2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions BimmerCode
      04-27-2017, 06:32 PM   #23
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by pikcachu View Post
Wonder how this BimmerCode works when BMW releases a new I-step... but I'm no expert...
It codes just like E-sys (ie changes FDL's). Occasionally functions move around; but, otherwise, different I-Steps should not make that big a difference.
      04-29-2017, 10:14 AM   #24
Ft_LaudM235i
Ft_LaudM235i's Avatar
36
Drives: M2 Competition
2014 M235i  [0.00]
Vgate arrived, everything works perfectly! Was able to turn off the legal disclaimer, activated speed display on instrument cluster, activated psi and temp in the TPMS display, mirrors fold and open with both the fob or the comfort access button on the exterior door handle, and some other little things. All very cool and simple!
I did try changing the startup display on the iDrive but it seems to remain the same. Worth every penny!!
      04-29-2017, 12:30 PM   #25
BEM-S4
BEM-S4's Avatar
What did you use for mirrors on door handle lock? Mine works but just with key.
      04-29-2017, 05:34 PM   #26
mdputnam
mdputnam's Avatar
289
I get the following error when changing "Fuel Range Warning 1" or "Fuel Range Warning 2" to anything other than the default setting:
Warning instrument cluster failure. Instrument cluster must be reprogrammed by dealer.
This warning occurs after the car's system reboots. Has anyone else successfully coded these two features? Does anyone have any ideas what is going wrong with the recoding?
      04-29-2017, 07:01 PM   #27
Almaretto
Almaretto's Avatar
2374
I have never changed 2nd fuel warning but coded plenty for 1st.
In e-sys, there is error clearing. Does something similar exist in app?
      04-30-2017, 01:52 PM   #28
BMWZ4
BMWZ4's Avatar
1907
I have an older 4s with no SIM. Even though it connects to the v-gate via Wi-Fi it still won't work because the in-app (surprise!) purchases require internet.
Bit ticked because it didn't say anything about in-app purchases...man for $30US shouldn't be any of that crud
      04-30-2017, 06:47 PM   #29
itzzoscar
Drives: 2016 M235i xDrive GSM
Coded a few things using bimmercode then trying to go onto another category it timed out and now I cant connect. Keeps saying timeout error cannot read date.
      04-30-2017, 07:12 PM   #30
Almaretto
Almaretto's Avatar
2374
Let car sleep and try again later.
      04-30-2017, 07:29 PM   #31
itzzoscar
Thanks. I figured I can just try tomorrow.
      05-01-2017, 10:19 AM   #32
mdputnam
mdputnam's Avatar
289
I'm not sure, although I get the dire warning everything seem to work fine afterwards. I'm currently working with Stephan at BimmerCode support to resolve the issue. I am impressed with BimmerCode's rapid support response, I got a reply within several hours of submitting a trouble report and have received many timely responses as we work through the problem in-spite of them being located in Germany and being the weekend.
      05-01-2017, 01:33 PM   #33
Fasteddy1
Drives: 2017 M240i
Can you add in office and texting with this?
      05-01-2017, 03:28 PM   #34
culturedape
Drives: 235i 2014
anyone know which codes to change to add bluetooth audio streaming on a 2014 m235? I found various lists of codes on the forums but they seem to be outdated and don't match the options I have available using the app.
App works great; it did disconnect when connected for a while and inactive, but this may be because of the adapter. Hope this won't happen during coding.
      05-01-2017, 04:15 PM   #35
crywolf
crywolf's Avatar
Drives: 2015 M235xi
Has anyone tried coding variable light distribution with this yet?
2015 m235xi
Enzo Tune/Dinan intake/VRSF dp/Evolution FMIC/MPE
*Someone once told me "Badass ain't cheap and cheap ain't badass"*
      05-01-2017, 05:15 PM   #36
itzzoscar
So I tried to code again and still have the timeout error. I also have a JB4 OBD passthrough connected. Would that affect it? If I unplug the passthrough would it cause any errors?
      05-01-2017, 05:56 PM   #37
Almaretto
Almaretto's Avatar
2374
Was car running (ie engine on)? You definitely want to avoid connection interruptions during coding as they can result in corrupted ECU's (E-sys can fix, but not sure app has similar process to recover).
Some warning are false positives. They can clear on their own by power cycling, shutting down vehicle for 20-30 minutes, or with driving. Others do require clearing. That is great that their support is so responsive.
      05-01-2017, 06:37 PM   #38
PANDA F22
///AMG Killa
PANDA F22's Avatar
Drives: '15 M235i 6MT
Is there any way to code to leave the car in sports mode on start?
2015 BMW M235i 6MT
      05-01-2017, 06:43 PM   #39
BEM-S4
BEM-S4's Avatar
No
      05-01-2017, 09:45 PM   #40
Drpoomanchu
Drpoomanchu's Avatar
Drives: AW M235i Man FBO
You have to remove the passthrough. Jb4 requires full bandwidth to operate. Unplug jb4 and plug in v gate... code the car... when your finished coding plug jb4 back in. Wont cause any issues
      05-01-2017, 09:51 PM   #41
Drpoomanchu
Roughly a month ago I used Bimmercode along with v gate 2 and absolutely worth every penny. Seems like a very well put together app with great support and updates. No errors or timeouts experienced
e30jim62.00
      05-02-2017, 02:24 AM   #42
culturedape
Drives: 235i 2014
Yes, the car was running. The disconnect seemed to happen after I took quite a while to select the various codes to code.
By the way for other users of the app, Stephan, the creator, said that in the next version he will fix an issue that caused the ACSM module to be unavailable in the app for my particular car. Very nice of him.
Almaretto2374.00
      05-02-2017, 03:26 AM   #43
illingworth22
illingworth22's Avatar
Ireland
31
Drives: F87 M2
I know we have the "cheat sheet" for a different model but has anyone put on together for the 2 series or the M2?
I had a brief play on Saturday but I was heading to Galway for the weekend and I ran out of time....
Any Suggestions for interesting code options?
2016 F87 M2
      05-02-2017, 04:42 AM   #44
Almaretto
Almaretto's Avatar
2374
F22 coding cheat sheet
Coding Made Easier (Cheat Codes in E-Sys Launcher)
Search this Thread:
