2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Oil Dipstick???
      08-06-2014, 04:41 PM   #23
mjayjock
Drives: 228i
If found 5.3 Quarts for the 228i engine Online
Many thanks for the reply:
7 Quarts sounds like a lot for a 2L engine:
I found the following online for the 228i:
2014 BMW 228i 2.0L 4-cyl Engine Code N20 B20A Turbo
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......SEO[1]
Synthetic 5W-40 European Oil (EFMQT)
All TEMPS......5W-30, 5W-40, 0W-30, 0W-40
Manual Transmission,S6-17BG......GLS [2]
All TEMPS......
No AMSOIL Product Recommendation
Automatic Transmission,GA8HP45Z......SLF [3]
Signature Series Fuel-Efficient Synthetic Automatic Transmission Fluid (ATL) (ATLQT)
OE Fuel-Efficient Synthetic Automatic Transmission Fluid (OTLQT)
Standard Differential, Rear 188LW......GLS [4]
All TEMPS......
Fluids
Clutch Fluid......HBH
AMSOIL Brake Fluid DOT-4 (BF4SN) [5]
Brake Fluid......HBH
[1] To prevent potential engine damage, use only BMW High Performance Synthetic Oil part No 07 51 0 017 866 or an equivalent meeting BMW Long-Life rating LL-01 or LL-01FE
[2] Use MTF-LT-3, BMW P/N 83 22 0 409 878. Ensure correct fluid is used by referring to the label on the transmission.
[3] Shell M-L12108, BMW P/N. 83 22 2 152 426
[4] Use BMW P/N 83229407768 (60 Liter).
[5] Hydraulic Brake Fluid, DOT 4
TORQUES:
Oil Drain Plug.....6 ft/lbs [1]
Manual Transmission GS6-17BG [2]
Fill Plug 18 ft/lbs
Drain Plug 18 ft/lbs
[1] Replace oil drain plug. If the new oil drain plug does not
latch after tightening to specified torque, the drain plug
must be positioned so the latch mechanism is aligned.
[2] M12x1.5 thread
      08-06-2014, 04:44 PM   #24
mjayjock
Drives: 228i
Sorry here is the cut and paste on 228i oil amount
CAPACITIES:
Engine, with filter..........5.3 quarts [1]
Cooling System, Initial Fill..........5.6 quarts
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, GA8HP45Z Initial Fill..........Not Specified [2]
Automatic Transmission, Total Fill
8 speed GA8HP45Z..........Not Specified
Manual Transmission, S6-17BG..........3 pints
Differential, 188LW Rear..........0 pints [3]
[1] After refill check oil level.
[2] Carry out oil level check in accordance with instructions from a scan tool.
[3] Fill to level of fill plug.
      08-06-2014, 04:46 PM   #25
alz0rz
What goes here?
alz0rz's Avatar
452
Drives: 2019 G30 M550i
woops.. sorry yeah that was for the M235i
2019 G30 M550i
GBNF:
2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i
      08-20-2014, 12:04 AM   #26
dreamspeed
dreamspeed's Avatar
Drives: 6MT
Unfortunately a manual dipstick is one of those things they took out and will never put back in.
