01-18-2019, 12:48 PM | #23 |
Everyday I'm shuffling
449
Rep 1,098
01-19-2019, 11:49 AM | #24 |
Rep 1,237
Drives: M2 Competition
What bulbs did you use after all? Same as I did or different ones?
01-21-2019, 07:13 PM | #25 | |
449
Rep 1,098
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 |
01-26-2019, 04:38 PM | #26 |
Rep 772
Drives: 2015 435i grand coupe xdrive
Just tried this on my 2014 m235i. This does now work. No LEDs in our lights at all and probably no replacements would fit.
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
10-13-2019, 04:43 PM | #27 |
Rep 500
Thanks for this DIY post. I did the LED swap today. On Bimmercode, I see options to change the left and rear reverse lights from “Bulb” to “LED” and I coded them to LEDs.
In the same coding menu, I also see “Tail Lights Inner Lamp”, currently shown as bulb type but I see no other bulbs on the tail light assembly. What is this “inner lamp”? |
10-13-2019, 04:46 PM | #28 | |
Rep 1,237
11-14-2019, 09:04 AM | #30 | |
Rep 706
Is there other sources for these LED's other than Aliexpress? |
11-14-2019, 04:00 PM | #31 |
Rep 500
Boodlied 20W 9-30V 7440 T20 W21W... https://www.amazon.com/dp/B07GBTQQKY
11-15-2019, 02:14 PM | #32 | |
Rep 706
Ali express site is annoying and wants way too much information for a simple purchase. Not comfortable doing that. Lol Will keep trying to find the same by another vendor. Appreciate all suggestions. TIA |
11-15-2019, 02:40 PM | #33 | |
Rep 500
11-20-2019, 10:27 AM | #34 |
449
Rep 1,098
11-20-2019, 11:03 AM | #35 |
Rep 1,237
I don't like AliExpress too.... but, i've still bought a few items rellated to pc building and never had a single issue, great quality items and verd low pricing.
Same applies for these bulbs. If still valid i would highly recommend to use exactly the bulbs from my link.
11-20-2019, 04:26 PM | #36 |
Rep 2,196
12-05-2019, 01:26 AM | #37 |
Rep 512
OP, the circumference of the LED bulb looks as though it may be bigger than the standard bulb. Also, in your photos it appears the plastic housing that the bulb slides into may have been cut to increase the circumference of the entry hole.
Is that correct? Did you have to increase the circumference of the hole in the plastic housing to allow the new LED bulb to slide into the housing and twist-lock into place? |
12-05-2019, 07:14 AM | #38 |
Rep 736
Drives: Lexus RC F
Wow, this is the first car I've owned that you have to remove the entire taillight housing to change a bulb lol. Usually I can just pull back the trunk lining.
Thanks for the write-up and review.
Estoril Blue E36M3
12-05-2019, 07:50 AM | #39 | |
Rep 1,237
12-08-2019, 01:39 PM | #40 |
Rep 706
Yes, I meant the number of LED's. Each has a specific output and the total is cumulative. I was reluctant to answer as I didn't want to debate this seemingly simple detail.
I would like those LED's as posted by the OP///M, but gave up on that site as for whatever reason it kept kicking some security code to my email, but the email was blank. I gave up. Have not found them anywhere else, even on the LED manufacturer website. Is weird. Anyways... Will decide what to do as the light output from the stock lights leaves much to be desired. I may settle and try the 30 led unit from Amazon. Thank you all for the feedback |
12-10-2019, 05:56 PM | #41 | |
449
Rep 1,098
Your best bet is to listen to independent reviews, not manufacturer claims. I bought the one that I posted and I can attest that it works on an M2, buscan claims or not. As you can see, it's not a simple detail, even if it's seemingly simple. |
01-04-2020, 03:50 PM | #42 | |
Rep 706
But I put one bulb in and it didn't light. Is programming from "bulb" to "led" a must? I haven't done anything in Bimmercode yet, will if needed if course. Really didn't want to change anything if I could avoid it. Although that stupid warning on start up does need to go. Anyways, let me know, thanks. |
01-07-2020, 11:26 AM | #43 | |
Rep 2,135
01-07-2020, 11:35 AM | #44 |
Rep 706
Yes first thing I did, then tried the other unit thinking maybe one was bad... No go either one.
I see the "led" setting as just preventing any code due to resistance value difference between an incandescent bulb and LED lamp (drivers). |
Tags |
led reverse light f87 f22 f23 |
