2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Replacement Battery Registration?
      05-27-2017, 12:11 AM   #1
shark715
Drives: '11 X5 50i, '16 M235xi vert
When you replace a 2 series battery does anyone know if the new battery needs to be registered in the same manner as our '11 x5?
Instead of having to pay the dealer or independent garage to do it, I want to buy one of the electronic tools so I can do it myself, but if our 235 requires the same thing, I want to make sure I get a tool that works on both cars so I'll be prepared when the time comes.
Thanks in advance for your help.
      05-27-2017, 08:19 AM   #2
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Yes, all late-model BMWs require registering the new battery with the car's charging system. You can use Carly for BMW Pro and their bluetooth OBDII adapter, which will cost about $100 all told for the adapter and the license. Very easy operation, works on Android and IOS devices.
shark715166.00
fbsm743.00
      05-27-2017, 12:20 PM   #3
shark715
Thanks! Based on Carly's website I thought that was the answer, but just wanted to make sure.
Can Carly also handle a change to the type of battery (AGM versus lead acid) as well as a change to the Amp Hour rating of the battery?
Finally, with Carly can you see the battery history the way the pros can (history of battery replacements, history of the charge condition of the existing battery, etc.)?
Appreciate your help.
fbsm743.00
      05-28-2017, 08:22 AM   #4
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Here's a link that will answer your questions:
http://support.mycarly.com/knowledge...hould-you-buy/
You can choose AGM vs. lead-acid, but you can't replace an AGM with a lead-acid. It also allows you to select the ampere-hour rating. It will vary from car to car (chassis/model).
      05-28-2017, 08:32 AM   #5
shark715
Thanks so much!
      05-28-2017, 08:37 AM   #6
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
You're welcome! I've been using Carly for BMW since it was called "BMWhat" and it's been well worth the cost.
      05-29-2017, 02:46 AM   #7
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
You can also do it for free with ISTA+ and ENET.
      05-29-2017, 08:47 AM   #8
RoundelM3
RoundelM3's Avatar
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Yeah, but he can also do feature coding with Carly...
      05-29-2017, 08:56 AM   #9
shark715
Thanks for the input. I did see the info on ISTA+ and ENET, and candidly was a bit scared away by it as my computer literacy is merely average. Looks significantly more complicated and I was not clear how current some of the data was.
No doubt I probably could have waded my way through it after investing some time, but I came to the conclusion that in my case the investment in Carly would be worth it.
      05-29-2017, 12:17 PM   #10
Almaretto
Almaretto's Avatar
2374
ISTA+ (compared to older INPA or DIS) is very easy-to-use interface.
