05-10-2016, 10:21 AM | #265 |
Rep 201
Here you guys go:
19x9 et48 & 19x8 et45. 5mm spacer is necessary up front to clear the suspension. With 265 & 235 MPSS tires the setup is flush all around with less than a millimeter to spare in the back. Last edited by Saab Story; 05-10-2016 at 03:14 PM.. |
jpnh1424.50 |
05-20-2016, 06:16 AM | #266 |
Rep 4
Hello Saab Story I've ordered same wheels for my 228i, is the 5mm spacer needed in the front also with 225 (with standard suspensions)? I didn't find any information on BBS website
05-20-2016, 06:46 AM | #267 | |
Rep 887
Drives: Enzo F23 228i
05-20-2016, 09:51 AM | #268 |
Rep 201
Clearance wise you should be fine without it. Although you may want to pick up a set so the wheels don't look recessed into the fenders. Make sure to go with BBS's spacers; they are designed to work with their PFS system to ensure that the wheels remain hub centric.
09-06-2016, 07:42 AM | #269 |
Rep 6
Those wheels look amazing! I'm looking to do the same, was wondering if they fit ok with no need for spacers. You mentioned you use 5mm spacer, is that because you have aftermarket suspension? I used a calculator online that confirmed there will be no difference in scrub radius, with the spacer there would then be a difference in scrub radius which may affect handling/stability.. Is it really needed? The wheels sit perfectly in the arches by the looks of things!
09-06-2016, 09:27 AM | #270 |
im a car
736
Rep 1,117
Drives: 220i M Sport | 520i M Sport
3 cars, 3 different wheels (ignore the Porsche and Lambo hahaha)
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB] Instagram: @icyj95 | FB |
jpnh1424.50 |
09-09-2016, 01:55 AM | #272 |
Rep 177
09-09-2016, 07:04 AM | #273 |
Rep 81
19x8.5 et 42 and 19x9.5 et 56 with 5mm spacer on 235/35/19 and 255/30/19
Edit: Wow just realized how terrible that picture came out posting from a mobile. Last edited by artinz; 09-09-2016 at 09:41 AM.. |
09-09-2016, 12:20 PM | #274 |
im a car
736
Rep 1,117
wheels wheels wheels...
09-10-2016, 11:05 AM | #275 |
Rep 3,843
09-10-2016, 11:22 AM | #276 |
Rep 81
09-11-2016, 01:14 PM | #277 |
Rep 177
09-11-2016, 04:34 PM | #278 |
Rep 864
Very Quality
09-12-2016, 12:24 PM | #279 |
Rep 199
Drives: M235i alpine white on black
after market wheels
VMR 701's
09-14-2016, 06:12 PM | #280 |
Rep 18
Does anyone find putting aftermarket wheels on their 235 alters the handling or steering in any way? My old man put 19's on his 335 and the steering became really heavy. I don't know the specs of the tires though.
09-16-2016, 05:13 AM | #281 |
Rep 83
Have you got any more pics on this? Also where did you purchase from? I'm pretty much sold on these for my M135i...
09-16-2016, 08:49 PM | #282 |
Rep 103
09-23-2016, 11:20 PM | #283 |
Rep 509
Drives: 2016 M235i RWD 6MT
2015 ES350 6AT - Traded In 2004 RX330 5AT - Sold 2004 Civic Coupe Si(EX) 5MT - Retired 1993 Civic Coupe Si(EX) 5MT - Retired |
10-18-2016, 06:58 AM | #285 | |
Rep 6
http://www.wheel-size.com/calc/?whee...cl=30mm&sr=0mm I have already populated the data with measurements I took from my M235i, for the rear wheels and arches.. and included the new wheels and tires I intend to buy. |
10-18-2016, 11:20 AM | #286 | |
Rep 3,843
The scrub radius is something that people don't talk about much, many people are more concerned with the "look". Couldn't the scrub radius be compensated for with a bit of camber adjustment? |
