02-08-2017, 09:44 AM | #45 |
Rep 78
Put the dinan in super late last night. Went right to race mode and wow what a difference. Not enough hard data yet to give to you guys, but the butt dyno was very impressed. I am getting a check engine light today though and I'm not sure why. Ran through the install just as the instructions stated. Wondering if the car needs to be asleep when it's installed rather than just the ignition being off. Gonna read the code later to see what it's saying. I'll have more updates later.
02-08-2017, 11:45 AM | #46 |
Rep 78
Update: read the codes and I'm getting P12A5 and P112F. Any ideas? I just double checked the connections and everything looks fine. I'm kinda stumped :
I erased them and they came back within about 5 miles. |
02-08-2017, 11:57 AM | #48 |
Rep 78
02-08-2017, 02:42 PM | #49 |
Rep 913
Take a read. While not the same car - the code is the same.
http://f30.bimmerpost.com/forums/sho....php?t=1057503 |
02-08-2017, 04:55 PM | #50 | |
Rep 558
I'm not happy to see this and starting to second guess my purchase. @ Dinan: Any comments or reassurance that if installed as instructed and used as intended it won't result in CELs and/or error codes? Last edited by PeterWT; 02-08-2017 at 05:29 PM.. |
02-08-2017, 06:05 PM | #51 | |
Rep 3,130
That said none of our development/test cars after everything was ironed out set faults and none of the others that were received from the initial shipping that have made it to social channels or what have you have reported the same thing so this would be the first case of a CEL that I am aware of. I would encourage the OP to reach out to Dinan Warranty / Tech Support at 1-800-341-5480 x2101 as they have not been contacted about any B58 SPORT tuners to see if they could assist in sorting what may be at play. It may be worth a shot to turn it down a setting (to Sport+) and run it for a bit just to see if the OP's car may be one of those that is tuned closer to acceptable limits then norm from the factory and the maxed tune is just setting it over the edge. Not entirely scientific but it tests a possibility pretty quickly anyway. |
02-08-2017, 06:17 PM | #52 | |
Rep 558
The background info you provided is somewhat reassuring. I intend to run mine in "Sport" or maybe "Sport+", but not "Race". So, here's to hoping mine falls within "acceptable tolerances" and I never see a CEL. |
02-08-2017, 07:11 PM | #53 | ||
Rep 78
02-09-2017, 04:02 PM | #54 | |
Rep 303
This is the conclution: http://f30.bimmerpost.com/forums/sho...8&postcount=34 |
02-09-2017, 04:32 PM | #55 | ||
Rep 3,130
We had 2 M240i's in the test fleet that I am aware of. There may have been more though as they send a few out all over the place for different environments and what not to be tested in and with different drivers, etc. Quote:
AlexM240i101.50 |
02-09-2017, 10:44 PM | #56 | |
Rep 303
I hope you can solve the issues and come out with an stable unit. I would definitely buy it. |
Cars38.50 |
02-10-2017, 07:52 AM | #57 |
Rep 78
Yeah so after a bunch of trial and error, this module just isn't working properly with the car. I talked to tech support and they don't really have any diagnostic support for the unit since it's such a simple system. Their only course of action really, was to send it back for a new one but I highly doubt the module is a dud. Sucks cause I really liked the simplicity of the system. Nothing against Dinan, but I'm just gonna send it back for a refund as I really don't wanna wait for the turn around and have the next module do the same thing. I've got a jb4 on the way so here's to hoping I have no problems with that. I really hope it works for anyone else who buys this!
AlexM240i101.50 |
02-10-2017, 08:54 AM | #58 | |
Rep 3,130
Cars38.50 |
02-10-2017, 12:16 PM | #59 | |
Rep 303
02-10-2017, 01:04 PM | #60 |
Rep 558
I ordered mine on Monday and should have it one day next week. I like the simplicity and control via app as well.
Fingers crossed that it works OK on my car, at least in Sport & Sport+. I'll post results.
02-10-2017, 01:30 PM | #61 | |
Rep 3,130
We have a couple hundred of the B58 modules in the field at this point and this would be the only reported issue to date. It would be presumptive to panic and pull the product from the market when there happened to be single bad unit (for whatever reason). If more turn up as having issues then it will be addressed at this point. Currently however, its an isolated anomaly. |
02-12-2017, 12:40 PM | #62 |
Rep 283
I know in an earlier post you said you would mainly keep it in Sport and maybe Sport+, but can you try it in Race to see if a code appears?
02-15-2017, 03:17 PM | #64 |
Rep 78
I sent mine back a couple days ago, so we'll see if they actually find something wrong with it and post about it. Would be nice if some of these other people with the tuner installed, would drop some input in for the rest of you guys...
AlexM240i101.50 |
02-16-2017, 07:17 AM | #65 |
Bavarian Love
24
Rep 263
Not sure if relevant but i'm currently the tester for Dinan for the B58 DPT Sports on the B48. At least for the B48 (230i, 330i engine) the device is working properly and no issue or check engine so far. Not the same engine as the B58 that is sure but same device. In sport+ (+3psi) its pulling great and seem its doing its job properly. Didnt tried Race mode yet (+4psi) because I don't really have access to 93+ octane easily, its about 0-14F this week and we received 25 inches of snow since last sunday.
My only complaint so far is the application (at least on IOS). The map switching seem to be working fine but the boost gauge feature simply does bot work (at least on B48 engine).
08 FG2 Civic SI FBO - SOLD
09 E92 335i Xdrive FBO - SOLD 17 F22 230i Xdrive | Alpine White | Coral Red | M-Sport | BMS Intake | JB4 | 666M Rep | M Carbon Mirrors | Roof Rack | Daily Driven |
AlexM240i101.50 |
02-16-2017, 07:50 PM | #66 | |
Rep 558
However I do not plan to run it in Race because +4 boost on a stock engine is too much for my taste and I don't want to risk a stored code.
