2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Code 102001 MAF issue?
      11-20-2018, 10:12 PM   #1
Eatyolegs
Drives: 2014 M235i
A few weeks ago I installed a vrsf catless downpipe, charge pipe, and a intercooler.
Car was running pretty well until yesterday, it started throwing code 102001 "Air mass, plausibility -- Tuner code, ignore" and the feel of the car was drastically different. I've cleaned the MAF twice and checked the connections on the intake, they seem fine.
Do I need a new MAF? Is there a way to know if mine is screwed up? or could I have leaks somewhere else that's making the car throw code?
      11-21-2018, 10:39 AM   #2
hwntime
hwntime's Avatar
272
Drives: F22 Raptor
Do you have an aftermarket intake? If so, I'd start there and remove it to see if it clears.
      11-21-2018, 11:33 AM   #3
Eatyolegs
Drives: 2014 M235i
I do. So you're saying put the stock one back on and see if that helps? Okay, will do, and will report back, thank you.
Any other suggestions?
      11-21-2018, 11:48 AM   #4
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
sell what you bought and buy the dinan if you need an intake.
I know dudes with 550whp + 2's with stock intake and a drop in filter.
So go back to stock if you have to.
www.nybmwcca.org
Current Cars:
      11-21-2018, 12:49 PM   #5
hwntime
hwntime's Avatar
272
Drives: F22 Raptor
Yes, put the OEM back on. BMW's don't take well to most aftermarket intakes.
      11-22-2018, 01:34 AM   #6
Shayan55
Shayan55's Avatar
Drives: F90 M5
2105 BMW M235I  [0.00]
Yea, back when i used to run the BMS intake, I got a code (code can be cleared via custom tune, Enzo Racing did mine and it cleared the code) But the code was from the intake, now i am on the stock airbox with a BMC filter no problems at all.
(Sold) M235I Dinan intake, Active Autowerke FMIC, meisterschaft, TCKline coilovers, NT01's, BMS Oil cooler valve, VRSF DP&CP, BM3,StopTech Trophy BBK, Corbeau FX1 Pro seats, AP bar, Bimmerworld V3 Wing, APR Front splitter, Seibon Vented CF Hood
399.8whp on 91oct
Hmu on Ig: @n55_shayan
      11-25-2018, 05:30 PM   #7
Eatyolegs
Drives: 2014 M235i
I went back to the stock intake and I'm still throwing the code. What now?!
      12-09-2018, 12:10 AM   #8
naveed865
Drives: BMW M235xi
I have a 2015 M235xi with catless downpipe, bms intake, and a jb4.
I just received that same code im trying to figure it out, nothing i have done worked. Im probably going to take it to the shop, but i prefer to do myself to save money.
      12-09-2018, 02:33 PM   #9
aschmitty6
Put your stock airbox back on, clear the code, see if it comes back. If it does, could be a dirty or faulted MAF sensor.
      12-10-2018, 11:18 AM   #10
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
102001 air mass to high, I literally just had the same code show up through bootmod3 yesterday. The car was doing some very weird things like jerking during light acceleration and then cutting out at a stop street going into neutral. It turned out to be an incorrect fitment of my charge pipe it was not seated onto the cooler correctly. after we sorted that out the car is perfect and the code has not come back.
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT //
//CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 //
      07-18-2020, 07:54 AM   #11
adamnm2
Drives: Bmw m135i
Hello mate,
I’ve just seen this post because I’ve got the same issue as you,
What exactly did you do to fix the problem, the garage that fitted it said it’s fine but will double check everything, I’m just wondering what the exact problem was and how to fix it so I can pass it on to the garage,
Thanks
      08-02-2020, 06:11 PM   #12
beeyar
Drives: BMW 335i MSports 6speed M/T
Originally Posted by adamnm2 View Post
Hello mate,
Thanks
I’m also seeing this issue after installing bootmod3, car would jerk randomly and getting two error codes 102001 and 10BA49 any solutions?
      08-12-2020, 07:29 PM   #13
JoelEnc
Drives: 2015 BMW M235i Xdrive
What did u do for the solution, I’m currently having the same issue that someone else had above where the car stalled at a stop and I had a code 102001 I put the stock air box back on thinking it was my Cts intake but it wasn’t. Should I do a smoke test to check for boost leaks I have a vrsf cp and IC.
      08-13-2020, 12:13 AM   #14
XutvJet
You guys have intake leaks somewhere. My guess is at the charge pipe rubber section that joins the two pipes or the charge pipe connection at the intercooler.
Do all of you have VRSF charge pipes?
      08-13-2020, 06:47 PM   #15
JoelEnc
Yes I have a vrsf charge pipe and thank you I will try to check it out tomorrow.
      08-14-2020, 12:53 PM   #16
beeyar
Unfortunately, I don't have a charge pipe yet, I just got the car on bootmod3, I believe you are right and will take a look at it this weekend.
      08-14-2020, 01:02 PM   #17
beeyar
I am going to check this weekend, did you figure it out?
      08-14-2020, 07:34 PM   #18
JoelEnc
Not yet. I might try to do a smoke test to know exactly where because by just looking at it I can’t tell where exactly on the charge pipe am I having the boost leak.
      08-17-2020, 07:16 PM   #19
beeyar
Not yet. I might try to do a smoke test to know exactly where because by just looking at it I can't tell where exactly on the charge pipe am I having the boost leak.
I found my issue, turns out the C clamp between my throttle body and stock charge pipe blew off, luckily the C clamp is still there but the stock charge pipe is done, I'll need a new charge pipe.
      08-20-2020, 09:23 AM   #20
JoelEnc
Yeah I found mine too with a smoke test. Turns out one of the bungs for meth on my charge pipe blew off somehow so I had some screws with thread locker on it now and it runs fine.
      09-10-2020, 08:15 AM   #21
ChristosD
ChristosD's Avatar
South Africa
97
Drives: m135i
100% charge pipe related
      09-14-2020, 02:40 PM   #22
Niko_X5M
Drives: BMW X5M
I have this problem. I have a high flow downpipe, chargepipe, intake, jb4 and exhaust. Can’t seem to figure it out.
