2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Anyone tried MSS Modular Suspension Solutions kit?
      03-25-2020, 11:33 AM   #45
Matthewricha
United Kingdom
43
Oh sorry, didn't want to sow doubt.. difficult to see purely on a photo!
Looks a good stance!! Did mss elaborate on the different springs? Are they different to manage the famous/apparent BMW ride height difference?
How does one set the spring heights up? Say you want 15mm drop, do you calculate the height adjuster to a defined thread height? Or is it trial and error?
      03-31-2020, 12:03 PM   #46
grocerylist
Drives: BMW M235i
2016 BMW M235i  [0.00]
I see these available for the M240i but would they also be compatible with the M235i? Does anyone know the drop range F&R?
I'd like to reduce bodyroll, firm up the suspension a bit but don't want too much of a drop as my wheel offset and LCA & TS upgrade won't allow for it.
      03-31-2020, 12:27 PM   #47
wfujay
Drives: 2019 Toyota Tacoma TRD OR
Contact Excelerate Performance as they are the main US distributors for MSS. They should be able to answer your question.
https://excelerateperformance.com/
      03-31-2020, 12:43 PM   #48
wfujay
V710's and new rubber mounted! I'll get some better pics eventually.
      03-31-2020, 01:29 PM   #49
stvward
stvward's Avatar
133
Drives: G42 M240i on order
Looks awesome !!
What are your early thoughts on the MSS HAS?
      03-31-2020, 05:43 PM   #50
wfujay
Originally Posted by stvward View Post
Looks awesome !!
Thanks man! And I'm not sure what you mean by 'HAS', but the kit is great so far. Not a ton of miles yet but handling is definitely tightened up and improved - instant feedback. Squat and dive is virtually non-existent. Ride quality was very close to stock, just a tad stiffer with the stock 18 inch MPSS tires.
I thought ride quality would suffer a bit after mounting the larger wheels and lower profile tires, but just the opposite occurred. The Continental ECS's are pretty amazing. Grip and ride quality are both noticeably improved, and they are way more compliant over small bumps and imperfections in the road. I'll never go back to MPSS tires with these on the market, and I can't see how the MPS4S would be worth the significant price jump.
I definitely need an alignment now, as I get very minor vibrations at 75+ mph and a very slight pull to the right, otherwise I'm extremely happy.
Overall, every bit as good as the kit that was on my S3, and I'm a lot happier with the drop on the front tires on this car. Much more uniform.
      03-31-2020, 07:04 PM   #51
grocerylist
Drives: BMW M235i
Looks great!
What's your wheel size/offsets? Do you have any other suspension mods (ie M3/M4 LCA & TS)?
      04-02-2020, 01:06 AM   #52
wfujay
Looks great!
Front: 19x8.5 ET35 225x35
Rear: 19x9.5 ET45 255x30
Thanks man! No other suspension mods.
      04-26-2020, 12:37 PM   #53
Solid67
Drives: 2019 M240i xDrive MP Edition
Going to pull the trigger on the MSS kit. Do you need to pair this with adjustable end links since the car will be lowered?
2019 M240i M Performance Edition / xDrive / ZF8 / BM3 Stg 2+ E30 / xHP Stg 3 / Dorch Stg 2 HPFP / Evolution Racewerks Catless Downpipe / MPPSK Exhaust / FTP Drop in Filter / FTP Intake Pipe / FTP Chargepipe / NGK 94201 Spark Plugs .022 / Michelin PS4S - 225/35/19 + 245/30/19
      05-05-2020, 06:49 AM   #54
wfujay
Nope. These kits are designed to be used on an otherwise stock suspension.
      05-07-2020, 05:20 PM   #55
GoodMoodley
Drives: 12' 135i Pure Stg 2, 15' 228i
Just ordered a set. Will be picking them up this weekend. Hope to pop them in over the next week. Will take some pics and post during the process.
Past: 1979 RX-7, 1980 Civic, 1989 B2200 lowrider, 1990 Golf GT, 1995 Civic Si Turbo, 2000 Civic SiR, 2000 328i, 2003 540i M-Sport, 2008 Rabbit, 2014 Pilot, 2002 A4 1.8T, 2009 A4 2.0T Quattro, 2017 CR-V Touring 2020 CR-V Touring
Current: 2012 135i, 2015 228i x-Drive, 2023 CR-V Touring Hybrid
      05-10-2020, 01:15 AM   #56
cironephotosucks
cironephotosucks's Avatar
No_Country
Drives: 2015 M235i
I know KW makes this for the M2 but will that not fit our cars?
      05-11-2020, 08:37 PM   #57
wfujay
Nice, let us know how it goes!
Say what? This thread is about the MSS kits, not KW coilovers...
      05-12-2020, 06:40 PM   #58
GoodMoodley
Just a bit of unboxing. Sorry for so many pics but just thought some of you may want to see them. Appears to be quite well made. Collars are machined well and the the threads are pre-lubed and move smoothly. Nice that the kit comes with new bumpstops and other rubber parts as well.
Solid67187.00
wfujay19.50
SerenVoX146.00
      05-13-2020, 07:38 AM   #59
wfujay
Does the lettering on your front springs match? "MSS MQB 185-TDF 32/18"
      05-13-2020, 11:22 AM   #60
GoodMoodley
I just checked and yes they do.
      05-13-2020, 01:35 PM   #61
wfujay
Thanks. Mine didn't match up, but I called MSS directly and they assured me they were the same springs.
      05-14-2020, 05:42 AM   #62
GoodMoodley
Well the part number on my kit was for the 3 series. My local distributor guaranteed me that they verified with MSS that it is still the same kit.
I installed one of the fronts yesterday. Doesn't seem to go as low as I expected on the lowest setting. I'm sure it will settle down a little bit more but I'm not concerned as this is my daily and was only looking for a mild drop. At least I'll be able to lift it up a bit for winter driving.
      05-19-2020, 09:41 PM   #63
SerenVoX
SerenVoX's Avatar
No_Country
146
Drives: M235i Xdrive
Hi guys,
I have a set on order for my 2015 M235XI. They should be going on this weekend. It will be interesting to see how they compare to my stock suspicion since im running a very aggressive wheel setup and honestly may no be able to do any drop from stock height. Should be interesting since I have the added weight of the AWD as well. Im also pairing these with Dinan bump stops. Stay tuned.
Here is my wheel setup, wish me luck!
FRONT TIRE: MPSS 8.5 +39 235/40/18 22.2lbs
REAR TIRE: MPSS 9.5 +45 265/35/18 25.8lbs
      05-20-2020, 10:30 AM   #64
Liandri
Liandri's Avatar
Drives: 2016 M235i
Originally Posted by SerenVoX View Post
Hi guys,
Good luck! Staying tuned, very interested to hear/see the results
      05-21-2020, 11:26 PM   #65
Solid67
Hi guys,
The MSS kit doesnt come with bump stops?
      05-22-2020, 12:00 PM   #66
FaRKle!
Drives: 328d Wagon, M2 Comp, i4 eD35
Is the F2x/F3x version like the F8x one where you have to undo the lower camber arm to adjust the rear height since they placed the adjuster at the bottom? It kind of looks that way from GoodMoodley's pics.
It kind of stumps me why they'd put the height adjuster where access to it is restricted by other control arms other than to save cost by not having another spring coupler. I'm really surprised they didn't put the adjuster at the top like every other coilover/HAS kit for the F8x version.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
