2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics M240i coupe front door speakers
      10-17-2020, 09:19 AM   #1
jliuod
Drives: 21' M440I
Does anyone know the max depth of the front door speaker that will not obstruct the window?
      11-13-2020, 09:32 PM   #2
RocketBoots
RocketBoots's Avatar
Drives: Horse Drawn Carriage
I've heard 47mm, but I've not tested the limit. I have one that is 42mm and there is no issue at that depth.
      11-17-2020, 08:21 AM   #3
MarcoZandrini
Drives: 2018 M240i
What speakers are you considering?
      11-18-2020, 12:36 AM   #4
jv92red
Drives: F22 M240i (SOLD) E92M3 (SOLD)
Clearance for 4" door speakers in the F22 and across many BMW chassis codes is ~42mm, and I believe there are some 4 door BMW models that may allow a few more mm, not sure on that. There are a few aftermarket BMW specific retrofit 4" drivers that fit (Eton and Bavsound comes to mind) and a few other mainstream aftermarket vendors that have shallow 4" drivers that will fit this spec. For example, the Audiofrog GB40 4" drivers will fit perfectly, they have a 41mm mounting depth thanks to its smaller Neodymium Motor. Actually, when Audiofrog owner Andy Wehmeyer was designing these 4" drivers he had BMW's specifically in mind. But these Audiofrog 4" drivers aren't cheap at ~$450 per pair but there are more examples of really good 4" drivers, component sets, and coaxials for less. And if budget isn't a concern then the Dynaudio Esotar E430 drivers will fit perfectly as well and would be probably the best midrange driver you could get to fit your stock 4" door cavity but at around $2K for the pair, you'll have to pay to play.
But I digress, for a potential solution to allow deeper drivers, if you go with a set of PVC adapter rings from the seller "73mustangconv" on eBay, mounting depth would be increased to "50mm-52mm". I think he lists 50-52mm since these 4" adapters would work for multiple BMW chassis codes but in the listing he has a picture of a F22 passenger side door with 4" Morel Maximo coaxial installed which he notes has a 52mm mounting depth. There are two pics on the listing, one with the speaker mounted on the adapter with the door card off, the other with the door card on but with the factory speaker grill left off.
https://www.ebay.com/itm/BMW-F30-31-...cAAOSwDk5UExUe
Here is a link to that morel speaker for reference:
https://www.woofersetc.com/p-10027-m...er-system.html
BTW If you're running the factory amp I would look for other drivers with higher efficiency than those Morels. Our factory amps are already weak as it is, with 87.5db sensitivity on the Morels the OEM amp may struggle to keep up.
edit: Sorry, forgot to mention a disclaimer that if you're running the OEM amp and want to run a dedicated 4"midrange driver like the Audiofrog then you'll have to add a passive x-over to allow a seperate tweeter to be added as you only have two channels up front (left and right doors) from the factory amp. As good as the GB40's are for midrange duty, they would make terrible tweeters.
TonM3249.00
      11-18-2020, 11:53 AM   #5
Jcoop901
Southern Fried
Jcoop901's Avatar
Drives: BMW M240i
2017 BMW M240i  [9.00]
Focals will also fit and sound incredible.
      11-19-2020, 08:52 AM   #6
MarcoZandrini
Drives: 2018 M240i
Which focals have you installed in your car?
      11-19-2020, 04:06 PM   #7
Jcoop901
Southern Fried
Jcoop901's Avatar
Drives: BMW M240i
I put these in the doors. The tweeters and the crossovers were a bit of a challenge, but nothing too bad. The mids fit perfectly in the door.
The Focal IC 100's are basic plug-and-play replacements.
If you search on eBay you can find any of these for roughly half price compared to Crutchfield.
The Focals offer very good sensitivity and provide the best soundstage I have heard in a 2 series. The highs are far less harsh than hard dome tweeters. Overall a very natural and accurate reproduction of any music you chose.
