2Addicts | BMW 2-Series forum Classifieds Members Classifieds Suspension / Brakes / Chassis / Spacers Vorshlag camber plates for OEM-style springs
      06-14-2020, 04:40 PM   #1
SkyeC
Too many cars, not enough time
43
Drives: 17 m240i
Cool Vorshlag camber plates for OEM-style springs
Shipping Costs Included
Hi,
New set of Vorshlag camber plates for OEM or OEM replacement springs (H&R, etc.). They are for 5 bolt strut mount vehicles only.
Purchased these, but ended going a different route.
All hardware needed to install is included.
Below is from Vorshlag:
  • Compatible with all OEM diameter factory and aftermarket (lowering) springs for BMW F22
  • Works on the 2014-up BMW 1/2/3/4 series and M235 and up to 2018 M2
  • Installs with basic hand tools, no chassis modifications required.
  • Camber is easily adjustable at the track with simple hand tools (1/4" hex wrench sold separately in this car's Suspension section)
  • The spherical bearing used in the Vorshlag camber plate is the largest used in any BMW camber plate on the market. The result has much better durability and wear characteristics than the undersized bearings used in our competitors' plates.
  • Aluminum alloy main plate and 2-piece steel alloy bearing holder construction - Tough as a tank!
  • Sealed radial ball bearings isolate steering movement from spherical bearing. These do not have to be removed monthly and re-greased like competing models that use a flat, unsealed Torrington bearing
  • All components machined in-house at Vorshlag on our CNC machines
  • All components plated or anodized for maximum corrosion resistance and long life.
  • Can also be converted to use with coilover springs (different camber plate entry in this car's Suspension section)
  • Vorshlag upper spring perches are included and built to fit the OEM style spring for this model.
FOR SALE: 2017 ///M240i, 6 speed, slick top, Estoril Blue. https://www.2addicts.com/forums/show....php?t=1865469
