2Addicts | BMW 2-Series forum Technical Topics N55 (M235i) Engine, Transmission, Exhaust, Tuning M2 shifter on the m235i
      11-06-2016, 04:45 PM   #1
Scibike1874
Drives: Bmw Blue
Hello everyone,
I was curious if the m2 m-dct shifter be used on the M235i dct shifter. It would be a nice add-on for my car. Can this be done? Has anyone ever tried this swap?
      11-06-2016, 08:33 PM   #2
Anderw
Anderw's Avatar
Drives: F80 m3
Originally Posted by Scibike1874 View Post
Hello everyone,
There definitely is some way this may work , the F85 x5m has A ZF 8at but uses A M DCT style shifter, using its shifter and the m2s interior trim base. 99.9% it would work I'm going to look at part numbers
      11-07-2016, 09:51 AM   #3
mdputnam
mdputnam's Avatar
289
Just nit picking and unrelated to your question but, the M235i (in the US at least) is not available with a DTC (Double Clutch Transmission) it uses the ZF 8HP. A great transmission with many amazing features, but BMW's 7 speed DTC is still has the edge as far as performance.
abirmaher838.50
      11-07-2016, 12:01 PM   #4
pz619
Drives: F87 M2C 6MT, Tesla 3
I think the issue is going to be around park. There is no park button on the shifter if I recall.
      11-07-2016, 12:35 PM   #5
Anderw
Anderw's Avatar
Drives: F80 m3
very true though how does the x5m engage park as it has the 8AT
      11-07-2016, 12:43 PM   #6
pz619
Sounds like it just goes into Park when you turn the car off, which technically our cars do as well. So if you wanted to put the car in park you would need to turn off the car. If you wanted to leave the motor running I guess it's hand brake and neutral.
      11-07-2016, 12:54 PM   #7
Anderw
Anderw's Avatar
Drives: F80 m3
More than likely for this to work will require some coding or possible loss of functionality at some level like having to engage the handbrake which would give you that real Dual clutch feeling ( )
      11-08-2016, 09:26 AM   #8
Scibike1874
Drives: Bmw Blue
I guess for me I like the look of the m2 shifter. I underdtand bmw cars in general require coding to unlock functionalities not configured from the factory. Can anyone confirm how you put the m2 into park it doesn't look like it has a park button based off of the interior pictures.
      11-08-2016, 11:14 AM   #9
pz619
You can't put the M2/M3/M4 in park in the traditional sense. Keep in mind this is a DCT versus the ZF Auto that we have. On the M Cars, you turn the car off and the car engages park (unless in neutral). Generally you leave it in first gear, hand brake, car off, then the transmission locks the gear.
      04-14-2021, 03:25 AM   #10
228i_valencia
FakeM2
228i_valencia's Avatar
Germany
50
Drives: BMW 228i
Did anyone solve the problem with the manual mode? 🤔 Just swapped the gear selector/shifter on my 228i and coded it so far that the error doesn't appear anymore. I'm quite sure I have to code something but I'm not quite sure what. 😅
Also disassembled both shifters and the pcb is different as aspected. 🙃 The only reason is the small electric actuator. It pushes the leaver back into neutral position after you shut down the engine.
