03-18-2021, 04:38 PM | #1 |
Rep 776
M2 top hat / strut mount for camber on 2015+ F2X?
I can't stand the way M4 lower control arms change the caster on our cars, so I was doing some research to try to find any company making fixed (non-adjustable) camber plates. No dice, but I did find on the Vorshlag website that non-comp M2 uses the same Vorshlag part as the later F2X and F3X cars with the 5-bolt setup.
I also found the M2 and F2X use different top hats from the factory. It makes me wonder if there's a possibility the M2 top hats could add negative camber to our cars? F2X | 31-30-6-881-930 This says left, but I can't seem to find one for the right side. https://www.ecstuning.com/b-genuine-...h/31306881930/ F87 | 31-30-2-420-596 https://www.ecstuning.com/b-genuine-...t/31302420596/
M240i | Mineral White | Coral Red
03-19-2021, 06:11 PM | #2 |
Too many cars, not enough time
43
Rep 73
What's the concern with adjustable plates? Mine work fine...
I also would not do those arms due to the caster and offset change it produces, the wheel wells are already tiny enough.
FOR SALE: 2017 ///M240i, 6 speed, slick top, Estoril Blue. https://www.2addicts.com/forums/show....php?t=1865469
dradernh4371.50 |
03-19-2021, 08:55 PM | #3 |
Rep 776
