AutoTalent | Dinan anti-roll bar+spring set+control arm+tuner for Bmw 230i 2017-2018 |
09-25-2019, 11:38 AM | #1 |
2306
Rep 12,654
Dinan Adjustable Anti-roll Bar Set To order anti roll bar set for Rwd please visit our website by clicking HERE To order anti roll bar set for xdrive please visit our website by clicking HERE Dinan tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner. Features + Less Body Roll + More Mechanical Grip + More Stable At Limit + Large 28mm size + More Stable At Limit + Large 19mm size --------------------------------------------------- Lower Control Arm Monoball Kit To order anti roll bar set for Rwd please visit our website by clicking HERE The quietest bearings on the market are virtually noise free so you can live with them everyday. These are the only bearings on the market that are sealed using a rubber boot to keep out dirt and road grime stopping them from wearing out prematurely. The Dinan Monoball Kit provides responsiveness you can feel by replacing the rubber bushings in the thrust arms with precision ball joints and machined aluminum housings. Improves responsiveness by eliminating the deflection inherent in the stock rubber bushings while also reducing brake shimmy. Features + Improved Steering Responsiveness + Reduces Brake Shimmy + Nylon-lined Bearings for Quiet Operation + Machined Aluminum Housings + Sealed Bearings ---------------------------------------------------- Dinan Camber Plates To order please visit our website by clicking HERE The positive adjustment range on the camber plates is unique to Dinan and allows the end user, if desired, to retain OEM camber settings on a lowered car or to combat excessive negative camber brought upon by springs that aggressively lower the car. Not only do the Dinan camber plates provide a wide range of adjustment but they also have ride quality in mind like all of Dinan's suspension components and are designed to properly retain the bumpstop so that it compresses as designed from the factory. Dinan camber plates are also built to take a beating and are the only ones that utilize a steel alloy mount plate that will resist deforming from pot holes on the street or curb hopping at the track. Aggressive drivers will benefit from reduced outside edge tire wear as well. Features + 43mm of total camber adjustment (30 negative, 13 positive from OEM). This translates to 2.5 degrees of negative camber and just over a degree of positive camber being possible. + Decreased understeer + Decreases outside edge tire wear + Steel alloy mount plate and not aluminum + Fits with factory strut tower weather seal ------------------------------------------------------ Dinan Performance Spring Set To order please visit our website by clicking HERE Install time is 6.3 hours if no alignment is requested. Dinan's Performance Spring set for the F22 228i (non xDrive) provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan lowers the 335i by a 1/2" in front and rear for improved suspension geometry and an even more aggressive stance. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot peened for stress relief to last the life of the car. The 50% increase in stiffness will reduce the rear suspension compression under acceleration and front suspension compression (or dive) under braking, giving your car a more controlled feel. Features + 50% increase in spring stiffness + Lowers the vehicle 1/2" in front and rear + Preset to prevent spring sag + Compatible with both conventional and factory electronic shocksThe Dinan performance springs will also provide a noticeable improvement in grip, for high speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at speeds as low as 20 mph, up to the top speed of the vehicle. ------------------------------------------------------- Dinantronics Performance Tuner To order please visit our website by clicking HERE The DINANTRONICS Performance Tuner is a highly engineered piece of computer hardware and software that enhances engine performance to levels the stock programming is not allowed to venture into. It does this without negatively affecting your new car warranty coverage and without affecting long term reliability or the functionality of on-board diagnostic systems. It is also the only tuning device designed to be emissions legal in all 50 states. These items are unique to Dinan and together they embody the apex of performance engineering in a powerful, reliable, and warrantied package. The Dinan Difference is possible by employing a full staff of talented engineers that are well rounded in many facets of automotive engineering and backed by a wealth of hands on knowledge. Stemming from diverse backgrounds not only on racing teams but on standard factory production line vehicles we have seen it all. Manipulating these signals with an adept hand all the while keeping an engine running at its best and with the most reliable power is what Dinan is all about. How to Place Your Order: Phone Domestic: (855) 973-2757 X 104 Phone International: (310) 231-7800 X 104 E-mail: online@autotalent.com Website: www.AutoTalent.com Payment: Installations: Feel free to visit us at our facility in Los Angeles, CA. We install everything we sell. 19143 S. Hamilton Ave Gardena, CA 90248 Shipping: All orders are shipped via FedEx, UPS, USPS and Pilot. International, Hawaii and Alaska customers: Please contact us for the best quote possible. Hours of Operation: Monday through Friday: 10AM-7PM Pacific Time Saturday: By appointment only Last edited by AutoTalent; 09-27-2019 at 11:38 AM.. |
