2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Little rear fog lamps
      09-02-2019, 10:00 AM   #1
F22 Raptor
Usually 10 over
F22 Raptor's Avatar
Drives: 2015 BMW228i Coupe AT
OK, so I finished doing the grounding cable retrofit to my taillights for pre-10/2016 vehicles:
https://www.newtis.info/tisv2/a/en/f...ter/1VnZ8zZX2B
...after my iDrive barfed telling me I had no taillights on the right side. After I opened up, all bulbs were good but the #7 pin on the eight-pin connector was fried and melted part of the connector (no ground). My BMW parts dept. sold me the repair kit for half price (nice!) and I used the new connector. I used another method for adding an additional ground since I was NOT replacing the socket housing. I can detail it for you if you ask me nicely!
My question is this: How can I make that cute little H21W bulb work with the brake lights? Or can I? I've read that's a fog light (I don't have the rear fog switch) OR it's a two-stage brake light that comes on during heavy braking. If that's true, how can I test it?
I was thinking of jumper-ing the lights together but I got cold feet thinking I might blow something else or send iDrive into a tizzy again. I still would like to make it work - I hate the fact I got empty real estate back there. Thanks
      09-02-2019, 03:10 PM   #2
19bis
Drives: 2016 328i; 2018 230i
So long as you have front fog lights, adding rear fog lights is an easy and inexpensive (i.e., free) mod. In the headlight switch assembly, pop out the blank button underneath the front fog light button, using a trim tool. There are two nibs on the top near the front of the button and one nib on the bottom; these need to be shaved down (they function in US vehicles to prevent you from pushing the button in). Reinsert the button.
Now you need to do a little coding:
In FEM 3060 (LceMaster) NSL_Verbaut -> verbaut
In REM 3063 (LCELampMapping 2)
Mapping_Nebelschlussl_L_Output -> nsl_l (0x1C)
Mapping_Nebelschlussl_R_Output -> nsl_r (0x1D)
      09-06-2019, 08:48 PM   #3
da jemster
da jemster's Avatar
78
Drives: E46 M3,E93 M3,F22 M235i,i1 i3
This is on the E9x platform. The way 19bis is describing it, I think it might be the same instructions: https://www.m3post.com/forums/showthread.php?t=531296
'04 E46, '08 E93, '16 F22 M235i, '17 i01 i3
      09-06-2019, 10:43 PM   #4
19bis
Yeah, that's way too complicated. No need to take out the vent and dismantle everything, just pop out the button from the front, trim off the tabs, and reinsert the button.
      09-08-2019, 09:09 PM   #5
F22 Raptor
Usually 10 over
F22 Raptor's Avatar
Er, uh, I guess what I really like to know is can I make the fog bulbs work as an additional brake light? Has anyone done this? And done it without upsetting the computer?
Thanks for the comments and suggestions, especially 19bis for the lines of code - I'll use them if I go the rear fog route.
      09-08-2019, 09:26 PM   #6
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
On US-spec vehicles, the "Rear Fog Lights" are already used as emergency brake lights, this is BMW's description of its operation:
The Dynamic Brake Force Display show drivers behind you how heavily you're braking and allow them to react in good time. This drastically reduces the danger of a rear-end collision.
The brake lights themselves are divided into two zones. During normal braking, only one zone is illuminated. When heavy braking is detected, Brake Force Display increases the intensity of the brake lights by illuminating the second zone as well (i.e.Rear Fog Lights).
      09-09-2019, 10:58 AM   #7
F22 Raptor
Usually 10 over
F22 Raptor's Avatar
Thanks Poochie!
Now, how can I test the second stage to see if it is working?
      09-10-2019, 07:41 AM   #8
Poochie
Poochie's Avatar
Drives: 2016 M2
Originally Posted by F22 Raptor View Post
Thanks Poochie!
There is no way to test them unless you have someone follow you and confirm they activate, upon moderate to hard braking. If they didn't work, there would be some some sort of bulb error on the dash, indicating the second-stage brake light is out.
Also, if you did the "rear fog light" mod or have a European switch to control the rear fogs, you can code them to illuminate in a steady state.
Tags
bad ground, rear fog lamps, taillights
