2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Anyone used VMR V-710 on M235/M240?
      09-14-2020, 11:48 AM   #1
Si-M240i
United Kingdom
137
Drives: M240i LCI
Anyone bought and fitted VMR V-710 wheels on oem suspension???
18" 8.5j ET43
18" 9.5j ET50
What was the quality like and did you manage to fit 235/40 on the front without rubbing the suspension strut or did you need a 3mm spacer ?
I take it 255/35 was not an issue in the rear?
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
      10-27-2020, 08:52 AM   #2
2pt5RS
Drives: 2016 BMW M235i
those offsets are too high. I just got an email from them with the following sizing:
2x VMR Wheels V710 18x8.5 ET35 5x120 72.6
2x VMR Wheels V710 18x9.5 ET45 5x120 72.6
      10-27-2020, 10:00 AM   #3
Jcoop901
Southern Fried
Jcoop901's Avatar
Drives: BMW M240i
2017 BMW M240i  [9.00]
What size tires can you run with those?
      10-27-2020, 09:24 PM   #4
aftercorbu
aftercorbu's Avatar
Drives: 20 M2C, 20 S3
225 and 255
Si-M240i136.50
      10-28-2020, 09:41 AM   #5
TrboMike
Drives: BMW M240ix
I may be wrong, but I thought V710 18x8.5 only comes in +35 and +45 offset.
FRONT:
+40 is perfect for about a 245 tire. So if you go smaller like 225 either one of those offsets will work. If you want a 235 or 245, its probably safer to get the +45 offset (closer to suspension) and put on a 3mm or 5mm spacers to get closer to 40 offset.
If they do come in +43 offset, then a 225 will be fine and probably a 235 also.
REAR: I know +45 will be good, with a +50 rear you should be ok for up to a 255 tire. Might want to research that one before you buy
      10-28-2020, 10:15 AM   #6
Si-M240i
United Kingdom
137
Drives: M240i LCI
FRONT:
I have them in ET43 all round but fitted 3mm spacers all round. Not needed for rear but wanted it the same all round. On the front I had 2.5mm clearance between the wheel and strut so did not want to risk a 235/40 tyre like that but with a 3mm spacer a 235/40 if perfect 👌. So basically I'm at ET40 all round with 18" 8.5j V-710's
      10-28-2020, 03:29 PM   #7
BeautyInMotionF22
Drives: E36,E92,F22
I have 19s but am running ET50 in the rear with 265s no rubbing with the 710s
      11-19-2020, 01:56 PM   #8
VMRWheels
General
VMRWheels's Avatar
2038
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
18" 8.5j ET43
18" 9.5j ET50
Both OP and 2pt5RS are correct, 8.5et35/ 43 and 9.5et45/et50 will work with no issues. VMR Europe usually recommends et43/50 while we(USA) recommend ET35/45, which both clear the recommended 225/255 tires just fine. 265 has been done with ET50, but it's too close to be able to guarantee a rub free fitment. For those with no access to the ET43 fronts, we recommend an ET45 front with a 3mm spacer (effective ET42). This allows for a 235 front tire.
      11-19-2020, 01:59 PM   #9
Si-M240i
United Kingdom
137
Drives: M240i LCI
18" 8.5j ET43
18" 9.5j ET50
I run 235/40 front with ET43 with 3mm spacer, on eom suspension and no rubbing 👍
