06-10-2020, 09:44 AM | #1 |
Rep 599
My M235i for medium and economical track use
Hey Everyone. I post a lot on here, but I've never made a thread dedicated to my car.
My M235i is my "daily", but also for this season it is going to be my casual track car. I have a S54 E36 race car, but because of current events and financial/logistical reasons it doesn't make sense for me to run it this summer. I have tracked my m235 a decent amount in the past, but in stock form as a backup car if the e36 was broken. Since I will be driving it a lot more this summer I decided to address some of its easier to remedy flaws. I focused on making it economical to run, as well as something that is enjoyable to drive 6 hours to and from the track in one day. This is how I set it up: Suspension: Tc-Kline camber plates (-2.5 front / -2 rear) Dinan springs + bump stops Brakes: Hawk Dtc-70/60 Ate 200 fluid Driveline: M perf LSD (spec'd when new) Rogue Engineering Short shifter Engine: Fabspeed sport cat Stock otherwise Wheels/tires: Bimmerworld TA5r 17x9 +42 (10mm spacer front) Falken 200tw 245/45 square Rogue Engineering Race wheel studs The 2 most important things in my opinion for running an F22 economically are camber plates and 17" wheels. Camber plates make it possible to make a set of front tires last more than one day. They also make turn-in much better and the car way more neutral especially when running a square tire setup. Because of the fact I'm running 17" wheels, tires are much much cheaper. The Falkens that I run are only $125 a piece. They are very popular within the AER community because they last forever and they are very consistent. They aren't as fast as an Re71r, but they are also half the cost. I'm going to Limerock Park tomorrow and I will report back with some footage.
2015 F80 M3 DCT, Carbon Roof
1998 S54 E36 M3 BMWCCA Club Racing #532 CM 1995 E36 M3 Sunbelt S52 Last edited by K8_M235i; 06-10-2020 at 09:56 AM.. |
06-10-2020, 01:48 PM | #2 |
Rep 3,491
Well done!
Looking forward to your Lime Rock video. Which club is running there tomorrow?
06-10-2020, 01:59 PM | #3 |
Rep 599
Tomorrow is just a scca track night. In two saturdays I'll be there with bmwcca.
1998 S54 E36 M3 BMWCCA Club Racing #532 CM 1995 E36 M3 Sunbelt S52 |
06-11-2020, 09:59 PM | #4 |
Rep 599
Here's some footage from today. I had a great time, Limerock is a very fun and challenging track. Given that this was a track night in America event, there weren't a ton of traffic free laps, but I made the most of it and had a great time.
Towards the end of the second session I got a drivetrain malfunction and greatly reduced power. Towards the end of big bend you can actually see the car die. I tried restarting it, but it didn't sound good so I tried shutting it off again. It sounded like it was down a cylinder and all I could hear was a big vacuum. I didn't want to start it until I read the codes so I got flat towed back. When I read the codes I was confused because they pointed towards a blown charge pipe. I have an evolution racewerks pipe that I installed before my stock one got the chance to blow. At this point I realized that the loud vacuum noise was probably the sound of my car being NA for a brief moment. The charge pipe must of somehow managed to recouple itself slightly because when I started it up everything seemed normal aside from a slight whistle. I felt the middle of the charge pipe and sure enough the rubber coupler was ready to fall off the upper portion of the pipe. I decided to clear the codes, skip the last session, and drive home while trying to stay out of boost. This weekend I'll reattach the coupler fully and make sure to get the clamps nice and tight before Palmer on Tuesday.
06-11-2020, 11:14 PM | #5 | |
Rep 233
Drives: '18 M2 LCI
'18 M2 LCI 6spd
K8_M235i476.50 |
06-12-2020, 12:37 AM | #6 |
Rep 322
Looks like a good time. First time with these Falkens? Any impressions? Seems like the fronts were having a hard time from the video...
Bummer about the charge pipe and missing track time. At least it's a trivial fix. I was kicking myself for not bringing clamps along this weekend, too. Borrowed my friend's Miata and the exhaust hangers tore on track, clamps would've been the perfect fix. We ended up just ziptying it together and kept going |
K8_M235i476.50 |
06-12-2020, 03:23 AM | #7 |
Rep 3,491
Thanks for posting your video.
We can see your hand move to the shifter, but were you in 4th gear all the way around?
K8_M235i476.50 |
06-12-2020, 07:18 AM | #8 | ||
Rep 599
I'm a big fan of them just because of how long they last. Falken actually just came out with a replacement 200tw which I'm going to try. Quote:
I would shift into fifth on the main straight, down shift 5,4,3 into 1, use 3rd for turns 1,2, and 3, and then shift back into 4th on the back straight before the uphill and use 4th for the rest. I tried using 3rd one lap up the hill, but the revs jumped way more in 3rd when the car got light, so I stuck with 4th. I was trying to be (somewhat) nice to the car.
dradernh4347.50 |
06-16-2020, 05:58 PM | #9 | |
Rep 400
If you want long lasting tw200 tire, maybe try Hankook RS4. |
06-16-2020, 09:33 PM | #10 | ||
Rep 599
06-17-2020, 02:02 PM | #11 |
Rep 599
Here is some footage from Palmer yesterday. I drove a bit "loose" and definitely got a bit carried away with my turn 14 curb usage.
06-17-2020, 02:37 PM | #12 | |
Rep 3,491
I see Fred put in curbs and tire walls - when did that happen? The last time I was there the only help like that were the barriers to keep you from falling off the mountain! Fast lap of 1:56.46?
06-17-2020, 02:44 PM | #13 | |
Rep 599
Fast lap was 153.82, it pops up at the end of the video on the aim.
dradernh4347.50 |
06-26-2020, 09:48 AM | #14 | |
Rep 36
K8_M235i476.50 |
07-16-2020, 12:32 PM | #15 |
Rep 599
Here's a lap from Thompson Motor Speedway in CT two days ago. Thompson is a fun little track. Great curbs and somewhat relaxing to drive. It's bumpy coming on and off the old nascar oval, but I think it's entertaining.
I'm still running on the same Falkens from mid way through last season. They have a tiny bit more tread life, but they are definitely not in their prime.
08-04-2020, 09:40 PM | #16 |
Rep 599
Here's some footage from 2 weeks ago that I forgot to upload. I drove Palmer a couple weeks ago with a good friend of mine. We both had very similar pace and trust each other as drivers, so it was very fun.
08-09-2020, 11:11 AM | #17 |
Rep 599
Here's a lap from NHMS North and South Chicane from last week.
I will rebuilding my calipers this week. When I came in after the last session I had a decent little fire on my drivers side front. My dust boots have been in disrepair for a little while and I'm getting a little uneven pad wear, so time to rebuild.
07-16-2021, 02:16 PM | #18 |
Rep 189
Old post, I know.
I like the wheels. Would the 17x9 fit the 370mm front and 345mm rear rotors? Also, if you are interested in selling them (if they fit), I would be interested. Cheers. |
07-16-2021, 02:18 PM | #19 |
Rep 599
I don't think they would fit the 370mm rotors. They are very very tight to the 345s. I'm pretty sure bimmerworld says you need 18s for the 370s
07-16-2021, 02:32 PM | #21 |
Rep 599
They make 18s too! They are a great value
07-16-2021, 03:18 PM | #22 | |
Rep 3,491
I missed your Loudon video when you posted it. It brings back fond memories of the excitement I experienced during time trials while barely under control between the exit of 6 and the exit of 10. What a dangerous track, that one is; still, there were remarkably few incidents during the time I was running there. I wanted to ask you about your caliper rebuild. Whose kit(s) did you use, did they include fluid seals as well as dust boots, and did you find that you had 40mm pistons on both front and rear calipers? I'm going to have my blue M-Sport calipers rebuilt and am looking for a source for more than just the dust boots sold by BMW. I looked at bimmerworld, but the front caliper rebuild kit is out of stock and they don't have a date for when it will be back in stock. They do have the rear kit, so I was thinking that if the pistons are the same size front and rear I might try buying rear kits and using them for both front and rear. There's always Zeckhausen, too, I imagine. Any thoughts you have would be most appreciated!
