2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics 6.5" to 8.8" L7 Navigation Display Screen Swap | Very Simple & Cheap (relatively) ;)
      04-17-2017, 06:50 AM   #111
aus2610
England
Drives: BMW 118d Sport
How does this improve the displayed information?
Hiya,
Coming to this late as I just got an 118D sport.
Fantastic, simple mod which I will have to add to my list too. And well illustrated too. Makes all the difference.
A query though. How does the appearance of the screens change on the larger display? Are they the 6.5 screens stretched or does the system sense the bigger screen and show different information (i.e. more split screens, more data).
Anyone who has done this mod (particularly with Nav) able to upload a few screenshots of the differences?
Thanks Guys.
      04-19-2017, 12:38 PM   #112
simsimma777
Drives: 2019 M850i coupe
Originally Posted by aus2610 View Post
Hiya,
Thanks Guys.
I don't have pictures right now (you can look at the OPs), but the car will adjust to the larger screen resolution so it will look the same as a car that came with the 8.8" screen stock, minus the navigation menus. There is no stretching or anything.
Your technically supposed to code the car to let it know a bigger screen was installed, but in my case I found that I didn't even need to do that as the option was already set to the larger screen.
      04-19-2017, 12:44 PM   #113
simsimma777
Originally Posted by CharlieF576 View Post
Looks brilliant! I have one problem doing the upgrade with mine though, I've fitted the screen and there was no problem there but after the coding the display doesn't seem to work...
In the coding the two entries you say to change are:
HU_NBT > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_NBT > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
But when I go online with my car the entries I have are:
HU_ENTRY > 3000 HMI > DISPLAY_SIZE_RESOLUTION = 8.8_1280x480
HU_ENTRY > 3001 EXBOX > DISPLAY_VARIANTE = breites_display
But it still doesn't work. In the original post it said you need HU_ENTRY so I'm wondering if anyone could shed some light on this for me.
When you start the car you can hear the radio and stuff, it's just the screen not displaying anything.
I had the same issue as you, I think I was getting a message that said 'no connection' or something like that.
Turned out the wire wasn't connected to the screen properly. Just double check the wire and make sure its plugged all the way in, and you should be good to go.
      05-02-2017, 05:17 PM   #114
CharlieF576
CharlieF576's Avatar
United Kingdom
Drives: BMW 335d xDrive M-Sport Shadow
Thanks for the advice but I eventually got it working, I had bought the wrong screen, because of my head unit configuration etc I noticed my existing smaller screen had "L7 Mid" on it, I swapped it with an "L7 High" screen and it works excellently.
I'm guessing L7 is logic 7 I did post some pictures on this thread somewhere of it working
      06-04-2017, 01:28 PM   #115
schoettt
Drives: 228i x drive m sport
Am I out of luck if my build date is 6/2014?
      06-30-2017, 12:05 PM   #116
rawrbot
Drives: m235i 6MT EB
2016 BMW i3 REX  [0.00]
2016 m235i  [0.00]
Does the display with the different backplate from the F30 wiggle or rattle at all after install?
F22 displays are so much more expensive online...
      06-30-2017, 12:10 PM   #117
Anderw
Anderw's Avatar
Drives: F80 m3
No doesn't rattle or anything , I used a f30 back plate for a almost year without any problem, if it's not going to bother you having a small gap I'd go with the f30 screen
      07-01-2017, 01:15 PM   #118
rawrbot
2016 m235i  [0.00]
Anderw Thanks for the reply.
Since the gap is in the rear of the display and totally unnoticeable I feel like it's no brainer to go with the f30 display.
      07-01-2017, 02:13 PM   #119
david51
david51's Avatar
France
538
Drives: bmw M3 F80
Hide the back of the original screen F30 on F22
      07-01-2017, 02:14 PM   #120
Anderw
Anderw's Avatar
Drives: F80 m3
That's a good way to fix the problem !
david51537.50
      07-20-2017, 02:27 PM   #121
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
Just a few updates some might find useful:
- You can code the retrofit through the BimmerCode app in expert mode. Very easy. Good option for those not comfortable with eSys.
- Touch Controller basic functionalities are plug and play. However even through coding I wasn't able to make the touch functionality work. Not sure if missing something, hardware is incompatible or ID version is not the right one
- Be careful with the clips under the screen. I lost one of them in the dashboard. Hard to find.
      07-21-2017, 11:43 AM   #122
corporate.roadie
Drives: 2016 M235i
New 10.3" touchscreen option!
http://www.businesswire.com/news/hom...Retrofit-Touch
Under 1K, looks interesting!
      08-10-2017, 05:18 PM   #123
CanadianGatorBacon
CanadianGatorBacon's Avatar
Drives: M235i (holy crap!)
Originally Posted by corporate.roadie View Post
$955
Seriously don't care about those features enough to drop that much money.
Gone but not forgotten: 1992 Buick LeSaber Limited | 1999 Acura CL 3.0 | 2003 Volvo S60 2.4T | 2006 BMW x3 3.0i | 2009 Honda Fit Sport
      08-20-2017, 12:50 PM   #124
Shirk228ix
Drives: 228ix
Originally Posted by CanadianGatorBacon View Post
$955
That's still cheaper than some f22 screens I've seen on eBay.
      08-27-2017, 11:04 PM   #125
BM235iW
BM235iW's Avatar
Drives: 2015 Black Sapphire M235i
It looks like a great article you posted and my sister would be interested in updating as you have. Unfortunately it seems that photo bucket is an issue displaying your instruction pictures, not sure if it's them or me is the problem (I am a senior citizen). Is there any chance of obtaining these pictures by reposting w/o photo bucket or a different source?
      09-04-2017, 05:04 PM   #126
Anderw
Anderw's Avatar
Drives: F80 m3
I'm going to go through and fix all my pictures , seems photobucket has gotten greedy
      09-12-2017, 12:32 AM   #127
Theoneandonly
Drives: F22 218i M Sport, F48 18d xLin
This is my screen, can anyone tell me if it will work on mine? The right product code for this would be greatly appreciated as I've found half a dozen different ones online. I'm ok with with f30 8.8 or f22 RHD 8.8
      09-13-2017, 02:29 PM   #128
stlb5
stlb5's Avatar
222
Drives: '19 M2C MT, '15 X5 Msport
What options are there for us HU_entry poor souls?
      10-21-2017, 06:04 AM   #129
af5bv
Drives: BMW 320i
Anderw can you please post photos without photobucket (I dont want to spend $400 just to see them)
      11-14-2017, 06:09 AM   #130
Isolde
Drives: M235ix
Just did this upgrade. Great improvement over the old screen. Very easy with Bimmercode and the right parts. Thanks to Anderw for working this out for the rest of us!
      12-13-2017, 11:08 AM   #131
Roman G
Drives: a few
I have a 2018 230i, will the screen part number: 9387453 still be applicable to me?
      01-16-2018, 05:30 PM   #132
J1mayo
Drives: 228xi coupe
Can someone please let me know how to code the screen. I installed, but the screen is black.
JM
