03-18-2020, 04:18 PM | #1 |
Rep 28
Engine loud ticking
I've owned 2 BMWs (135i with N54 engine and 335xi with N54 engine). I just bought my 2016 M235i and didn't notice when test driving but the engine ticking noise is really loud. I've seen some threads say that is normal but check out my video as I've never had a BWM this loud.
What do you think it is? Anything I can do?
Cyle with a "C"
My ride: 2016 M235i. Black w/ Black Extras: |
03-19-2020, 04:14 AM | #2 |
Rep 5,577
It’s hard to gauge the loudness frm the audio but the direct injection fuel injectors do sing louder.
U may want to pop off the top plastic engine cover to make sure the foam insulation is affixed underneath. Just a guess |
03-19-2020, 06:08 AM | #3 |
Rep 706
What's the mileage? Maintenance history? Wanna bet 10k mile oil changes? Just a guess...
Sounds like lifters... Go to harbor friend and get a stethoscope and put it on intake, heads, and block... It'll tell you exactly where the noise is from and go from there! Can do an oil change with some engine (internal) flush that you put in and run for 20 mins or so before dropping the oil. Then replace oil and filter. I suggest after 500 miles dropping oil and filter again. Of course this is just throwing new oil at the sound and may be totally unrelated. But with new (used) car purchases, isn't going to hurt anything except your pocket a little. Can't see the inectors being so loud, or at least changing their tune, lol. Good Luck |
MLJR235116.50 |
03-19-2020, 09:16 PM | #5 |
Rep 28
So I found this and it does NOT work on N55 engines. Waste of time.
So being I just bought it I'm going to do an oil change first. Then I will look into the lifters. Does anyone have a good video on how to change lifters?
Cyle with a "C"
03-26-2020, 08:49 PM | #7 |
Rep 68
03-27-2020, 05:51 PM | #8 |
Rep 5,372
Definitely not the injectors. Very likely a bad lifter or an issue with the Valvetronic eccentric shaft actuator/system.
MLJR235116.50 |
03-27-2020, 05:54 PM | #9 |
Rep 5,372
Very difficult to change the lifters on the N55 due to the highly complex valve train system. It's most certainly something left up to someone that is/was a BMW tech. It also requires a few special tools to control/manage spring tension.
In normal operation, the N55 doesn't rely on a throttle body to manage incoming air. It's uses valve timing as the throttle management.
04-09-2020, 01:12 PM | #11 |
Driver - Autocross
74
Rep 178
This sounds like some bad lifters, Injectors are loud but they're more of a ticking than a thudding. I'd get this checked out ASAP and don't drive the car like this. Doesn't sound like rod knock but this is for sure something internal.
04-09-2020, 04:42 PM | #13 |
Rep 599
How many miles on the car? Spun rod bearings can sound like that.
I would do an oil analysis.
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM 1995 E36 M3 Sunbelt S52 |
04-09-2020, 05:55 PM | #15 | |
Rep 28
Cyle with a "C"
04-09-2020, 05:58 PM | #16 | |
Rep 28
What would it do? Just let me know if there are metal deposits or any other debris. Not sure what that would have to do with it.
Cyle with a "C"
04-09-2020, 06:03 PM | #17 | |
Rep 28
Cyle with a "C"
04-09-2020, 06:09 PM | #18 | |
Rep 599
If there is a spike in a mineral like lead it would point to bearings or another engine component that has lead in it. Oil analysis's are best to use over time because you can see increase of minerals to know whether or not the figures are normal.
04-10-2020, 07:14 PM | #19 |
Driver - Autocross
74
Rep 178
I still think it's a lifter problem, no way that's a injector tick....rod knock would get louder with RPM.
16 M235xi 8ZF Black on Red FBO: Xhp trans tune -BMS Intake - VRSF Catless DownPipe - VRSF CP - VRSF Muffler delete/resonator - n22 plugs - MHD stage 2+ 95map - Wagner EVO II Preformace IC - Rear seat delete - weight reduction/stripping -FTP 18.5in rims - Hawk HPS front pads - StopTech STR 660 fluid
04-10-2020, 08:56 PM | #20 |
Rep 706
Again... A stethoscope, or the old screwdriver to the ear trick will locate the tick and you can go from there... No joke! It works. Stop guessing! Harbor Freight is like $12...
04-22-2020, 02:26 PM | #21 |
Rep 28
So I took it in and they are saying it is Brake Vacuum Pump making the noise. Does that sound right to anyone?
$2,000 would be the fix they say. Par for the BMW course.
Cyle with a "C"
04-23-2020, 09:08 AM | #22 |
Driver - Autocross
74
Rep 178
