haven't noticed any issues yet (done about 300miles since)
      08-15-2021, 06:54 AM   #6
123Britt
Idler Pulley Torque
Yes 60Nm or 56Nm -- wish I had at least an F30 maintenance manual to review.
I took that info from when I ordered the parts from FCPEuro.
On their website when ordering the belt kit it says:
Please note: When installing this kit torque the belt tensioner bolt to 38Nm and torque the idler pulley bolt to 56Nm.
