09-14-2020, 08:31 PM | #1 |
Rep 86
Rear DRL coding
Hi all, I am using Bimmercode to try to turn on the real DRLs. After multiple attempts at coding it and getting an 'active' message in the Bimmercode app, the rear daytime running lights still do not light up. Do I need to use expert mode to turn them on for a non-LCI taillight?
Current: 228i M Sport
Former: E85 Z4 3.0, E89 Z4 35is, 28 others.... |
09-15-2020, 03:31 AM | #2 |
Rep 208
I've done it with e-sys so it definitely works on non-LCI, but never done it with bimmercode.
With e-sys you can just use a cheatcode to do it, you just tick "enable taillight as DRL".
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger
09-15-2020, 10:14 AM | #3 |
3612
Rep 3,578
The options that need to be changed are:
MAPPING_TAGFAHRL_H_L_OUTPUT - default is "", needs to be set to "sl_l" MAPPING_TAGFAHRL_H_R_OUTPUT - default is "", needs to be set to "sl_r" |
09-15-2020, 10:29 AM | #4 |
Rep 86
Thanks!
09-15-2020, 10:30 AM | #5 |
Rep 86
Appreciate it!
09-15-2020, 10:44 AM | #6 |
Rep 86
Strange, I checked in expert mode and mine are set to the appropriate settings for 'on' yet I still get no DRLs. I've coded them several times, toggling on and off and back again but still no lights.
09-15-2020, 10:46 AM | #7 |
Rep 736
Drives: Lexus RC F
There are bulbs in the housing, right?
Estoril Blue E36M3
09-15-2020, 10:55 AM | #8 | |
Rep 86
09-15-2020, 11:06 AM | #9 |
3612
Rep 3,578
I only needed the two options coded to switch them on on my 2017 M240i, but there are 8 possible options that may make a difference:
MAPPING_TAGFAHRL_H_L_OUTPUT - "sl_l" MAPPING_TAGFAHRL_H_R_OUTPUT - "sl_r" MAPPING_TAGFAHRL_H2_L_OUTPUT - "sl_2_l MAPPING_TAGFAHRL_H2_R_OUTPUT - "sl_2_r MAPPING_TAGFAHRL_H_L_FUNCTION - "werte 06" MAPPING_TAGFAHRL_H_R_FUNCTION - "werte 07" MAPPING_TAGFAHRL_H2_L_FUNCTION - "werte 06" MAPPING_TAGFAHRL_H2_R_FUNCTION - "werte 07" |
09-15-2020, 12:35 PM | #10 | |
Rep 86
09-15-2020, 04:19 PM | #11 | ||
Rep 86
MAPPING_TAGFAHRL_H_L_OUTPUT - "sl_l" MAPPING_TAGFAHRL_H_R_OUTPUT - "sl_r" MAPPING_TAGFAHRL_H2_L_OUTPUT - "sl_2_l MAPPING_TAGFAHRL_H2_R_OUTPUT - "sl_2_r MAPPING_TAGFAHRL_H_L_FUNCTION - "werte 06" MAPPING_TAGFAHRL_H_R_FUNCTION - "werte 07" MAPPING_TAGFAHRL_H2_L_FUNCTION - "werte 06" MAPPING_TAGFAHRL_H2_R_FUNCTION - "werte 07" Thanks aerobod - I tried the codes you have shown. Two questions: When you show a value like 'werte 07', I see a value that says '0x06'. Am I changing that to '0x07'? Also, when coding is in process and I get the 'restarting ECU' message I don't always see my instrument panel reset. Does that mean the ECU isn't restarting and is that affecting the coding?
09-15-2020, 08:13 PM | #12 | |
Rep 5,262
09-15-2020, 09:50 PM | #13 | ||
Rep 86
09-15-2020, 10:51 PM | #15 | |||
Rep 5,262
