11-24-2017, 06:54 PM | #23 |
Rep 1,117
Drives: 2015 BMW M235i
I thought durability would be better since they refab oem turbos with stronger components to handle the increased boost.
11-25-2017, 01:58 PM | #24 | |
Rep 2,214
I think based on the feedback I'm going to do the flash tune, and see how it goes for 2018, combined with the whole new track setup installed. Thanks for the advice, it's more or less what I was worried about, the turbo reliability.. JB4 vs Flash tune, I already know it will feel like a whole new car. The tune we have in the GTI is APR flash tune, and it walks JB3 tuned GTI's by 6-7 cars. The flash tune is way smoother than the JB3 as well, when I compared the two. I'm hoping for a similar experience when I move to a flash tune, on the 2er. I will simply leave the JB4 on as a boost/meth controller after that.
11-25-2017, 03:28 PM | #25 |
Rep 244
Dont know what kind of horsepower you measure, but if you have 370hp to the wheels thats waaaaaaaay over 400hp from the crank. No true.
11-25-2017, 03:39 PM | #26 | |
Rep 1,117
Dylan861330.00 |
11-26-2017, 05:12 AM | #27 |
Rep 596
There does seem to be some discrepancy between peoples crank and wheel horsepower figures. Im FBO running 16psi with 99Ron (93Aki) and am getting 400/417 crank - dyno measured which is about 340whp.
Euro dynos appear more conservative? |
11-26-2017, 05:28 AM | #28 |
Rep 2,577
Do you run 16psi at 7000rpm?
Lemania 2320
11-26-2017, 07:21 AM | #30 | |
Rep 2,577
As for crank power, unfortunately there is no dyno that's invented to scientifically and effectively measure that - you'll find tons of debate on this topic but at this point, we should be only safe to look at measured wheel horsepower compared to a baseline that's gotten on same day from same dyno machine.
Lemania 2320
11-26-2017, 11:14 AM | #31 |
Rep 5,369
Different brands of dynos measure power a bit differently. In the US, we tend to use the wheel power numbers. For whatever reason in Europe, they take the wheel power numbers and automatically calculate the flywheel/crank. It really makes no sense why the Europeans do this because the wheel power numbers are what make it to the ground and back calculating to crank numbers is wrought with issues and bias, far more so than relying on wheel power numbers.
amw896582.50 |
11-27-2017, 08:38 AM | #32 |
Rep 415
Comparing American numbers to European/Australian/SA numbers is pointless. The latter tend to make the same crank figures as claimed by the manufacturer. Where as in America the manufacturer claimed figure is closer to your wheel numbers. For example most ps2 results tend to fall between 520-550 flywheel horsepower over here where as in the states it's 520-550 whp.
Terminal/trap speeds and vbox numbers are a better way to compare but even then you have different climates and environments that people will still argue over. |
12-04-2017, 11:50 PM | #33 |
Car Enthusiast
282
Rep 501
9 hours is about right IMO. Ive done a couple turbo replacements and turbo oil feed line repairs here at the dealer. dont remember the exact time off my head that it pays. Not bragging but ive done them 5 hours in and out.. its not a difficult job just time consuming especially if its ur first time doing the repair let alone first time dropping the subframe.
If your going with a new turbo - make sure the new turbo comes with Turbo oil feed lines or even just O-rings for the Feed/return lines.
2016 M235 - Melbourne Red
12-05-2017, 09:18 AM | #34 |
Rep 1,117
Thanks for replies guys! I guess my next concern is that these are remanufactured turbos. Am I being picky but when I'm dishing this kind of $$, I want brand new top notch product.
12-05-2017, 01:49 PM | #35 |
Rep 2,214
If concerned about the brand, what about the Dinan turbo upgrade using BM3 as the tuning platform and essentially much better power delivery? Or is Dinan's turbo manufactured by the same company?
I only suggest it because I've never heard of one of their turbo's failing?
12-05-2017, 02:21 PM | #36 | |
Rep 1,117
12-05-2017, 02:38 PM | #37 | |
Rep 2,214
12-05-2017, 05:19 PM | #38 | |
Rep 1,541
12-05-2017, 06:16 PM | #39 | |
Rep 2,214
On the newer GTI's you can swap the S3/R turbo (BW IS38) and the power bump is incredible (30-40whp 40-50ft-lbs), while retaining stock like reliability and dirve-ability. I was thinking at one point that maybe the turbo from the M2 may have some merit to it, but if they're already being maxed out at similar numbers, it probably wouldn't be worth it for just a bump in power. It would/could be a great alternative for when (not if) the factory turbo pukes, even if it only came through with marginal gains. Gains are gains...
12-05-2017, 07:08 PM | #40 |
Car Enthusiast
282
Rep 501
You cant go wrong with a Pure Turbo. Have very high rep. Very good customer service and alot of great feed back from the BMW community
Anthony235715.00 Rick24913.50 |
02-02-2018, 12:25 PM | #41 |
Rep 190,750
beMtroubleYou66.50 Rick24913.50 |
02-02-2018, 12:35 PM | #42 | ||
Rep 8,942
02-02-2018, 01:04 PM | #44 |
Rep 190,750
