04-16-2019, 02:33 AM | #23 |
Rep 373
Have you looked at the snow performance stage 2.5 kit? the controller is really epic doubles up as a boost a gauge as well.it comes in both nylon lines and braided hoses with an fittings.
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
04-16-2019, 11:42 AM | #25 |
Rep 2,214
BMS is the best and easiest meth integration kit I've ever used. Keeping it long term to stack with a BEF, it's honestly that good.
04-16-2019, 11:50 AM | #26 | |
Chuggin' Along
333
Rep 588
I need a simple boost actuated system with a baffled large capacity tank. It has to have stainless braided lines, a shut off toggle switch, and some indicator leds. The BEF, FBOs, xdi hpfp, and pure stage 2 turbo have already been taken care of... |
04-17-2019, 02:05 AM | #27 |
Rep 373
this is my buddies set up i have just ordered the same kit. i think the quality of the snow kit is exceptional AEM is definitely not better built they as good as each other. i got the snow kit was due to the braided lines with AN fittings and the digital controller love it. the tank is the 3quart one but ill upgrade to the 2.5gal tank as you can empty that tiny tank very quickly.
04-17-2019, 08:15 AM | #28 | |
Chuggin' Along
333
Rep 588
04-17-2019, 08:32 AM | #29 | |
Rep 373
04-17-2019, 09:16 AM | #30 | |
Rep 2,214
04-18-2019, 02:36 PM | #31 | |
Rep 1,184
04-20-2019, 11:32 AM | #32 |
Rep 2,214
The BEF? Not yet, hoping for summertime! Otherwise the system is still fully functioning as it was when I installed. Just using a meth mix now as opposed to the blue washer fluid, performs better and not all that expensive either.
04-21-2019, 10:10 AM | #33 |
Rep 211
Ideally, I would have went with custom map with meth. However, since I’ve had the JB4 already and I mostly street drive, I decided to go with JB4 + BMS’s BEF + their BMS WMI kit. Here’s what I think of the BMS kit so far:
Pros: - fully integrate with JB4 - Ease of set-up with good support from BMS - Have failsafe - Can change to non-meth maps on the fly - can log on the Bluetooth app and monitor if everything is working as it should Cons: - Sprays 100% on or off, not progressive - No actual flow sensor, only measure voltage to pump - Nylon hose only, no protection - Would be nice to have a meth level sensor in tank If I am missing anything, pls feel free to chime in |
05-07-2019, 08:43 PM | #34 |
Rep 303
Question for you guys....what boost line are you tapping into to get an accurate boost measurement to the WMI controller ? Thanks in advance for any input (and pics? ).
06-18-2019, 11:06 AM | #35 | |
Mr. Clutch
91
Rep 245
Drives: 2015 M235i
"FTG-QuickTap-CompHSG for boost port on silicone hose instead of compressor housing" $18 shipped. Taps into the silicone hose on the charge pipe. You could also try the rubber cap on your chargepipe if you're running a manual car. Or the hose that comes out of that hole if you're car is auto
Quiet M235i
jondagger90.00 |
06-24-2019, 08:32 PM | #36 |
Really Twisted
28
Rep 265
For the windshield washer idea, could swap out the sensor for this one?
https://www.snowperformance.net/Low-.../sno-40035.htm
2021 Jeep Gladiator Rubicon
2015 BMW M235i F23 - Sold |
06-27-2019, 12:29 PM | #38 |
Rep 197
Snow Performance Stage 2.5 , #4 nozzle, going 100% meth on e40 custom tune, with upgrade 2.5 gal tank. currently no leaks, pushing 50/50 spray with zero performance increase in OTS BM3 e30 map.
06-29-2019, 06:37 PM | #39 | |
Rep 1,184
The SS lines that I had looked identical to the ones in your setup. Although they could be different. Just wanted to give you a head up. The way I noticed is that my tank wouldn't need to be filled as often/ just stopped going down altogether. Just spent a pretty penny on all fragola lines and connections hopefully that solves my issues. The DO lines I was running were not cheap either. If I remember correctly they were $150-200. I think the Frag ran me just over $300. I almost wish I just stayed with the stock plastic lines... But something about running fuel through crackable non heat resistant lines sketched me out. |
07-01-2019, 07:31 AM | #40 | |
Rep 197
Braided lines feels so much better yes LOL, specially at the connectors and in engine bay. my friend got nylon lines and braided them himself with some harness covers. pretty savy |
06-15-2020, 07:22 AM | #42 |
Rep 643
Looking for photos of pumps installed in engine bay.
I couldn't find any space when I removed the passenger wheel liner and bumper. I've seen other photos of installing under headlight, but I have oil cooler there. I've seen installed on bumper support beam, but I have the old cooler duct in the way. M235i rwd 6mt USA Also interested in photos of trunk installs and where you drilled to make access holes for wires and hoses
M235i rwd 6mt
