2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning Misfire at 6500rpm - No codes thrown - Stage 2 BM3
      12-08-2022, 11:16 PM   #1
Hatcher
Drives: 128i
Hi Everyone,
I've recently had issues with my 2016 m235i xdrive (94k) misfiring at high rpms. At first it was throwing a superknock - cylinder 5 injector shutdown code. I had all of the plugs (one step colder NGK), coils (Eldor) and injector 5 and LPFP replaced as well as walnut blasting done.
Car is driving much better but still misfires on full load at high rpms randomly, and also when pulling out of the driveway after cold start on 1>2 shift. No codes are being thrown.
Car has BM3 stage 2, AR design catted downpipe, VRSF chargepipe and secondary resonator delete, pump fuel (91 octane). Logs are linked below, any ideas what could cause this behaviour? Thanks for any guidance you can offer 🙏
https://www.bootmod3.net/log?id=6392...729bf911e6209b
https://www.bootmod3.net/log?id=6392...729bf911e620a5
https://www.bootmod3.net/log?id=6392...729bfbe96ae6cf
edit: happens on stock tune as well. plugs are gapped 0.022
      12-09-2022, 08:35 AM   #2
designatedposter
Drives: m235i
why is your short term fuel trim maxed out at 0.7? enable and log LTFT to get an idea what's going on, maybe you have a vacuum leak.
cylinder 4 timing consistently lags behind all the others, try swapping plugs and/or coil with another and see if that's the culprit. maybe that injector has an issue.
M235i rwd 6mt
      12-11-2022, 09:51 AM   #3
M2_MEDUSA
M2_MEDUSA's Avatar
Drives: 2021 M2 Comp. SpecialEdition
Dude you have legit engine knock in your log and your timing is all fucked up, Preety bad. Whens the last time you changed out your spark plugs?
Instagram: M2_Medusa
      12-14-2022, 10:02 PM   #4
Hatcher
Drives: 128i
Plugs were changed right before the log above was taken. After the log above was taken I replaced the HPFP with a stage 2 Nostrum one and it feels like it improved things a lot but still misfiring same as before under high rpms. Still getting what feels like either knock or misfires today on the new log below:
https://www.bootmod3.net/log?id=639a...0b431774f989cb
It is now throwing 1C3102 Engine Oil Pressure Sensor; plausibility; pressure before engine start-to-low
Im not sure how to enable LTFT to check if there is a vacuum leak unfortunately.
Any guidance is welcome 🙏 thank you.
      11-18-2023, 04:06 AM   #5
rVito
Drives: bmw f30 335i
check your vacuum hoses around chargepipe and intake. All of them need to be plugged in tight, due to age they tend to loosen and need replacement
      11-27-2023, 06:14 PM   #6
MLJR235
MLJR235's Avatar
117
Drives: M235I
Originally Posted by Hatcher View Post
Is it just me or is your HPFP crashing hard in 3rd gear pull? You're dipping into 1200psi range which is pretty low. Are you running the stock HPFP?
'15 235i - Moddedededed
Tags
bm3, cylinder 5, high rpm, misfire, n55, stage 2
