2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Harmonic Damper
      07-09-2021, 12:31 PM   #1
MarcoZandrini
Drives: 2018 M240i
Harmonic Damper
I've been noticing a vibration+deep noise when the engine is running at about 1000rpm. There's a Technical Service Bulletin (TSB SI B11 01 19) out that tells the dealer to inspect the harmonic damper for issues. The damper and the serpentine belt are replaced if the damper's rubber material is torn or damaged. I have an appointment on 7/21 to have it checked.
overcoil3104.50
