10-27-2020, 05:46 PM | #1 |
Rep 1
Will 19x9.5 et40 Fits? F
I have recently seen a set of second-hand BBS CH, 19x8.5 +35 19x9.5 +40 5X120. I would like to ask if F22 RWD can use them? If not, I'll just buy Apex. But BBS is really attractive. I have the Dinan Lowering Spring on my car. In addition, I wanna ask if the BBS is suitable, what is the maximum width of the tire I can put in the rear wheel?
10-27-2020, 09:49 PM | #2 | |
In search of the perfect cup of coffee
140
Rep 211
"run 19x8.5 ET35 in the front with a 225/35/19 tire and 19x9.5 ET45 in the rear with a 255/30/19 tire. This is based on stock to mildly lowered ride height." |
10-28-2020, 09:37 AM | #3 |
Rep 345
Perfect offset is about 40 front and 45-50 rear. But thats to run the maximum size tire. You're within 5mm (closer to fender). So you wont have a suspension rub issue but you may have a fender rub issue if you go wide on the tire and your car is lowered etc.
235 front and 255 rear SHOULD be ok with what you have, especially on stock suspension. Could be an issue if you get a wider than normal tire or if lowered. |
