11-22-2020, 08:45 PM | #1 |
Rep 44
Starting point for performance mods?
Hey guys just recently got my 2015 M235i xdrive and have been on the forums for a couple months now I just do not know where to start. Where would the most sensible spot to start with tuning. I am assuming bootmod3 stage 1 would make the most sense but I am curious if I should add maybe a cold air intake or charge pipe as well. Any input would be appreciated. Also any recommendations for the intake or charge pipes as well any other mods you'd recommend would be great. Can't wait to start the modding journey!
11-22-2020, 09:40 PM | #2 |
Rep 338
Vrsf for the charge pipes, they're reasonably priced and their honestly all the same. As for the intake, you don't need it, they cause lots of problems on lots of cars. A good drop in filter is all you need, if you wanna get real fancy you can cut a extra hole in the lower half of the air box to mimic the M Performance box. Just look up a picture and copy it. Bootmod is a good time, it's what I run.
11-23-2020, 11:10 AM | #3 |
Rep 190,804
Bootmod3 + charge pipe
I recommend CTS Turbo CP , best value in my opinion
11-23-2020, 11:41 AM | #4 |
Rep 736
Drives: Lexus RC F
I'm in the same boat as you and so far, ordered a K&N panel filter, vrsf cp and BM3 from Mike at XPH. ^^^
Skip the intake, I had a BMS one and my car didn't respond well (rough starts and high IATs).
Estoril Blue E36M3
11-23-2020, 11:50 AM | #6 |
Rep 190,804
Its always recommended to upgrade the plugs when tuning the car. The stock ones will eventually fail with increased boost
11-23-2020, 09:53 PM | #7 |
Rep 72
What would you like to get out of the mods? Stage 1, Stage 2, or elsewhere?
From my experience, i did stage 1 and im wanting MORE, but now i gotta add a couple more to produce more POWA. In order to get more power, there's a series of Modz to get. So if you want just a lil bump try stage 0+ or stage 1 for a bit. |
11-24-2020, 08:44 AM | #8 | |
Rep 44
11-25-2020, 09:53 AM | #9 |
Rep 190,804
stage 2 is perfectly safe on the engine, you check the datalogs and see how the car is reacting to the additional power. With that being said, you are doing the right thing by going with stage 1 for now. If you want more power, you can upgrade in the future
11-25-2020, 10:13 AM | #10 |
Rep 44
Thanks for the response. Once I have some cash saved up I will look into one of the combo deals on x-ph. I am surprised you guys don't have a charge pipe bm3 combo, it would be perfect for a stage 1 tune!
11-25-2020, 03:56 PM | #11 |
Rep 190,804
Most customers don't get the charge pipe separate. They almost always add an intercooler as well. That's why we have a deal for both + the downpipe as that's all the mods needed for stage 2
11-25-2020, 05:42 PM | #12 |
Rep 31
I like turtles.
Pussiwillow521.00 |
11-30-2020, 10:01 AM | #13 |
Rep 10
My goal is 450WHP and not 1 WHP over. Please see the build I am currently doing that will be done mid-Dec 2020:
Build in progress @ 69k miles (they are now stripping the car): ● Perform Automobile Dynamometer Before and After ● F Chassis N55 JB4 Tuner ● N55 PURE Stage 1 Turbo ● Momentum Cold Air Intake System w/Pro 5R Filter Media ● Turner Motorsport N55 Stepped Intercooler ● Turner Motorsport N55 High Flow Catted Downpipe ● CTS Turbo Charge Pipe Upgrade Kit ● Performance Iridium Spark Plugs ● OEM High-Pressure Fuel Pump Replacement Kit ● OEM Fuel Injector Replacement (6) ● OEM Rear Shocks, Springs and Related Component Replacement ● BMW M Performance Exhaust (Installed 06/2014 @ 15k miles) ● BMW M Performance Brake Kit
BRAND NEW N55 engine put in 6/2018 (or 15k miles ago) on this 2012 335i: JB4; Momentum air intake; VSRF Catted DP; Turner FMIC; CTS chargepipe; M Performance Exhaust and Brakes and new OEM HPFP and fuel injectors.
