2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Engine / Drivetrain / Exhaust / Bolt-ons Injen evolution cold air intake system - evo1105
      12-07-2022, 02:20 PM   #89
HP Autosport
Supreme Allied Commander
Drives: F80 M3
bump
      12-14-2022, 10:50 PM   #90
HP Autosport
Drives: F80 M3
Take the ultimate driving experience of your 2016-2020 BMW 340i/440i (F3X) series with the B58 engine to the next level of excitement with Injen’s EVO1105 Evolution cold air intake system. This intake was designed using the most up-to-date engineering tools and techniques available to produce a top quality kit that has no parallel. The EVO1105 cold air intake system is truly on the next level. From the one-piece sealed housing that utilizes our patent pending Twist-Lock technology to securely attach a massive SuperNano-Web Dry air filter in place all the way down to premium hardware, Injen has put it all on the board to provide you, the consumer, the best intake possible!
Roto-molded Housing:
The one-piece sealed housing utilizes the all-new Injen Twist-Lock System to securely attach the SuperNano-Web Dry air filter in place which eliminates the use of unnecessary parts and provides one of the simplest installations available. The EVO1105 housing also sports the all-new Injen Clear-View badge for a cleaner more aggressive under hood appearance.
Roto-molded Intake Tube:
The EVO1105 Evolution Air Intake System uses a custom designed and dyno-tuned, intake tube to produce huge power gains while retaining an OE quality fit.
SuperNano-Web Dry Air Filter:
“That’s massive!” is all you will hear about this SuperNano-Web Dry air filter that is included with the EVO1105 cold air intake system. This filter has been uniquely designed to work with the Injen Twist-Lock System. Using our Twist-Lock technology has allowed our engineers to use the largest filter possible for this application, which increases the available air volume - resulting in added power while keeping the installation process quick and simple.
Quality Hardware:
From the Stainless Steel Band Clamps with an inner protective liner to the reinforced automotive grade silicone coupler, every aspect is covered for a perfect and secure fit.
Hassle-Free Installation:
Make it easy! The Injen Evolution Air intakes that use our Twist-Lock System have been strategically designed to use fewer parts to provide the end user with one of the quickest and simplest installations available on the market today.
Dyno Proven:
Clean and simple, NUMBERS talk! Injen has put in the time and diligence to stand behind our performance data. We put in the time to test and prove that we have developed a superior kit for your BMW. So after hours of designing and dyno testing, Injen is proud to say that the EVO1105 Evolution Air Intake system puts down numbers of up to 13 additional horsepower and 18 lb-Ft. of torque.
KEY FEATURES
Direct Fit for
2016-2019 BMW M140i L6-3.0L(t) F20/22
2016-2019 BMW M140i xDrive L6-3.0L(t) F20/22
2016-2020 BMW M240i L6-3.0L(t) F22/23
2016-2020 BMW M240i xDrive L6-3.0L(t) F22/23
2016-2019 BMW 340i L6-3.0L(t) F30/31
2016-2019 BMW 340i xDrive L6-3.0L(t) F30/F31
2016-2019 BMW 340i GT L6-3.0L(t) F34
2016-2019 BMW 340i GT xDrive L6-3.0L(t) F34
2016-2020 BMW 440i L6-3.0L(t) F32
2016-2020 BMW 440i xDrive L6-3.0L(t) F32
2016-2020 BMW 440i Gran Coupe L6-3.0L(t) F36
2016-2020 BMW 440i Gran Coupe xDrive L6-3.0L(t) F36
Dyno Proven gains of up to 13 hp and 18 lb-ft. of torque
Designed to work with the stock calibration
Aggressive intake growl under acceleration
Durable Roto-Molded Polyethylene tube and housing
Reinforced automotive grade silicone couplers
Fully serviceable Injen SuperNano-Web dry air filter
Replacement air filter # X-1112-BB
Stainless steel band clamps with inner protective liner
Aggressive under hood appearance while maintaining an OE fit
Our clear inspection badge allows you to quickly check the condition of your air filter while the red stripe enhances under hood appearances.
Made in Pomona California, USA
Injen Technology Limited Lifetime Warranty
This product is not currently CARB exempt and is not available for purchase in California or for use on any vehicle registered with the California Department of Motor Vehicles.
      12-26-2022, 02:13 PM   #91
HP Autosport
Drives: F80 M3
bump
      01-10-2023, 06:47 PM   #92
HP Autosport
Drives: F80 M3
bump
      01-19-2023, 11:30 AM   #93
HP Autosport
Drives: F80 M3
bump
      02-01-2023, 05:21 PM   #94
HP Autosport
Drives: F80 M3
bump
      02-10-2023, 03:36 PM   #95
HP Autosport
Drives: F80 M3
bump
      02-21-2023, 03:16 PM   #96
HP Autosport
Drives: F80 M3
bump
      03-02-2023, 02:17 PM   #97
HP Autosport
Drives: F80 M3
bump
      03-16-2023, 01:16 PM   #98
HP Autosport
Drives: F80 M3
bump
      03-27-2023, 09:18 PM   #99
HP Autosport
Drives: F80 M3
bump
      04-07-2023, 11:41 AM   #100
HP Autosport
Drives: F80 M3
bump
      04-19-2023, 02:35 PM   #101
HP Autosport
Drives: F80 M3
bump
      05-04-2023, 04:22 PM   #102
HP Autosport
Drives: F80 M3
bump
      05-18-2023, 04:33 PM   #103
HP Autosport
Drives: F80 M3
bump
      05-30-2023, 08:34 PM   #104
HP Autosport
Drives: F80 M3
bump
      06-13-2023, 03:47 PM   #105
HP Autosport
Drives: F80 M3
bump
      06-27-2023, 01:39 PM   #106
HP Autosport
Drives: F80 M3
bump
      09-13-2023, 04:43 PM   #107
HP Autosport
Drives: F80 M3
Order here:
https://www.hpashop.com/products/inj...04a6569b&_ss=r
      09-21-2023, 01:54 AM   #108
HP Autosport
Drives: F80 M3
bump
      09-27-2023, 12:19 PM   #109
HP Autosport
Drives: F80 M3
bump
      10-03-2023, 01:42 PM   #110
HP Autosport
Drives: F80 M3
bump
