08-02-2020, 07:11 PM | #793 | ||
Rep 1,287
08-02-2020, 07:52 PM | #794 |
3612
Rep 3,579
Mercedes and the Volkswagen Group use the 5x112mm bolt pattern And Mercedes and Audi use the same centrebore. Likely it is easier to get better supplier prices when using a configuration that is more of a standard.
mblaucoupe135284.50 |
08-03-2020, 07:03 PM | #795 | |
Rep 1,287
08-03-2020, 07:27 PM | #796 |
3612
Rep 3,579
Actually I think the A3 uses the VW centrebore of 56.1 with it being on the Golf MQB platform, as opposed to the larger Audis, but it is worth checking.
08-03-2020, 09:06 PM | #797 | |
Rep 1,287
08-13-2020, 07:38 PM | #799 |
Rep 15
2016 M235i xdrive... stuck height, daily driver looking for summer set up.... staggered vs. Square set up... benefits or downfalls? I did look through about half the pages, but was hoping to hear some opinions.. looking at V703 19"
08-14-2020, 11:16 AM | #800 |
Rep 237
I did v710 19x8.5 et35 + 3mm spacer (=et42) 235/35/19 and 19x9.5 et50 265/30/19 and it's fantastic. I would never consider 225/255 on the same width personally, there's so little sidewall even with 235/265. This v710 fitment is off the shelf and as close to perfect for a 2 series as you can get. Not a single rub or contact ever even with front adjustable camber/caster bushings. I'll try to post a pic (seems to be hard on a phone)
08-14-2020, 11:19 AM | #801 |
Rep 237
Edit: also on dinan springs, but with 5mm rear spring spacers
2016 M235i 8AT - MHD Stage 2/XHP Stage 3, AA Gesi downpipe/axle back/charge pipes/IC, QTP 3" wireless cutout, MSL oil thermostat, Nelson billet paddles, Gates X5M fob, Xpel 35% tint, LED conversion + body stuff, VMR V710 235/35 + 265/30, Dinan springs/stops/5mm rear spring spacers, Powerflex bushings, Akebono pads...and far too much of my time
10-03-2020, 03:50 PM | #802 |
Rep 894
Bought these a few weeks back but just got around to putting them on.
V703 19x8.5 ET40 Pilot 4S 225/35-19 V703 19x9.5 ET45 Pilot 4S 255/30-19 I think maybe the rears have way too much poke but I am going to give it week or so. |
10-15-2020, 11:52 PM | #803 |
Rep 1
Drives: BMW M240i Stock
Could you post more photos from the side, so we can all appreciate those beauties
Last edited by Bimmerbeast; 10-15-2020 at 11:53 PM.. Reason: I didnt clarify the angle of the photos |
11-03-2020, 04:05 PM | #806 | |
Rep 337
My car has 225/40/18 run flats all around. Can't wait to ditch them. |
11-04-2020, 07:48 AM | #807 |
Rep 894
Side shot by request.
V703 19x8.5 ET40 Pilot 4S 225/35-19 V703 19x9.5 ET45 Pilot 4S 255/30-19 |
aftercorbu404.50 |
11-05-2020, 07:11 PM | #808 |
Rep 337
11-07-2020, 09:19 PM | #809 |
Rep 337
Anyone running 18x8.5 235/40 front and 18x9.5 rear 265/35 on stock sports suspension without rubbing or issues? Please advise if you had to use negative camber or mods. Im thinking et 40 front and et 50 rear. Thanks.
11-10-2020, 11:36 AM | #810 | |
Rep 337
11-22-2020, 09:12 PM | #811 |
Rep 9
just bought my 2019 m240ix. already looking for wheels. I love the vmr look. my car came with 19s but the fronts are x7.5 and the rears are x8. I would like to have a wider tire but idk if its worth it. I also plan on doing some autox but with these tires at 30 series I can feel the sidewall folding during hard cornering. wondering if I should just use these 19s for my winter set and buy either 18s or 19s for summer. or should I just keep these 19s and maybe buy better tires for them and buy a winter setup. ???
11-23-2020, 09:08 AM | #812 | |
Rep 144
If you just do occasional autox then stick with the wheels you have. |
01-23-2021, 06:36 AM | #814 |
DisplacementReplacement
394
Rep 1,092
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
Tags |
9.5, fitment, v703, vmr, wheels |
