2Addicts | BMW 2-Series forum Classifieds Commercial Classifieds Electronics: Audio / Video / Phone / Alarm / Navigation / Radar CLOSED: BimmerTech PnP Amp Group Buy
      09-22-2015, 07:03 PM   #23
Nelson@BimmerTech
Drives: 2014 M6 GC
Originally Posted by crbalch View Post
Nelson@BimmerTech Is there a way you can tune your amp to play nice with the ASD as Viffermike pointed out? If so, this would solve your PnP issue.
Unfortunately you can't. Its not really about 'my amp' if you decide to updrade your factory amp you will have to code it off, no other way around it. I can't lower it down but it affects the tune.
I'm a little perplex of how most of the 3 series customers don't have an issue coding it off. If you read at the F30 threads most of them don't care for ASD. Even our customer with the 228i which i used to create the tuning file didn't want to lose it.
      09-22-2015, 07:05 PM   #24
crbalch
The Schwab
crbalch's Avatar
Drives: 2020 AW M340xi
2017 BMW X1  [0.00]
2016 BMW M235xi  [0.00]
ASD is good for people that don't want an aftermarket exhaust (not everyone does), but would like their car to sound good inside.
      09-22-2015, 07:16 PM   #25
Nelson@BimmerTech
Drives: 2014 M6 GC
I'm already setup to code for the new car and have previously done it on my 135i. For me, its not a matter of difficulty, its more that I am in the minority that like ASD, and don't want to sacrifice it. I will spend the $150 on the Focal speaker upgrade, then call it a day most likely. Hard for me to justify the $800 amp only upgrade while also losing ASD.
If I find the system to be so terrible after the speaker upgrade, I may look to an amp.
This is my honest opinion as a car audio enthusiast and not a vendor. Don't waste your money on upgrading the speakers if you have no plan on upgrading the amp. Might as well keep the system as it is.
I also want to clarify that this not just an AMP. It has a 8 channel digital signal processor with 31 band eq per channel, time alignment, active crossovers, phase adjustments and much more.... Most standalone processors that have this kind of tuning capabilities start at $700.
http://www.crutchfield.com/p_975HELI...&awmt=p&awnw=g
http://www.crutchfield.com/S-uM0dpRC...-PXA-H800.html
      09-22-2015, 08:53 PM   #26
opfreak
Drives: Rabbit
Originally Posted by opfreak View Post
Why does an amp swap make ASD louder?
Technically I am unsure, but I have to assume that it has something to do with the HiFi/HK amp being tuned to handle the ASD frequencies differently. When passing the ASD through a 3rd party amp, it cannot discern what is ASD and what is music or sounds. In turn, the ASD system comes through as being much louder.
That's just werid. In my simple understanding of most amps. The signal from ASD would just be amplified, so a new amp shouldn't change that.
I geuss in someway it makes sense that BMW built in a special feedback loop, otherwise as you turn the sound up your 'engine' gets louder and its probably tuned to have a steady output.
Anyway to put a new amp inline? IE take the high level inputs into a new amp?
      09-22-2015, 11:20 PM   #27
jtskariah
Bud Light General
jtskariah's Avatar
Drives: M4 CS Limerock Grey
From what I have read, the amp is giving more power to the speakers causing the ASD to be louder. But thats the purpose of the amp, to improve the sound system by adding more power to your speakers. Regarding whether this amp is PnP, I don't understand how any other amp in the market can compete with this one in regards to the simplicity of install. This amp was build to plug directly into the car and uses the original harness. When looking for a aftermarket amp this is the reality, more power means louder ASD. I am pretty sure every single amp you install (other than the factory amp) will deal with this.
      09-23-2015, 05:24 AM   #28
opfreak
Drives: Rabbit
Except if it the original amp was acting like a simple amp, replacing it would making everything equally louder canceling out the louder ASD.
      09-23-2015, 10:34 AM   #29
Viffermike
Viffermike's Avatar
That is baloney and you know it. In almost every instance no matter what the application, upgrading the speakers appropriately makes the single biggest positive difference in sound quality. In our case, better speakers also magnify the stock HU and amp's weaknesses and biases regarding DSP, D/A conversion, etc. But it still makes the system sound much better than OEM, to the point where it is reasonably bearable depending on programming.
You know how crappy the OEM Hi-Fi speakers are, Nelson. If what you state was indeed the case, companies like BAVsound and Jehnert wouldn't stay in business.
No argument there, either. And BimmerTech's pricing of this unit, even without the group-buy discount, is really good, particularly when compared to the stock version of the Match amp. I'm not contending that the product is a bad one; not in the least. I'm contending that to operate it properly requires a vehicle modification that not everyone is willing to adopt, much less be aware of. It's important for a potential consumer to know that from the manufacturer.
I've stated my issues with the positioning of this product. I'm not going to rehash them beyond the above.
--Helmets are for closers.--
      09-24-2015, 01:37 AM   #30
Knightelf
Australia
87
2011 BMW 135i  [0.00]
How are we tracking on the group buy?
Current: 2014 F22 M235i Mineral Grey
Previous: 2011 E82 DCT 135i Space Grey
Build thread: http://www.2addicts.com/forums/showthread.php?t=1149793
      09-24-2015, 03:13 PM   #31
dailowill
Drives: '15 M235i
Almost there...
Seems like we need one more person to join and two payments to make it official!
      09-24-2015, 07:01 PM   #32
Knightelf
Australia
87
Alright, I've mentioned this in the Australia sub-forum for E82 and F22. We should get there soon!
      09-24-2015, 07:12 PM   #33
opfreak
Drives: Rabbit
I'd do it, but cant right now :-(
      09-27-2015, 11:33 PM   #34
Knightelf
Australia
87
Looks like the deal is LIVE
      09-28-2015, 01:05 PM   #35
ggabriele3
Drives: 2015 228i Msport
Are there any measurements available to quantify why this trumps the JL Audio XD600/6?
      09-28-2015, 05:42 PM   #36
opfreak
Drives: Rabbit
end date?
      09-28-2015, 06:43 PM   #37
Nelson@BimmerTech
Drives: 2014 M6 GC
end date?
When we reach 20 buyers.
      09-28-2015, 06:57 PM   #38
Knightelf
Australia
87
When do you expect to start shipping?
      09-28-2015, 08:52 PM   #39
dailowill
Drives: '15 M235i
Seems like soon!
I spoke to Nelson today and he expects to start shipping out orders Monday the latest (except for 1/2 series which are waiting for brackets)
      09-28-2015, 11:29 PM   #40
Knightelf
Australia
87
Oh right.. well that's me and you on the 1 & 2 series... d'oh!
      09-30-2015, 08:24 AM   #41
stratatak7
stratatak7's Avatar
Drives: 2016 228i xDrive M-Sport
I may be interested. Can you PM me with price, please?
      09-30-2015, 08:34 AM   #42
dailowill
Drives: '15 M235i
You got a PM!
      09-30-2015, 09:34 AM   #43
opfreak
Drives: Rabbit
i'm getting close, just because the audio needs help.
Does the tune use the center speaker? or is it disabled?
      09-30-2015, 10:35 AM   #44
Nelson@BimmerTech
Drives: 2014 M6 GC
It uses it.
