2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB What to check before a long road trip?
      07-21-2014, 07:52 PM   #1
lichenlt
Considering the car is so new (1800 miles so far), do I need to take it in for an inspection before my 3000-mile road trip?
      07-21-2014, 08:10 PM   #2
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
I don't think so.... just carry a quart of oil in the trunk just in case
      07-21-2014, 08:10 PM   #3
overcoil
Drives: M235i 6spd
An oil change ?
Some may say totally unnecessary, but I think it's not a bad idea, guess they would charge one-hour labor ~.
      07-21-2014, 08:13 PM   #4
lichenlt
good idea.
Which one is the OEM oil? I remember seeing somebody mention it here on the forum but can't find it now.
      07-21-2014, 10:28 PM   #5
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
Biggest thing is to check the tire pressure.
      07-23-2014, 03:21 PM   #6
zkeeper
zkeeper's Avatar
Drives: 2017 M2 & 08 Z4 si
Am also on same page with fresh oil change. Get break in oil out and new in. Yeah, I know...I'll get flamed for it sounding too old school, but if you are taking that long of a trip with sustained speeds, most likely, nice to have fresh oil now that break-in time is completed.
At same time, have a tech--- or DIY-- double check torque on wheel bolts. They may be OK but may also have worked the adjustment-need magic after 1800 miles. Air inflation as above is a must. Don't assume its the same as when you picked it up. And even then it might not have been spot on. Have a great trip...
      07-23-2014, 04:07 PM   #7
lichenlt
Thanks for the suggestions!
      07-23-2014, 11:54 PM   #8
pikcachu
pikcachu's Avatar
1403
Originally Posted by lichenlt View Post
good idea.
http://www.bavauto.com/fland.asp?part=07+51+0+017+866
http://www.fcpeuro.com/products/bmw-...FctzMgodozYAPw
      08-15-2014, 12:58 AM   #9
RichRed2
Drives: 2014 BMW M235i
I agree with checking your tire pressure before a long trip. Mine was delivered with all tires at 34 psi, which is two psi too high for the front and 2 psi too low for the rear. Once I put in the correct pressure the car handled much better. If you do change the pressure significantly to bring it back to specs you need to recalibrate the car tire pressure monitoring system. It is easy to do (instructions in owners manual).
      08-15-2014, 08:43 PM   #10
lieb923
lieb923
Drives: '15 M235Xi
2015 BMW M235Xi  [0.00]
M235 Oil
Iirc the oil spec is 0-40. Approx 7 qts. Enjoy the trip.
      08-15-2014, 09:01 PM   #11
pikcachu
pikcachu's Avatar
1403
you can use any of these but the car comes with 5w30 in the US at least
SAE 0W-40, SAE 0W-30, SAE 5W-40 and SAE 5W-30
      08-15-2014, 09:51 PM   #12
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
1800 miles and oil change? Dont waste your money, but do one after the trip
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
