2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Leaving OBD Bluetooth Dongle Plugged In - Battery Discharge?
      05-19-2020, 05:02 PM   #1
Conr4d
Conr4d's Avatar
28
Drives: 2024 BMW X3M Competition
I use the Veepeak OBD BLE+ Bluetooth Dongle to monitor oil/coolant/transmission/intake temperature gauges while driving via the Bimmerlink app.
Will leaving the OBD bluetooth dongle plugged in while the car is parked/off prematurely discharge the car’s battery?
I have read other users having issues where their alarm is triggered when they attempt to lock their car with an OBD Bluetooth dongle plugged in. My 2016 M235i does not do this. I would prefer to leave it plugged in for convenience if there is no risk to the battery.
2024 BMW X3M Comp ~ Individual Gentian Blue
      05-20-2020, 10:48 AM   #2
TrboMike
Drives: BMW M240ix
Quick answer: yes but most drain so little you wouldnt notice if the car is driven at least 3x a week.
Longer answer: depends on the dongle but in most cases yes. ODB2 standard puts constant power to the port (there is always power there even if key off, car parked). Most dongles are on when plugged in, and only turn off when you unplug it. So it will be on all the time and a small drain on battery, especially cheaper dongles where they make the circuitry as simple/cheap as possible. Some dongles small drain, some larger. I've seen some high end wifi dongles that detect when the car is off and turns itself off thereby not using the constant power source even tho it is there, and thereby not using power when car is off. If your car driven once a week or less, I'd unplug it. Most the cheap dongles would take 2-3 weeks to drain a new good battery in summer. But constant drain and recharge will shorten the life of a battery. And why deal with it in very cold winter or when your battery is older and towards end of life and now you have a jump/charger situation just for a dongle
      05-21-2020, 07:15 PM   #3
Conr4d
Conr4d's Avatar
28
Appreciate the feedback. I am going to unplug after each use. Better safe than sorry, its one extra step to plug and unplug each time.
      05-21-2020, 07:17 PM   #4
H2O_Doc
H2O_Doc's Avatar
Drives: BMW M2C, GLB-250, C7 Z51
As a general rule of thumb, dongle discharge isn't good.
      05-24-2020, 11:43 PM   #5
PDM5
Drives: 2017 240i 6 Speed
I don't have an OBD adapter in my current car, but I've always left it plugged in my other cars with no issues. Just make sure you drive the car regularly and there should be no issues.
