2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Trunk Won't Open (DIY Fix)
      06-15-2023, 01:12 PM   #1
omerakz
Drives: BMW 220D F22, Mazda MX5 ND
2014 BMW 220d  [0.00]
Hello all,
My 220d's trunk actuator failed and i cannot open the trunk.
Also i was not able to fold the rear seats, but with a lot of work, i figured a way to fold them with a stick, i will post the video there
https://youtube.com/shorts/Pb3ae6jDoPk?feature=share
Now, i can not find the emergency latch to open the trunk, maybe my trunk does not have it? I guess my car is Euro version, but clearly there is no latch here. Maybe European people does not lock people on trunks 🤔
Anyway, here is the foto inside trunk, do you guys have any idea how to open it? I tried to remove the black trim inside the trunk lid, but it is also impossible without opening the trunk.
Waiting for your ideas! Thanks
      06-15-2023, 02:07 PM   #2
fiveightandten
fiveightandten's Avatar
108
Drives: F22 M235, E36 M3, E30 325, E90
The latch is accessible. Have you tried using a flat screwdriver to flip it to the open position? If that does not work, remove the plastic trim under the trunk lid so you can unbolt the latch.
      06-18-2023, 06:01 AM   #3
omerakz
it is accessible but i dont know how do i open it, it is probably impossible or too much force needed because it is locked already.
i could not remove the plastic trim, i will try again but it is probably impossible to do without opening the trunk also
      06-18-2023, 08:31 AM   #4
omerakz
Update:
I applied force to lock with flat head screwdriver, did not open, broke some plastic parts of it, tried to open the trunk with its button, luckily it opened. Looks like i broke the lock completely, but it was not working anyways. Tomorrow i will buy a new lock and put it in.
      06-18-2023, 09:38 AM   #5
Apo Zubulthums
Drives: 228i M-Sport slick-top
I see you ordered the trunk delete.
omerakz11.00
      06-20-2023, 12:42 AM   #6
omerakz
I finally installed the new lock, it is better than it was before 😅
      06-20-2023, 10:10 PM   #7
fiveightandten
108
Nice job getting things solved. This is such a stupid design. There should be a mechanical backup for when these electric parts fail.
      06-24-2023, 04:15 PM   #8
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
There is a mechanical back up but it is only installed in delivery countries that routinely lock people in the trunk.
