2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Ground Strap / Cable
      12-09-2020, 10:02 AM   #1
2blue
Drives: BMW ’16 228iX
I was just quoted $400.00 to replace a corroded strap by the dealership (228iX out of warranty). Seems outlandish to me - easy to access, $50 part...anyone else?
      12-09-2020, 09:22 PM   #2
pmcmtnbkr
pmcmtnbkr's Avatar
106
Drives: BMW M235I
I have always replace straps like that when they fail with a left over peace of car stereo power wire and crimped and solder on ring terminals. If you have a local car stereo shop near buy they will likely have a peace of scrap wire from an install that they could crimp some ends on for under $20 it will be better than oem
2blue2.50
      12-10-2020, 09:57 AM   #3
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
Its copper and has a nice patina, leave it alone.
2blue2.50
      02-14-2021, 08:00 AM   #4
matrixhunter
matrixhunter's Avatar
Drives: 2008 BMW X3 SI M + 2014 M235I
Replace it yourself, it takes a few minutes. Pull on the cable with some force to see if it rips. I've seen ground straps that look perfect but disintegrate the moment you touch them.
jzeiler4320.00
      02-14-2021, 08:01 AM   #5
matrixhunter
Ignore the above advice, stick with oem for this cable.
      02-14-2021, 08:16 PM   #6
pmcmtnbkr
pmcmtnbkr's Avatar
106
Drives: BMW M235I
please explain how an oem braided ground strap could be any better than using a peace of high quality ground cable in this application. It will flex well and do to the high quality of a silicone based cover will not degrade like the pictured ground wire leading to increased resistance and failure of the ground.
