2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions DIY: LCI Tailights
      12-17-2018, 09:34 PM   #67
glachhman3
Drives: SO M2
I'm going to have my LCI tails off my m2 for sale in a couple weeks. 400obo shipped, about 1500 miles on them. They're also ceramic coated, PM if interested.
      12-21-2018, 06:47 PM   #68
beyonce
beyonce's Avatar
27
Drives: 2022 X3 M40i
Superb instructions, very easy installation. The tail lights are beautiful, and BRIGHT.
      01-12-2019, 05:37 PM   #69
rodybmw
rodybmw's Avatar
Drives: 2022 i4 M50 / 2011 335is Coupe
Originally Posted by Hasser View Post
the LCI taillights are now on realoem as an official BMW upgrade retro fit.
Hi. Do you have any more info on that? I looked up the lighting section as well as the retrofit section on Real OEM and wasn't able to find the LCI tail lights as a "Retrofit Kit"......I just found the individual right and left tail lights. Can you point me to where you found the Retrofit Kit on RealOem......or share the part number for the Retrofit Kit? I know I could just buy the individual parts that are needed (tail lights and connector shell)....but I'd rather get a kit if BMW already sells this as a complete "kit".
Thanks in Advance
modeboy37.50
      01-18-2019, 11:42 AM   #70
sea_m2c
sea_m2c's Avatar
82
Drives: 2019 M2C - 6MT
I know it's fairly old at this point but thank you for such a well worded DIY guide! Did my retrofit in about 25mins because of now well laid out (and simple) this was. Cheers[IMG]undefined[/IMG]
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i
      01-28-2019, 02:21 PM   #71
lazymman345
Drives: Alpine White M235i
wowowowow was unsure of whether i should do this but these look amazing! so great compared to the small turn signals on the pre-LCI models
      03-25-2019, 08:04 PM   #72
stratatak7
stratatak7's Avatar
Drives: 2016 228i xDrive M-Sport
A big thank you to OP and all of the contributors to this thread. My car looks brand new. I have had 3 taillight replacements because of moisture collecting in the Pre-LCI tails and I bit the bullet and ordered the Euro tails from Schmeidmann. I was also inspired to do a full detail. Everything came out great with the code spreadsheet!
      04-10-2019, 10:01 AM   #73
SM2
SM2's Avatar
Drives: 2015 Audi S6 | 2017 BMW M2 | 2
Originally Posted by Anderw View Post
Thats what I thought too, assumed Black Friday was an American sales weekend only
I also bought the connectors from getbmwparts and ordered the Vgate icar 2 wifi OBDII to code the lights with the bimmercode app since I have a Mac book and don't want to download bootcamp to run esys
Does bimmercode work for coding the lights?
      04-10-2019, 10:02 AM   #74
SM2
SM2's Avatar
Why you selling LCI tailights?
      04-10-2019, 10:04 AM   #75
SM2
SM2's Avatar
63217420992
63217420993
63217420994
Does anyone know the difference I assume the top part numbers are for eu tailights.
      04-10-2019, 03:48 PM   #76
Anderw
Anderw's Avatar
Drives: F80 m3
Yeah that's what I used!
      04-10-2019, 03:53 PM   #77
SM2
SM2's Avatar
How easy was it?
      04-10-2019, 03:55 PM   #78
Anderw
Anderw's Avatar
Drives: F80 m3
How easy was it?
Very straight forward , just have to locate the entries and change them, on 1-10 scale , 2 out of 10 lol
SM2731.50
      04-10-2019, 07:54 PM   #79
SM2
SM2's Avatar
Originally Posted by Gabrola View Post
Attachment 1660754
The taillights are a direct fit in place of the pre-LCI ones but need a 6-pin connector instead of the 8-pin connector.
The old connector had 3-pins for the 3 brake light bulbs while the new one only needs one. While some people have opted to solder the 3 brake light wires together and connect them using a single pin. I opted to only use one of the pins, specifically the inner brake light pin since that is the one used for the brake force display function. The other two pins remain in the old connector and is left dangling next to the new connector in case the installation needs to be reversed for whatever reason.
[SIZE="4"]Parts List:[/SIZE]
  • Left Taillight: 63217420991
  • Right Taillight: 63217420992
  • 6-Pin Connectors (2x): 61132359993
[SIZE="4"]Tools:[/SIZE]
  • 10mm Socket and Driver
  • Pick tool or narrow flat-head screwdriver
  • ENET Cable and coding software (E-Sys)
  • Electrical tape
  • Masking tape (optional)
[SIZE="4"]Instructions:[/SIZE]
  1. Cover the area right below the taillight with masking tape because you risk scratching the bumper when pulling it out.
  2. Open the trunk and open the two plastic covers covering the two 10mm nuts on the taillight and unscrew them.
  3. Give the taillight a good tug and it will come out. The outer side is held in with a snap-in rubber ball thing so it needs a good tug.
  4. Remove the 8-pin connector from the taillight. First unlock the connector by pulling on gray locking tab and then pull on the connector to remove it.
  5. Put the old taillight aside.
  6. Now open the small pin-locking plastic pieces on both sides of the connector locking the pins in place.
  7. Remove all pins from the 8-pin connector except the two non-BFD brake light pins. To remove the pins just unlock them by pushing on them using a pick tool through the newly exposed area.
  8. Remove the purple locking tab from the new 6-pin connector and correctly insert the pins into it according to the pinning guide. Don't forget to insert the purple locking tab again.
  9. Now wrap the old 8-pin connector with the brake light pins with electrical tape so no water can get in there and corrode the pins.
  10. Plug in the new connector into the new taillight and install the taillight. Make sure while installing the tallight that the rubber drip rail is not bent and is correctly sealed against the body of the car.
  11. Repeat for the other side.
  12. Code the car
[SIZE="4"]Pinout:[/SIZE]
Pre-LCI Left:
Pin 1 Gray / Blue = Reversing Light
Pin 2 Gray / Violet = LED Bar
Pin 3 Gray / Yellow = Fog Light
Pin 4 Black / White = Turn Signal
Pin 5 Yellow / Black = Brake Light
Pin 6 Brown = Ground (-)
Pin 7 Black / Yellow = Brake Light
Pin 8 Gray / Pink = BFD/Brake Light
LCI Left:
Pin 1 Gray / Pink = BFD/Brake Light
Pin 2 Black / White = Turn Signal
Pin 3 Brown = Ground (-)
Pin 4 Gray / Violet = LED Bar
Pin 5 Gray / Blue = Reversing Light
Pin 6 Gray / Yellow = Fog Light
Pre-LCI Right:
Pin 1 Black / Gray = Turn Signal
Pin 2 Gray / Yellow = Fog Light
Pin 3 Gray / Black = LED Bar
Pin 4 Gray / Blue = Reversing Light
Pin 5 Gray / Pink = BFD/Brake Light
Pin 6 Black / Blue = Brake Light
Pin 7 Brown = Ground (-)
Pin 8 Yellow / Violet = Brake Light
LCI Right:
Pin 2 Black / Gray = Turn Signal
Pin 4 Gray / Black = LED Bar
[SIZE="4"]Coding:[/SIZE]
REM:
3061 LceOutputChannels:
SL_L_KALTUEBERWACHUNG = nicht_aktiv
SL_L_WARMUEBERWACHUNG = nicht_aktiv
SL_L_IS_LED = aktiv
SL_R_KALTUEBERWACHUNG = nicht_aktiv
SL_R_WARMUEBERWACHUNG = nicht_aktiv
SL_R_IS_LED = aktiv
SL_2_L_KALTUEBERWACHUNG = nicht_aktiv
SL_2_L_WARMUEBERWACHUNG = nicht_aktiv
SL_2_L_IS_LED = aktiv
SL_2_R_KALTUEBERWACHUNG = nicht_aktiv
SL_2_R_WARMUEBERWACHUNG = nicht_aktiv
SL_2_R_IS_LED = aktiv
BL_L_KALTUEBERWACHUNG = nicht_aktiv
BL_L_WARMUEBERWACHUNG = nicht_aktiv
BL_L_IS_LED = aktiv
BL_R_KALTUEBERWACHUNG = nicht_aktiv
BL_R_WARMUEBERWACHUNG = nicht_aktiv
BL_R_IS_LED = aktiv
BFD_L_KALTUEBERWACHUNG = nicht_aktiv
BFD_L_WARMUEBERWACHUNG = nicht_aktiv
BFD_L_IS_LED = aktiv
BFD_R_KALTUEBERWACHUNG = nicht_aktiv
BFD_R_WARMUEBERWACHUNG = nicht_aktiv
BFD_R_IS_LED = aktiv
NSL_L_KALTUEBERWACHUNG = nicht_aktiv
NSL_L_WARMUEBERWACHUNG = nicht_aktiv
NSL_L_IS_LED = aktiv
NSL_R_KALTUEBERWACHUNG = nicht_aktiv
NSL_R_WARMUEBERWACHUNG = nicht_aktiv
NSL_R_IS_LED = aktiv
FRA_H_L_KALTUEBERWACHUNG = nicht_aktiv
FRA_H_L_WARMUEBERWACHUNG = nicht_aktiv
FRA_H_L_IS_LED = aktiv
FRA_H_R_KALTUEBERWACHUNG = nicht_aktiv
FRA_H_R_WARMUEBERWACHUNG = nicht_aktiv
FRA_H_R_IS_LED = aktiv
3062 LceLampMapping1:
MAPPING_BREMSL_L_PWM_LEVEL_1 = 13.7V (89)
MAPPING_BREMSL_R_PWM_LEVEL_1 = 13.7V (89)
MAPPING_BRAKEFORCED_L_PWM_LEVEL_1 = 13.7V (89)
MAPPING_BRAKEFORCED_R_PWM_LEVEL_1 = 13.7V (89)
MAPPING_BLINKER_H_L_PWM_LEVEL_1 = 13.7V (89)
MAPPING_BLINKER_H_R_PWM_LEVEL_1 = 13.7V (89)
3063 LceLampMapping2:
MAPPING_NEBELSCHLUSSL_L_PWM_LEVEL_1 = 13.7V (89)
MAPPING_NEBELSCHLUSSL_R_PWM_LEVEL_1 = 13.7V (89)
[SIZE="4"]Images:[/SIZE]
Attachment 1660755
Attachment 1660756
Attachment 1660757
Do you need to unplug the battery when doing this?
      04-11-2019, 08:33 AM   #80
glachhman3
Drives: SO M2
I went with EU tails
      04-11-2019, 02:14 PM   #81
SM2
SM2's Avatar
Just to give you a heads up new sets go for $350.
      04-12-2019, 03:43 PM   #82
Joaco135
Joaco135's Avatar
Drives: 2020 M2C LBB
Seth, were you found them at that price?
Thanks.
SM2731.50
      04-12-2019, 05:41 PM   #83
SM2
SM2's Avatar
Thanks.
(U.S L tail light)
https://www.bmwpartsnow.com/oem-part...CABEgKHsPD_BwE
(U.S R tail lights)
https://www.bmwpartsnow.com/oem-part...mp-63217420994
(2x tail lights plugs)
https://www.bmwpartsnow.com/oem-part...bf-61132359993
      04-12-2019, 09:02 PM   #84
Joaco135
Joaco135's Avatar
My bad, $359.90 plus shipping and taxes.
Seth,
Thanks for the info but this ones are the USDM ones and I'm looking for the EU with amber turn signal.
      04-12-2019, 09:10 PM   #85
SM2
SM2's Avatar
Seth,
Those seem to be more expensive parts. The part numbers are the same but with ending in 1 and 2 not 3 and 4.
(Left)
https://www.schmiedmann.es/en/bmw-f2...3-21-7-420-991
(Right)
https://www.schmiedmann.com/en/produ...3-21-7-420-992
      04-15-2019, 12:20 PM   #86
SM2
SM2's Avatar
Attachment 1660754
  • Electrical tape
  12. Code the car
Pre-LCI Left:
LCI Left:
Pre-LCI Right:
LCI Right:
REM:
SL_L_IS_LED = aktiv
SL_R_IS_LED = aktiv
BL_L_IS_LED = aktiv
BL_R_IS_LED = aktiv
Attachment 1660755
Attachment 1660756
Attachment 1660757
How did you figure out the coding required for this upgrade?
      04-17-2019, 08:20 AM   #87
amelville
Drives: bmw M235i
Can I fit these lights to the car myself and they will work okay till I can drive to the dealership to code them, will it just be that a warning light will come up on the dash till it's coded.
      05-26-2019, 04:56 PM   #88
SM2
SM2's Avatar
Attachment 1660754
  • Electrical tape
  12. Code the car
Pre-LCI Left:
LCI Left:
Pre-LCI Right:
LCI Right:
REM:
SL_L_IS_LED = aktiv
SL_R_IS_LED = aktiv
BL_L_IS_LED = aktiv
BL_R_IS_LED = aktiv
Attachment 1660755
Attachment 1660756
Attachment 1660757
Why did you change LCE section to 13.7v? It appears that next to the plug in location on the back of the tail lights it says 13.5v.
