02-23-2020, 07:04 PM | #2113 | |
General
10480
Rep 40,936
Drives: 2018 Alpina B6 650ix GC
i think only difficulty is getting E-Sys Launcher PRO from TokenMaster, as he is unavailable for extended periods of time. As an alternative to Launcher PRO, you can use E-SysX: Info@esysx.com http://esysx.com/ As for a VM, you cannot run Launcher or E-SysX in a VM.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
///MaDeuce30.00 |
02-24-2020, 01:24 PM | #2114 | |
Rep 85
Now, here's what I've done: I have created a VM, that has its time set to June 2019, with a version of Windows that came out on May 2019. In that I have installed TokenMaster Pro. The machine doesn't sync it's time, meaning if I shut it down and the machine thinks it is June 5th 2019, 8pm and I boot it up 3 days later it is June 5th 2019, 8:03pm. The time moves, forward, but only when the machine is booted. I have set the SMBIOS.reflectHost to FALSE in VMWare to make sure that TokenMaster can't detect that we are running on a VM. I will do a full write-up on this later this week. This works with E-Sys 2.27.1 RC and the latest data. The NCD tool is flaky though, it seems to have issues with the latest data, and there is no workaround. Now, reason why I am doing this is as follows: 1) can I generate an NCD with an FA, SVT and data for an ECU without the car? 2) can I compare an NCD with another one, to see the impact of an VO? |
02-24-2020, 01:26 PM | #2115 | |
General
10480
Rep 40,936
02-24-2020, 01:30 PM | #2116 |
Rep 85
Cool, I just found the answers here:
https://www.bimmerfest.com/forums/sh...d.php?t=626447 https://www.bimmerfest.com/forums/sh...d.php?t=686167 Great. Are you interested in the VM solution? |
02-24-2020, 02:09 PM | #2117 | |
General
10480
Rep 40,936
09-07-2020, 03:04 PM | #2118 |
Rep 101
pikcachu do you know if you can code the 2er to use mobile sim internet via bluetooth instead of the BMW sim card in the car? I saw this suggested in another BMW forum.
09-07-2020, 04:04 PM | #2119 |
Rep 5,262
09-17-2020, 07:23 PM | #2120 |
Usually 10 over
Rep 25
E-sys and PSdZData software
To all you coding gurus:
I'm just about ready to code for the first time! I got my cable, readied my laptop, and visited the Bimmerfest "Coding: (No Request) Latest Software Links" page. The E-sys suite downloaded sucessfully, extracted files and created the directory tree. I then downloaded PSdZData ok but when I went to extract the files, 7-Zip threw up a "Unsupported command" error, stating the path ok but showing a filename different from the one downloaded. It has a ".7z" extension. 7-Zip stops here. So I went skimming around all 2 thousand posts to this thread and find out the newest E-sys is version 3.28, not 3.27.1 on the link. And I find PSdZData_Lite_v4.21.32 is not the latest either. Does anyone know what's going on here? Anyone know where I can get the latest and greatest? Thanks... |
10-08-2020, 07:15 AM | #2121 | |
General
10480
Rep 40,936
11-11-2020, 11:45 AM | #2122 |
Rep 13
Hi,
i have a problem to code the number of blinks on my 2018 M240i. by default,i'ts 3x blinks. I need 5x blinking. with the E-Sys version provided by shawnsheridan, when i want to code, i have the following menu, and if i change the value werte = 00 to 04, after coding i still have 3 blinks. So how to have 5x blinks please ? thank you. |
11-11-2020, 12:19 PM | #2123 | |
General
10480
Rep 40,936
11-12-2020, 01:11 AM | #2124 |
Rep 13
11-12-2020, 12:40 PM | #2125 |
General
10480
Rep 40,936
If car has factory Alarm System (DWA), yes, its codeable.
11-12-2020, 12:50 PM | #2127 |
General
10480
Rep 40,936
FZD => Akkustische Quittierung Entschaerfen = aktiv
11-14-2020, 08:36 AM | #2128 |
Rep 13
11-14-2020, 10:17 AM | #2129 | |
General
10480
Rep 40,936
Akkustische Quittierung Schaerfen = aktiv
11-14-2020, 10:22 AM | #2130 |
Rep 13
I īve tried it, but no bip when I close the car.
If I code : Akkustische Quittierung Entschaerfen = aktiv I have 2 bips when I open the car. If I code too : Akkustische Quittierung Schaerfen = aktiv I have 3 bips when I open the car. |
11-14-2020, 10:26 AM | #2131 |
General
10480
Rep 40,936
I have no idea then. Is Option under iDrive set?
11-15-2020, 05:21 AM | #2132 |
Rep 13
Hi shawnsheridan, no i don't have the menu in idrive.
if i try to code the HU_NBT\3000\ACOUSTICAL_LOCK_CONFIRM\aktiv ,then when i activate FA, i have an infinite green bar. Same thing if i try to code other line in FZD. |
11-15-2020, 10:45 AM | #2133 |
General
10480
Rep 40,936
Sorry, I have no idea.
12-21-2020, 11:05 AM | #2134 |
Rep 13
Hi my friend,
i reinstall my windows 10 backup to a new SSD on my DELL Laptop, reinstall Esys etc... but same thing, i have the infinite progress bar.... So i decided to create a dual boot with a Windows7,install Esys etc... and.... Bingo !! the coding is now OK !! I think it's because the update 2004 has installed on the WIN10. But now i have a good solution, if i want to code, i boot on WIN7 and i boot on Win10 for personnal usage. Thank you for your help shawnsheridan Last edited by corby59; 12-21-2020 at 11:45 AM.. |
