2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Oil filter change - didn't swap the small O-ring, problem?
      12-07-2014, 04:28 PM   #1
yep
Drives: M235i ED June 11
I did an oil change today and I didn't swap out the small O-ring that came in the oil filter box. Is this a problem? I inspected the one on the oil filter housing and it looked fine so I left it.
      12-07-2014, 04:52 PM   #2
overcoil
Drives: M235i 6spd
As long as you don't double up the rubber o'rings or leave them off you'll be fine.
Easy just to wrench off filter and replace if it bothers you.
BTW how many o'rings get replaced? My Mercedes had four and I don't remember how may my 2-had.
What are your oil drain intervals?
      12-08-2014, 09:39 AM   #3
bman6074
Drives: 14 M235i and 07 Lotus Exige S
if its like past BMW's which i beleive it is. There are only 2 o-rings. large one and small one.
Here is what is looks like on the 135i
      12-11-2014, 03:43 PM   #4
Gate7
Oh rly?
46
Drives: 335i
Why wouldn't you change it since it already comes with the filter?
