2Addicts | BMW 2-Series forum Technical Topics Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) How do you clean your rims? Favorite brush?
      03-16-2018, 06:16 PM   #1
vancitymike
Drives: 2015 M235i xDrive
Why are nice rims hard to wash?? I usually just end up using a cloth for a lot of it because nothing I have works well on these wheels - has anyone found a brush or tool that does?
      03-16-2018, 06:22 PM   #2
overcoil
Drives: M235i 6spd
I like the sponge that comes with P21 wheel cleaner.
Saw this recently https://www.lenosgarage.com/collections/newproducts
I don’t like bristle brushes personally, prefer sponges for cleaning and microfiber pads and cloths for polishing and waxing.
      03-16-2018, 08:24 PM   #3
xantdieselx
Kingslayer
xantdieselx's Avatar
No_Country
411
Drives: 23' M3 Base
I've used every wheel brush you can imagine including boars hair, wheel woolies you name it. The absolute best brush you can get imo is the Speed Master Wheel Brush ($29.99 on Amazon) for the spokes/barrel and a boars hair brush for the face.
The Speed Master literally took the place of 3 different wheel woolies and cut my wheel cleaning time in 1/2.
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      03-16-2018, 09:14 PM   #4
gk09
gk09's Avatar
Drives: 1m
Damn here in Canada, Amazon.ca they run in the $70-110 range lol
      03-16-2018, 10:31 PM   #5
xantdieselx
Kingslayer
No_Country
411
Drives: 23' M3 Base
Holy crap that's a lot of coin. You know even at that price I think it's worth it for the time it saves.
      03-18-2018, 11:25 AM   #6
bryan_G01
bryan_G01's Avatar
1165
Drives: like i stole it...
SONAX XTREME spray, a hose, a wheel brush and elbow grease.
www.nybmwcca.org
Current Cars:
      03-20-2018, 12:55 PM   #7
mdputnam
mdputnam's Avatar
289
I don't use a brush!
I don't even touch the wheels!!
So, how do I do that?
First, I clean the car every other week so the wheels don't get extremely filthy.
I buy Sonax Full Effect Wheel cleaner in the handy 5 liter containers (it's cheaper that way and you use more with this method than you would with the dainty size spray bottle).
I put the 5 liters in a 3 gallon pressurized tank sprayer :
(Don't worry you are not going to use 5 liters to clean the wheels)
Then I pressurize the sprayer using my handy portable pancake air compressor to 100psi:
Then disconnect the air compressor walk around with the sprayer to each wheel and blast the holy bejeezus out of them with the Sonax. I let the whole shebang sit for 3-4 minutes and pressure rinse off the Sonax using my Costco PowerStroke 3100 psi pressure washer with a 40° nozzle, (don't go ape sh%t, hold the nozzle at least 3-4" away from the wheel).
After that it is just a regular wash, including the wheels, with Snow Foam and a foam cannon attached to the PowerStroke.
I then dry the wheels with a Toro leaf blower on high:
and presto sparkling shinny wheels without touching them.
      03-21-2018, 10:19 AM   #8
cxp213
cxp213's Avatar
313
I use the wool wheel brushes for the barrels, soft-bristled short brush (rubber trimmed) for the crevices and corners, and a microfiber carwash mitt for the larger surfaces. Without physically touching the wheels, it's almost impossible to get it perfectly clean. Plus, sprays can't get around bends and hit the back of the spokes or the calipers.
I like trying out different products but I've been rotating around what I currently have (Griot's, Sonax, Chemical Guys). I first spray it down with a wheel cleaner and let it soak for a minute, then physically agitate and wipe with help of ph-neutral/acid-free carwash soap.
Tpeterson156.50
      03-25-2018, 10:44 PM   #9
Maynard
Drives: 228iX & M2C
I'm not super picky, but a rag around my finger works better than the 3 different foam/brushes I'd tried.
      04-04-2018, 09:41 AM   #10
BEM-S4
BEM-S4's Avatar
This. I do Sonax first to knock off the bulk of the crud, then wash the car, finally use a quick spray of chemical guys wash and wax with a microfiber towel. From there Griots tire shine and good to go.
WolfGTI716.00
      04-05-2018, 10:47 AM   #11
MarcoZandrini
Drives: 2018 M240i
Rejex! Never scrub your wheels again. But, if you need to scrub your wheel I recommend this:
MR-544 Synthetic Net Speedy Scrubber. It’s available on Amazon. Wash it 3x with towels to remove any excess abrasiveness. I used these for decades on my alloys without issues. Then, put Rejex on the alloy.
https://www.amazon.com/SKILCRAFT-MR-.../dp/B009W0TK46
      04-25-2018, 06:16 PM   #12
zipphreak
No_Country
454
Drives: m235xi
Sonax, large wheel woolie, and a hose (sometimes you have to repeat this twice if it's caked up).... Then you can put some wheel wax on top if you like
Beware of that speed master brush, if you mess up the tip it's a nice piece of twisted metal that you jam into your nice wheels. It wasn't a problem at first, but the more you use it, the protective cap will fail, and it will ding your wheels
      04-26-2018, 02:50 PM   #13
Rolf14
Drives: 14' 228i MSport
Get wheels off the car (that 2nd set helps); put them on a table so I don't have to bend down (old back) and wash with carnauba detergent, using soft brush and microfiber; dry with microfiber; let them rest; Chemical Guys wax.
      05-13-2018, 08:29 PM   #14
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
+1 on the Speed Master. I've been using them for years. Wheel Woolies are a great tool for getting into some of the places where the SM can't get into properly such as the lug holes.
78' Honda CB400A project
      05-17-2018, 06:41 AM   #15
duluthtwo
Drives: 17 m240i
I use a soft bristle brush for pans i noticed at WalMart. At $2 i thought WTF? i'd try it. Works perfect! Has a 1' handle, 7000 miles still like new!
      08-13-2018, 12:06 PM   #16
MarcoZandrini
Drives: 2018 M240i
I use these (https://www.mcmaster.com/#scrubbers/=1e52049; then scroll down to "Mesh Scrubbing and Scouring Sponges") and McGuiar's car wash. Wash the speedy scrub with towels 2 or 3 times.
      08-14-2018, 09:32 AM   #17
BEM-S4
BEM-S4's Avatar
I started using the chemical guys wheel wax and it does help with the brake dust based on early indications.
      08-14-2018, 09:46 AM   #18
cxp213
cxp213's Avatar
313
I've been using IronX lately (+ what I wrote above) and it seems to work better than the other wheel cleaning chemicals.
      08-20-2018, 01:13 AM   #19
Lipper
Lipper's Avatar
Australia
42
Drives: 2015 M235i 6MT
I always opt for black wheels and don't worry about cleaning them.
2015 M235i 6MT | Alpine White/Black Dakota | MPerformance Body Kit | 19" M-Sport 359s w/Pilot Sport 4S (r:255/30 f:225/35)
BMS JB4 w/Bluetooth| Wagner Competition IC | Wagner DP | Evolution Raceworks IC Pipes | Dynan CAI | BMS Catch-Can | Active Autowerks Axle-Back | ECS 2-Piece Rotors/Hawk HPS 5.0 Pads | Full MP Carbon/Alcantara Trim | M-Performance Alcantara/LED Steering Wheel
      08-22-2018, 09:01 PM   #20
Geo_FF
Geo_FF's Avatar
140
Drives: 2023 M340xi Portimao Blue
Interesting.. I may have to try this. So do you just spray your wheels off with water? And how often do you have to reapply the Rejex?
5 stars on Amazon: https://www.amazon.com/Rejex-High-Gl.../dp/B00GM6NF0I
      08-30-2018, 10:32 AM   #21
MarcoZandrini
Drives: 2018 M240i
Try this link for the speedy scrubs: https://www.mcmaster.com/#scrubbers/=1edrlv0. The scrubbers are in the middle of the screen.
      08-30-2018, 01:03 PM   #22
stevenvillatoro
stevenvillatoro's Avatar
2018 BMW M240i  [0.00]
I'm not super picky, but a rag around my finger works better...
Ditto. Sometimes simpler is better; it's a touchy-feely thing.
Rejex has been my #1 care product for over a decade now. Love, love, love it.
Hint: Just tried their Mr. Detail product for the insides of my window glass. It's a MUST-have, also!
—Steve
'19 MX-5 Miata GT-S soft top
Past BMWs: two '57 Isetta 300s, '70 1600, '72 Bavaria, '78 320i, '18 M240i
