12-07-2021, 09:23 AM | #1 |
Rep 344
Tree branch fell on m235. Advice
Based off the pictures I'm wondering what the procedure of fixing this is, hoping it can be done with paintless dent repair. If there's anyone familiar with the cost of body work like this or works/owns a body shop, is it worth paying out of pocket or going through my insurance for something like this?
12-07-2021, 09:28 AM | #2 |
3615
Rep 3,585
Should be fairly easy with PDR. If they can use a glue pull on the outside and don't have to disturb the headliner, likely will cost $100 to $200 for a skilled operator to do, a bit more if they have to work from the inside.
12-07-2021, 11:57 AM | #4 |
3615
Rep 3,585
In the wrong hands, yes. With a skilled operator and the right tools it only becomes a problem when the area has paint missing or cracked already. I recently had about 30 hail dents removed from my Caterham, the aluminium body is more sensitive to paint adhesion than steel bodies with original paint from major manufacturers. About 50% of those dents were glue pull removal, no issue in paint delamination.
Cos270608.50 |
12-07-2021, 03:37 PM | #5 |
Lucky13
211
Rep 1,762
I went out and looked at mine with the moonroof pushed back, looks like PDR person would have to remove the plastic piece that contains the roof switch and electronics. Looks like the plastic would pop off but it depends on what can be moved around to get to it. I’ve had some nasty dents removed even on the sharp crease where the wheel fender flares are flat. No doubt they can take it out if they can get access. Might have to get it done with glue but if they can get to it through the plastic housing for roof they can fix it.
1995 325i, 1996 328ci, 1997 528i, 1997 Z3 2.8, 2000 528i, 2001 X5 3.0, 2001 330i Convertible, 2002 M3 Convertible, 2003 M3 Coupe, 2004 M3 Coupe, 2004 Z4 3.0, 2004 X3 3.0, 2007 X3 3.0, 2007 335i Convertible, 2013 X1 28 sdrive, 2014 M235 manual, 2020 X3 30i Xdrive
F22leo244.00 |
01-05-2022, 08:03 AM | #6 |
Rep 344
Little update, the shop I went to did a phenomenal job. Looks perfect. Definitely wasn't cheap though since they had to remove the entire headliner
